1985 s10 4x4 speedometer gear - S-10 Forum
 1Likes
  • 1 Post By dime-dozen
post #1 of 10 Old 06-17-2019, 07:21 PM Thread Starter
User is: TheStone is offline
My speedo gear is chewed up and I can't find a speedo gear for an np207... anybody know where i can find one? I've called many shops, and everyone is saying they're discontinued.
1985 S10 Blazer, 350 sbc, BW t4 4 speed, 4x4
1991 K5 Blazer, TBI 350, SM465, NP241
1966 Studebaker Commander, 350 sbc, saginaw 4 speed
TheStone is offline
post #2 of 10 Old 06-17-2019, 07:41 PM
Registered Hoosier
Hoosier Rick's Avatar
User is: Hoosier Rick is online now
Re: 1985 s10 4x4 speedometer gear
Have you looked here?
https://www.allstategear.com/default.asp
1992 rcsb 4.3,at 357,000 miles. Rust in Peace
2002 rcsb, 2.2 at, 289,000miles
1967 C10
2006 Colorado
post #3 of 10 Old 06-17-2019, 10:16 PM Thread Starter
Can't find anything on their site, I'll call them tomorrow
TheStone is offline
post #4 of 10 Old 06-17-2019, 11:01 PM Thread Starter
I need an 18 tooth driven gear, i found a 19 tooth on ebay. Can i put the 19 tooth in? Or do i need to change the drive gear as well?
TheStone is offline
post #5 of 10 Old 06-18-2019, 09:02 AM
Transman304's Avatar
User is: Transman304 is offline
More than likely the other gear is damaged also. You can use the 19 tooth gear just be aware that the MPH will be off. Won’t cause any performance issues.
“If you can’t fix it with a hammer,you have an electrical problem.”
Brad
Morgantown WV
Like us on Facebook @ Otto Matics.
post #6 of 10 Old 06-18-2019, 02:43 PM Thread Starter
I looked through the hole, and the drive gear looks like it's in good shape, you don't think that the different tooth count on the driven is gonna bind?
TheStone is offline
post #7 of 10 Old 06-18-2019, 04:00 PM
New Member
User is: dime-dozen is online now
those gears were designed to have certain drive gears mated with certain driven gears.
GM used to put the charts in their Illustrated parts section so choices could be made.
I kinda doubt 1 tooth will matter as to the match,but as stated your speed will be off.
Im pretty sure theres not a different combo of drive and driven gears that will match and give the same
MPH as your factory set.Keep looking for the right one.
post #8 of 10 Old 06-18-2019, 08:23 PM
Registered Hoosier
The rule of thumb was 1 tooth changes the speedo about 3mph. Iirc, adding a tooth would slow down the speedo relative to vehicle speed. So, if speedo was correct before, at 55 mph, speedo would be showing 52 mph.
1967 C10
2006 Colorado
post #9 of 10 Old 06-19-2019, 07:50 PM
New Member
there are speedometer correction boxes to fix that small of an error
but then again this is a lot of work on account of giving up your search.
have dealer look up that part number for an 18 tooth and see what other vehicles it fits
then hit the junkyard.
post #10 of 10 Old 06-19-2019, 07:54 PM
New Member
just looked on ebay
theres plenty of choices from $5.88 up
https://www.ebay.com/sch/i.html?_fro...+gear&_sacat=0
oldgold1985 likes this.
You may post new threads
You may post replies
