The REAL scuba tank size and NITRO - S-10 Forum
post #1 of 17 Old 04-21-2005, 08:36 PM Thread Starter
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
User is: DJDAudio is offline
Send a message via AIM to DJDAudio Send a message via Yahoo to DJDAudio
a 3,000 PSI 80cu ft. scuba tank holds 5 gal of air at 3,000PSI
a 3,000 PSI 220 cu. ft. nitro bottle holds 15 gal of air at 3,000PSI
Hope that helps you calculate fill times.
below is an example,
to get to your tank size,
start pressure * tank volume = new pressure * truck tank size
3,000PSI * (scuba) 5 gal = X * 12 gal (my tank sixe)
15000 /12 = X
X 1250
so 1250PSI at 12 gal
above broken down is 1250 PSI at 12 gal (for a scuba tank)
all you do if volume is the same is subtract the PSI make sense?
so if you want to fill a 12 gal tank from 110-145 that is 35 PSI of fill
so take 1250/ 35 = 35.71 filles before the tank is empty.
or 8 fills from 0~145
Nitro 220 cu ft.
3750 PSI 12 gal tank
110-145 107 fills on 12 gal system tank.
The opinions and views expressed in the above post are the intellectual property of DJDAudio. The above mentioned information shall also hold no legal binding against Doug DeHaven in the court of law.
---\\\CALCULATE Compressor fill time HERE ///---
QUOTE: (Kevdog00) "You sir are like the Einstein of Mini Truckin'! lol"
DJDAudio is offline
post #2 of 17 Old 04-21-2005, 10:32 PM
User is: JAX NOMA is offline
Re: The REAL scuba tank size and NITRO
Cool deal man....I'm glad your on here to figure all this ish out, keep it up!
95 Blazer 4X4
03 Kawasaki Mean Streak
2K kawasaki ZX 9R
JAX NOMA is offline
post #3 of 17 Old 04-22-2005, 12:02 AM
Gave her the O face.
FSUnole's Avatar
User is: FSUnole is offline
Send a message via AIM to FSUnole Send a message via Yahoo to FSUnole
thats why i am doin nitrogen.
12 g tank with 220 nitro tank
FSUnole is offline
post #4 of 17 Old 04-22-2005, 07:22 AM Thread Starter
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Thanks,
Happy to help.
DJDAudio is offline
post #5 of 17 Old 04-22-2005, 02:46 PM
bagged-regal's Avatar
User is: bagged-regal is offline
i need to get to thinking on how ima make this info applied to my set up and pressures and such
FOR SALE: f9100 bags
2 valve sets, thats 4 smc 1/2 valves, 2 Ts, 6 1/2 nipples and push to lock line fittings 1/2 or 5/8. your chose
post #6 of 17 Old 12-30-2005, 03:08 PM
s10blazed's Avatar
User is: s10blazed is offline
Send a message via AIM to s10blazed Send a message via Yahoo to s10blazed
are you assuming the scuba tank is filled with compressed air or oxygen? The guys at the local scuba shop can fill mine with a variety of gasses, each i'm sure compress differently. Which gas compresses the best?
post #7 of 17 Old 12-30-2005, 03:09 PM Thread Starter
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
oh man i would not use pure oxy
but that is the actual size in gal of the metal tank.
and the math was done for normal air.
DJDAudio is offline
post #8 of 17 Old 12-30-2005, 03:13 PM
s10blazed's Avatar
Oxygen was not a consideration for me due to fire hazards and cost but its common to fill scuba tanks with oxygen or 'nitrox'. Standard compressed air was the cheapest anyways, but would pure nitrogen compress better?
post #9 of 17 Old 12-30-2005, 03:15 PM Thread Starter
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
the rate they compress the difference is so small in this case you can neglect it
DJDAudio is offline
post #10 of 17 Old 12-30-2005, 03:18 PM
FUCK YOU
Wicked Mayhem's Avatar
what about a 280 cu ft. nitrogen bottle at 3000psi i just got one.. goin in truck soon..
Wicked Mayhem is offline
post #11 of 17 Old 12-30-2005, 03:29 PM
s10blazed's Avatar
What if I keep the scuba tank (near) frozen? haha I wonder if that would net any more volume.
post #12 of 17 Old 12-30-2005, 04:04 PM Thread Starter
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
You will need to fill it frozena nd KEEP it frozen or you will have some problems lol
DJDAudio is offline
post #13 of 17 Old 12-30-2005, 04:05 PM Thread Starter
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
18.6gal of air
DJDAudio is offline
post #14 of 17 Old 12-30-2005, 04:19 PM
I Like Fire....HaHaHa
JACKEL's Avatar
User is: JACKEL is offline
We met before in the past on this forum about my retarded ass getting the air management kit from ART with the 3gal tank. Anyway, to combat my problem, I added 2 scuba tanks rather than adding a larger air tank and more compressors.
I did the math with 2 scuba tanks and a 3gal air tank:
(2) 80cf scubas (5gal) @ 3000 psi = 3000 X 10 = 30,000
30,000 / 3 = 10,000
10,000 @ 3gal. (Fill 35psi) = 10,000 / 35 = 285.71 fills of my 3gal air tank with (2) 80cf Scubas
Correct?
JACKEL is offline
post #15 of 17 Old 12-30-2005, 04:51 PM Thread Starter
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
30,000 / 3 = 10,000
Correct?
Looks right to me man.
DJDAudio is offline
post #16 of 17 Old 01-02-2006, 09:57 AM
JACKEL's Avatar
Ok, Now DJDAudio, How can I calculate the number of lifts I can get with the scubas? The front has 2600 and the rear has the F9000 bags. The truck is a regular cab S10 with the 4cylinder engine. I'm new to bagging so I guess from what I hear, 60psi in each front bag lifts it to a working drive hieght. How do i calculate volume of the bag and its depletion of the 3gal tank?
We have already figured that the 2 scubas will fill the 3 gal tank 285 some-od times and I think through past conversations, the 3 gal tank would be depleted to 110psi, 1 1/2 times to lift the front to ride hieght. I'm not sure about the rear.
Can you help calculate this one? Might give me3 a better idea of consumption on the scubas.
Thanks
JACKEL is offline
post #17 of 17 Old 01-02-2006, 10:08 AM
JACKEL's Avatar
I'm guessing here but, I imagine that if it took the front 1 1/2 fills of the 3gal tank to fully lift the front, and 2 fills of the rear to fully lift the rear, = 3.5 fills for full lift of the whole truck, then:
285.71 fills of the 3gal tank w/ 2 scubas / 3.5 fills for ful truck lift = 81.63 full pancake lifts before the scubas are empty and the comp kick on.
Sound right?
JACKEL is offline
