S-10 Forum
S-10 Forum (https://www.s10forum.com/forum/forum.php)
-   Baggin' It (https://www.s10forum.com/forum/baggin-it/)
-   -   Reference guide to selecting the size of pipe thread. and some TERMS ;) (https://www.s10forum.com/forum/f125/reference-guide-to-selecting-the-size-of-pipe-thread-and-some-terms-188644/)
DJDAudio 06-09-2005 07:43 PM
http://www.plumbingworld.com/images/...ding-sizes.png
Male threads: Measure the outside diameter of the large portion of the thread at "A"; Find figure nearest this dimension in column 1 or 2 of chart. The dimension in column 3 will be your nominal pipe thread size.
Female Threads: Measure top diameter of thread at "B"; Find figure nearest this dimension in column 1 or 2 of chart. The dimension in column 3 will be your nominal pipe thread size.
http://www.landisusa.com/chart1.jpg
Definition of pipe thread acronyms
NPT National Pipe Thread
FPT Female Pipe Thread
MPT Male Pipe Thread
PTF SAE short tape pipe thread
NPTF American National taper pipe thread for dryseal pressure-tight joints
NPSM American National straight pipe thread for mechanical joints
NPSI American National straight intermediate pipe thread
Two common pipe thread sizes exist, the tapered National Pipe Thread (NPT) and the straight National Standard Free-Fitting Straight Mechanical Pipe Thread (NPSM). The tapered threads are for joining and sealing, the straight threads are only for joining. The Dry-seal thread (NPTF) allows for joining without sealants. Three less common threads exist, the Garden Hose Thread (GHT), Fire Hose Coupling (NST) and British Standard Taper Pipe Thread (BSPT). The NPT and NPTF threads are interchangeable with sealants such as PTFE tape. None of the other thread standards are interchangeable. Female NPT threads can be designated as "FPT" and male NPT threads can be designated as "MPT."
Pipe sizes do not refer to any physical dimensions. The outside diameter of each pipe or fitting must be measured and compared to the table for size identification. For example, a 3/4" NPT pipe thread has an outside diameter of 1.050 inches. Each thread size has a defined number of threads per inch (TPI). The 3/4" NPT pipe thread has 14 threads per inch. Both the TPI and OD of the thread are required for positive identification of thread size because several sizes have the same TPI.
dragginbody365 06-09-2005 08:18 PM
Re: Reference guide to selecting the size of pipe thread. and some TERMS ;)
wheres the CFM of each size?
rcmaniac 06-09-2005 08:49 PM
Joking right?
dragginbody365 06-10-2005 12:19 AM
yeah
dragginbody365 06-10-2005 12:20 AM
but actually, since he seems to know everything about this crap, what is the CFM or CV of 15ft of 3/8" ID line.
saber07 06-10-2005 01:36 AM
uhh, isnt cfm cubic feet per minute as in regards to air compressors?
DJDAudio 06-10-2005 08:37 AM
CFM is a standord way of mesuring flow rate,
as in Cubic Feet of air a Min.
DJDAudio 06-10-2005 08:39 AM
that is not as easy as it sounds lol
it is around 45CFM,
I will work the math out at work.
here is some good reading on flow rates,
http://www.eng-tips.com/viewthread.c...=114881&page=7
dragginbody365 06-10-2005 06:40 PM
well, im trying to figure out if its really worth it to upgrade line to 3/4 or 1" instead of my 1/2" plastic line
it may not be as easy as it sounds, but im consistantly impressed by stuff you post, so i figured if anyone know, you prolly would
DJDAudio 06-10-2005 09:34 PM
if anything you will notice a diff in 5/8" line
I am still working on the formula
I will let you know.
Bdydrp02s10 06-10-2005 09:44 PM
You pretty much have to pick a fixed pressure to calculate cfm's between the two because different pressures will push the air through the pipe at different cfm's. Correct me if I'm wrong.
DJDAudio 06-11-2005 12:29 PM
you make a good point,
to calcuate the CFM and choked flow artes froma pressurized tank 15PSI+ to a empty vessle 0PSI you need to use this formula,
CD (A / V) (g R / M)1/2 [(k - 1)/(2k)] k3/2 [2/(k + 1)]a (T0 / P0b)1/2 (t2 - t1) = P2c- P1c
:eek:
I will make it into a claculator ;)
vBulletin Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright 2016 VerticalScope Inc.
