One bag, slow fill, checked many things. - S-10 Forum
post #1 of 7 Old 08-16-2005, 12:55 AM Thread Starter
Panface
specsix's Avatar
User is: specsix is offline
I installed my bags about a month ago and for the past week my passenger side bag will not fill up at all unless the tank is at 150 psi, and when it does fill up, it takes 2 turn-ons from my Oasis. The driver side comes up fast and so does the back. The only reason I have not taken apart the valve is that I have a hard time believing its dirty already....especially when its not exposed to the outside.
1) SMC Valves from SD. and 2500's in the front.
2) Line is not kinked
3) switch is good.
4) Maybe the check valve is not opening like it should?
I searched the forum and noticed a lot of threads discussing "sticking valves" ....well the valve is not sticking....it works fine.
Anything else?
TIA.
specsix is offline
post #2 of 7 Old 08-16-2005, 01:11 AM
Time to bulk up!
User is: HouseOfAtlas is offline
Send a message via AIM to HouseOfAtlas Send a message via Yahoo to HouseOfAtlas
Re: One bag, slow fill, checked many things.
The only thing I can think of is that it is the valve. Even if its brand new, it could of came bad from the factory. Things like that happen. It's a rarity, but it happens.
Good luck
post #3 of 7 Old 08-16-2005, 01:19 AM
Slingin ink
gotUsic's Avatar
User is: gotUsic is offline
Send a message via AIM to gotUsic Send a message via Yahoo to gotUsic
have you tried another valve on that bag? i was thinking kink in the line, possibly in the upper arm inside the cup.
washed out of new orleans
gotUsic is offline
post #4 of 7 Old 08-16-2005, 01:29 AM Thread Starter
Panface
specsix's Avatar
No I have not.....I will do that.....that will actually be difficult considering the hose lengths...but I guess I have no choice.
Thanks guys.....process of elimination I guess....
specsix is offline
post #5 of 7 Old 08-16-2005, 08:22 AM
Banned
Phildo's Avatar
User is: Phildo is offline
Send a message via AIM to Phildo
bad ground maybe?
Phildo is offline
post #6 of 7 Old 08-16-2005, 08:28 AM
sawzall's are cool
ohsolos10's Avatar
User is: ohsolos10 is offline
Send a message via Yahoo to ohsolos10
ooooo i know this one the check valve is backwards had the same problem with mine since if there low cracking valves 150 psi will force its way by causes theres no pressure on the othere side i had the same problem on my rear could not figure out what was wrong till i took the check valve out then it worked put it back in the right way and works like it should
post #7 of 7 Old 08-16-2005, 01:52 PM
XtremeHaze
Jmoney187's Avatar
User is: Jmoney187 is offline
Send a message via AIM to Jmoney187
Might be a sticky valve. I just got my front done about 1 week ago and i had to leave it at the shop becuz after the first 4 days of riding the valve stuck, pulled the bizitch apart and it did the trick!
2000 Xtreme strd. cab/ Magnaflow,K&N,Helix...KICKER...18"KMC's...
Bagged all around...thanks to suicidedoors.com
http://www.cardomain.com/ride/2092064...sorry the rear isnt in there yet
