ok so my brain IS FRIED! - S-10 Forum
post #1 of 33 Old 01-27-2006, 08:58 PM Thread Starter
doofus
93s10inprog's Avatar
User is: 93s10inprog is offline
Send a message via AIM to 93s10inprog Send a message via MSN to 93s10inprog
OK so we mounted my 20s to see if they will clear on an s10 AND THEY ARE LIKE AN 8TH-16TH INCH OUTSIDE the fender, so what Im wondering is, what control arms can I buy to fix this problem? basically when aired out I want to be able to tuck the tire/rim combo it was my xmas present and SHED KILL ME IF I CANT LAY OUT ON EM! GOD I LOVE'R!!!! anyway please tell me what control arms to get that will lay out( ps. Im running 2" djm drop spindles with my combo!)
PLEASE HELP ME!!!!
Chad
basically I need to lengthen the lower portion of the control arm. and Im bagging in 2 weekends from now.
let me know.
thanks guys
post #2 of 33 Old 01-27-2006, 09:07 PM
NTBSSHEVN
NCHEVYHEVN's Avatar
User is: NCHEVYHEVN is offline
Send a message via AIM to NCHEVYHEVN
Re: ok so my brain IS FRIED!
Looks like you got the wrong backspacing on the rims. I wouldn't even think about touching the control arms. You need to get rims with the right backspacing.
You arn't running spacers by chance are you?
Chris
03 S10 ZQ8-2/3 drop
08 Trailblazer SS-Lowered, exhaust, blacked out
12 Cruze ECO-Tuned, exhaust, system, CarPC
06 Trailblazer SS-Sold
01 Sonoma ZQ8-Totaled
95 S10 Bagged-Gone
post #3 of 33 Old 01-27-2006, 09:10 PM Thread Starter
doofus
no Im not running spacers at all. we got them as close to s10 as possible, but they way they are built are crazy and I dont want to get rid of them because I really like the looks of them. is there a chance I can have my rotors, and the rims milled a bit to work with my truck? otherwise could I use control arms to accomplish what I want?
thanks
Chad
post #4 of 33 Old 01-27-2006, 09:15 PM
NTBSSHEVN
NCHEVYHEVN's Avatar
I've never heard of any machine work that could be done. And control arms arn't going to solve the problem. The problem is the backspacing is wrong.
Chris
03 S10 ZQ8-2/3 drop
95 S10 Bagged-Gone
post #5 of 33 Old 01-27-2006, 09:19 PM
F u c k Wyotech
nigels_world's Avatar
User is: nigels_world is offline
Send a message via Yahoo to nigels_world
billet?
poop
post #6 of 33 Old 01-27-2006, 09:26 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
User is: DJDAudio is offline
Send a message via AIM to DJDAudio Send a message via Yahoo to DJDAudio
if you make the upper arm short and the lower long. it will pull negative camber an pull it away from the fender as you lay out.
The opinions and views expressed in the above post are the intellectual property of DJDAudio. The above mentioned information shall also hold no legal binding against Doug DeHaven in the court of law.
---\\\CALCULATE Compressor fill time HERE ///---
QUOTE: (Kevdog00) "You sir are like the Einstein of Mini Truckin'! lol"
DJDAudio is offline
post #7 of 33 Old 01-27-2006, 09:28 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
or something like this,
http://www.technotoytuning.com/t3_si...cts/ncrca.html
DJDAudio is offline
post #8 of 33 Old 01-27-2006, 09:29 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
lol
DJDAudio is offline
post #9 of 33 Old 01-27-2006, 09:32 PM
1cln_sdime's Avatar
User is: 1cln_sdime is offline
I would just shorten both u dont need much at all do that, and by the time u add the neg camber u will already have u should be fine.
post #10 of 33 Old 01-27-2006, 09:51 PM
Afterhours Admin
AVTekk's Avatar
User is: AVTekk is offline
do you have tires on them yet? are they steel? you might be able to mill the mounting surface of the wheel but it reallly depends on the manufacturer and how thick they are now. that ball joint spacer is def going to screw with the geometry and give em more neg camber, but i dont know if itll be enough and i dont think itll work, the ball joint will bind before the truck lays out..
Serving the Tri-state: New Jersey - New York - Pennsylvania[/center]
AVTekk is offline
post #11 of 33 Old 01-28-2006, 12:15 AM
User is: david4991 is offline
Send a message via AIM to david4991
spindles push your wheel out 1/2"
get rid of the spindles and mod some factory arms or get some tubulars to lay out
post #12 of 33 Old 01-28-2006, 12:27 AM
Token TSX Owner
ACE2790's Avatar
User is: ACE2790 is offline
damn doug, thats some negative camber right there.
Tony
*WTB - Random Orbital Polisher*
ACE2790 is offline
post #13 of 33 Old 01-28-2006, 06:48 AM Thread Starter
doofus
I want something like that ram, that looks sick! how would I go about getting that look when aired out?
Chad
post #14 of 33 Old 01-28-2006, 08:41 AM
Flat Out Fabricator
MiniTuckin''s Avatar
User is: MiniTuckin' is offline
Send a message via AIM to MiniTuckin' Send a message via MSN to MiniTuckin' Send a message via Yahoo to MiniTuckin'
shim the shit outta the upper control arm
post #15 of 33 Old 01-28-2006, 09:22 AM
NOW TUCKIN' 20'S
97bagdS10's Avatar
User is: 97bagdS10 is offline
Send a message via AIM to 97bagdS10
f theyre's enough material on the back side of the lug holes a local machine shope can mill them out for a price. we've doneit before at my uncles machine shop. even make a 5 lug into a six lug lol
Daily Driver: 96 s10 2dr 4wd blazer,
Project/Toy: 97 S10 doored SFBD, 2" chop top, turbo 6L, 45.5" overall height
To Do List: ALOT!
post #16 of 33 Old 01-28-2006, 01:03 PM
nick-s-10's Avatar
User is: nick-s-10 is offline
i would put some more shims on the uppper control arm
88 s-10 bagged n body dropped ---wrecker---
89 blazer lowered 5/6 shaved---sold---
84 xcab bagged n shaved---sold---
94 325i lowered
86 s-10 400 small block 4'11's(bag bodydrop suicidedoors layout on 22's son)
post #17 of 33 Old 01-28-2006, 01:43 PM
stone the crow...
Draggin97's Avatar
User is: Draggin97 is offline
yeah you can just get some material machined off the backside of the wheel, i think they did a tech article in truckin' about this a while back.
post #18 of 33 Old 01-28-2006, 02:25 PM
NTBSSHEVN
NCHEVYHEVN's Avatar
You don't just start throwing shims in there. That messes with the alignment causing tire wear and pulling.
Chris
03 S10 ZQ8-2/3 drop
95 S10 Bagged-Gone
post #19 of 33 Old 01-28-2006, 02:43 PM
Flat Out Fabricator
dude they have to camber so they clear the fenders shim the top some more man and see what that does for ya
post #20 of 33 Old 01-28-2006, 03:04 PM
nick-s-10's Avatar
i dont mean like put them whereever put the equal amount in each side
94 325i lowered
post #21 of 33 Old 01-28-2006, 03:09 PM
User is: 98s10inny is offline
I wonder what that dodge looks like aired up? How much change in camber can you get when its that negative when dropped.
post #22 of 33 Old 01-28-2006, 05:23 PM
NTBSSHEVN
NCHEVYHEVN's Avatar
Of course the suspension is going to change geometry when going up and down but what about his ride height. Pulling and adding shims to get it camber and sit flat on the ground is going to be pointless if when aired up you can't even drive the thing because it pulls hard or eats tires like a sumbitch.
Chris
03 S10 ZQ8-2/3 drop
95 S10 Bagged-Gone
post #23 of 33 Old 01-28-2006, 05:25 PM
NTBSSHEVN
NCHEVYHEVN's Avatar
You can't just pull and add equally. In order for the truck to not pull to one side most of the time you have unequal sides anyway inorder to compensate for road crown and so on and so forth.
I still say get the right wheels, machine the ones you got if it can be done or do what that one guy said of getting tubular control arms that will lay on 20s with stock spindles to suck the wheel in 1/2''.
Chris
03 S10 ZQ8-2/3 drop
95 S10 Bagged-Gone
post #24 of 33 Old 01-28-2006, 05:25 PM
Flat Out Fabricator
you do know you get an alignment after you bag a truck? Just put the truck at ? psi and have it aligned to camber correctly
post #25 of 33 Old 01-28-2006, 05:57 PM Thread Starter
doofus
yeah I knew that
Chad
post #26 of 33 Old 01-28-2006, 06:00 PM
NTBSSHEVN
NCHEVYHEVN's Avatar
Yea, but once the aligment has been done you could be right back where you started because there isn't enough negative camber to lay it out.
Chris
03 S10 ZQ8-2/3 drop
95 S10 Bagged-Gone
post #27 of 33 Old 01-28-2006, 06:13 PM
Afterhours Admin
AVTekk's Avatar
you guys are just making stuff up, you cant just add a bunch of shims to the upper control arm..sure itll pull it in but itll be cambered all the time, killing your tires in no time.
AVTekk is offline
post #28 of 33 Old 01-28-2006, 06:16 PM Thread Starter
doofus
yeah DEFINITELY DONT want to kill the tires THEYRE BRAND NEW! JUST MOUNTED! PLEASE DONT KILL MY TIRES FOR ME! but Im ordering the s10 front special tonight and a 10" monster notch bridge kit tonight as well. Ill be buying my control arms soon, PROBABLY THE THORBECKE BROTHERS new ones.
let me know.
also when I go control arms do I use STOCK spindles or what?
Chad
post #29 of 33 Old 01-28-2006, 06:17 PM
Afterhours Admin
AVTekk's Avatar
the new arms wont pull the tires in at all..as for the spindles, most run drop spindles because theyre tryin to lay out.
AVTekk is offline
post #30 of 33 Old 01-28-2006, 06:24 PM
Flat Out Fabricator
dude dont ride with that bisch on the ground i think everyone knows to ride at the same psi as they get it aligned at if they dont they dont need bags
post #31 of 33 Old 01-28-2006, 08:43 PM
F u c k Wyotech
Originally Posted by nigels_world
billet?
i guess you didnt want to answer my question?
poop
post #32 of 33 Old 01-28-2006, 08:57 PM
The Man The Myth The Mike
OnelowGnome's Avatar
User is: OnelowGnome is offline
Send a message via AIM to OnelowGnome
Originally Posted by DJDAudio
lol
MAN..... do i love layd out dodges.... too bad thats all they are good for
The Low Low
The "DUB"
Bagged, bodydropped, 20's, full painted interior, trailblazer headlight conversion,Grant calcombo/metal step shavers, fully shaved...
post #33 of 33 Old 01-28-2006, 09:33 PM Thread Starter
doofus
nigels_world sorry I didn't see that, no they are triple chrome. if you look up ADR Maximus those are my rims.
Chad
