4" blocks didn't drop 4" - S-10 Forum
 2Likes
  • 2 Post By Rhotpursuit
post #1 of 8 Old 06-18-2019, 08:34 PM Thread Starter
Ex Chevy Hater
Mikula's Avatar
User is: Mikula is offline
I'm 100% at a loss as to how its possible. after putting the 4" blocks in the rear, it only dropped 3.25".
before you say I measured wrong, I'm at least 28% sure that I measured correctly, and even have pictures to prove it. I bought the angled 4" blocks from djm.
I'm baffled because it seems literally impossible. Same leaf springs, same shocks, and a 4" block, should 100% every time equal out to a 4" drop, right? math may not be my strong suit, but subtracting 4 from a number seems pretty elementary!
any thoughts on the subject?
Mikula is offline
post #2 of 8 Old 06-18-2019, 09:13 PM
B4U Task Force
Rhotpursuit's Avatar
Re: 4" blocks didn't drop 4"
Dropping 101. Measure before and after. I'm sure you did, but did you measure the blocks?
Apple Red 96 SS
post #3 of 8 Old 06-18-2019, 09:21 PM
Registered Hoosier
Hoosier Rick's Avatar
User is: Hoosier Rick is online now
Is the axle on the bump stops?
1992 rcsb 4.3,at 357,000 miles. Rust in Peace
2002 rcsb, 2.2 at, 289,000miles
1967 C10
2006 Colorado
post #4 of 8 Old 06-18-2019, 11:53 PM
Been there Done it
oldeerslayer's Avatar
same shocks
Sure you haven't bottomed out the shocks. You need to replace them with shorter ones. Like Belltech 8530 "1982-2004 S10/S15 RWD Pickup (3"-5" Drop) 20.47" extended 12.99" collapsed
post #5 of 8 Old 06-18-2019, 11:58 PM
B4U Task Force
If he's using blocks, the shock travel won't change.
Mostizzle and manbearpig like this.
Apple Red 96 SS
post #6 of 8 Old 06-20-2019, 07:35 PM Thread Starter
Ex Chevy Hater
Mikula's Avatar
Nope. Dropping 101, cut that stuff off
I sure did. tall side of block measures 4", short side measures 3-5/8"
Mikula is offline
post #7 of 8 Old 06-20-2019, 07:45 PM
B4U Task Force
I assume you measured to the middle of the wheel well from the ground before and after the drop.
Apple Red 96 SS
post #8 of 8 Old 06-23-2019, 03:02 PM Thread Starter
Ex Chevy Hater
Mikula's Avatar
I measured center of wheel hub to middle of wheel well as well. just so tire pressure wasn't a factor.
Mikula is offline
You may post new threads
You may post replies
