Vortech upgrades - S-10 Forum
post #1 of 9 Old 03-22-2019, 12:02 AM Thread Starter
Jason d's Avatar
User is: Jason d is offline
Vortech upgrades
Thinking about going to a larger fuel pump, removing the ignition box, fmu and extra pump. Then going to a 2 bar map sensor and a tune. Only concern is if the spider injector is going to be an issue. Any info would be appreciated
Jason d is offline
post #2 of 9 Old 03-22-2019, 07:52 AM
I turn.
rentedmule's Avatar
User is: rentedmule is offline
Re: Vortech upgrades
The most straight forward to deal with it is to get a higher flow spider from Wynjammer or AUS (they're on Ebay). 36 lb/h will probably do unless you're over 300 rwhp. They're not cheap but the alternatives are usually more expensive or require a lot of fab work.
'09 G8 GT
'95 Firebird Formula auto-X build
'03 4.3L heads, cam, turbo donor for future 1st gen project
Red Jimmy '94 4dr 4wd, stock. Sold
Auto-X truck with stuff bolted to it and unbolted from it. Sold
post #3 of 9 Old 03-22-2019, 09:36 PM Thread Starter
Jason d's Avatar
Thanks, I was thinking about that size injector and my tuner thought that should be plenty. I knew about the wynjammer injector but not the aus so thanks again
Jason d is offline
post #4 of 9 Old 03-24-2019, 05:50 AM
User is: Bottlefedcamaro is offline
Fiveomotorsports also has upgradered spiders, 36lb I think
Edit: they go up to 48lb
post #5 of 9 Old 03-27-2019, 09:32 PM Thread Starter
Jason d's Avatar
Thanks, you can never have to much info
Jason d is offline
post #6 of 9 Old 03-29-2019, 04:56 AM
Can you share some info or pics of your set up? Id love to put a centri on my truck one day
post #7 of 9 Old 03-29-2019, 09:41 PM Thread Starter
Jason d's Avatar
Here’s a pic of the supercharger setup
Jason d is offline
post #8 of 9 Old 03-30-2019, 02:30 PM
What are you tuning with? Why not ditch the maf and go speed density? Unless its the older ecu not capable
post #9 of 9 Old 04-07-2019, 10:19 AM
Post Whore
chevymec's Avatar
User is: chevymec is offline
Good to know there are now more options for upgraded spider injectors!
1997 SS---Built and Blown... almost
My build thread... https://www.s10forum.com/forum/f30/pr...ecs-ss-513887/
chevymec is offline
Similar Threads
brake upgrades dime-dozen Wheels, Tires & Brakes 25 03-02-2018 09:19 AM
ISO: A vortech marine 4.3 MPI Intake 95s10&ls16speed 262ci Forum (4.3) 0 01-06-2018 07:15 PM
Vortech Supercharger $800 sbc408 Engine 3 07-10-2017 08:08 PM
4L60-E - Clarification Questions on "Corvette" & Other Upgrades Twit42 Transmission & Rearend 8 07-31-2016 12:06 AM
