Valve seal replacement - S-10 Forum
 3Likes
  • 1 Post By Rhotpursuit
  • 1 Post By oldeerslayer
  • 1 Post By Bee
post #1 of 13 Old 05-26-2019, 12:07 AM Thread Starter
usalbic's Avatar
User is: usalbic is offline
I have a 92 S10 Tahoe 4.3L that needs new valve stem seals. I was wondering if any kind souls could give a poor feller some advice on what tools I might need as well as what I might need to purchase along with the seals. It was my Grandfather's truck and I kinda would like to not screw this up. Any advice would be appreciated. A comprehensive guide would be disgustingly helpful.
usalbic is offline
post #2 of 13 Old 05-26-2019, 12:22 AM
B4U Task Force
Rhotpursuit's Avatar
Re: Valve seal replacement
Welcome....
Moved to 4.3/262
ala_frosty likes this.
Apple Red 96 SS
post #3 of 13 Old 05-26-2019, 01:21 AM
oldeerslayer's Avatar
All you really need besides the seals and valve cover gaskets is the spring compressing tool.
https://www.amazon.com/Proform-66784...B000630J84#Ask
And an air adapter so you can pressurize the cylinder you are working on. Or stuff rope in through the spark plug hole to hold the valve up.
Read the q&a at the bottom of the page for numerous tips from guys who just did it.
Be sure each piston is all the way up before doing that cylinder so the valve can't drop into the cylinder.
There are a bunch of You tubes on how to. Same as any 1st gen SBC V8. Just a bit more crowded under the hood of an s10.
Before you take the leap, care to enlighten us with why you feel it needs seals? 4.3's and 283 thru 400's have puffed a small amount of blue smoke on cold starts forever. Always will.
post #4 of 13 Old 05-26-2019, 09:25 AM
Registered Hoosier
Hoosier Rick's Avatar
What are your symptoms? Smoke on startup?, fouled plugs? oil consumption?
4.3 and small block from that era had umbrella seals on the intake valves, but only o rings on the exhaust.
I had a Monte Carlo with a 5.0 that was smoking on startup. I installed umbrella seals on the exhaust, which fixed the smoke, but down the line, it ate a valve guide, I had to replace a cylinder head.
I bought a high mileage 1992 with a 4.3. Smoked a little on startup at times, but didn't use oil. I left it alone.
Ran that truck to 357,000. Never added oil between changes.
1992 rcsb 4.3,at 357,000 miles. Rust in Peace
2002 rcsb, 2.2 at, 289,000miles
1967 C10
2006 Colorado
post #5 of 13 Old 05-26-2019, 12:00 PM
Bee
Bee's Avatar
User is: Bee is offline
I agree with Hoosier Rick here. My 91 puffs blue smoke on startup whenever it hasn't run hot for a while. It never actually burns enough to cause any noticable change in the oil level. It's at ~225k now and still runs just fine. I've thought about replacing valve seals before, but it hasn't bothered me enough to do so.
Hoosier Rick likes this.
Bee is offline
post #6 of 13 Old 05-26-2019, 12:45 PM Thread Starter
usalbic's Avatar
Definitely oil consumption. It is noticeably burning oil. Ive been carrying a quart with me to top it off. But I am concerned that I could take everything apart just to find out that the seals are fine. That would be a bad day.
usalbic is offline
post #7 of 13 Old 05-26-2019, 12:52 PM Thread Starter
usalbic's Avatar
Spark plugs are new and no fouling
usalbic is offline
post #8 of 13 Old 05-26-2019, 01:56 PM
Registered Hoosier
First, check the pcv system. A plugged port in the tbi or collapsed hose can cause oil consumption. Next, with the engine running, remove the oil cap, and check for vacuum. Failed intake gaskets can suck oil into the cylinders. Of course, check for external leaks.
1967 C10
2006 Colorado
post #9 of 13 Old 05-26-2019, 06:22 PM Thread Starter
usalbic's Avatar
Okay I will do it. Thank you for the help!
usalbic is offline
post #10 of 13 Old 05-26-2019, 06:51 PM
Registered Hoosier
Forgot to mention, AC Delco pcv valve.
1967 C10
2006 Colorado
post #11 of 13 Old 05-26-2019, 07:58 PM Thread Starter
usalbic's Avatar
Would a catch can do me any good?
usalbic is offline
post #12 of 13 Old 05-26-2019, 08:44 PM Thread Starter
usalbic's Avatar
No vacuum under oil cap just checked that a few minutes ago just to rule it out. Is there a way to troubleshoot the pcv valve or should I just buy one?
usalbic is offline
post #13 of 13 Old 05-26-2019, 08:48 PM
B4U Task Force
They're cheap...AC/Delco.
Apple Red 96 SS
Similar Threads
Valve cover replacement TranceAmerica 2.2L - 2nd gen 4-banging 9 03-09-2019 11:57 PM
Valve stem oil Seals replacement procedure ryguy170 262ci Forum (4.3) 0 11-30-2018 10:20 AM
1992 s10 4.3 Valve guide seals and Rear Main seal Help! s10masterman 262ci Forum (4.3) 3 01-08-2018 08:40 AM
EGR valve spacer gasket on a 95 replacement scartail 2.2L - 2nd gen 4-banging 0 11-22-2017 01:00 PM
Valve Cover Venting Blowndakrt 60v6 Forum (2.8/3.4) 6 07-28-2017 11:41 PM
