Starting issues - S-10 Forum
post #1 of 7 Old 07-11-2019, 04:42 PM Thread Starter
User is: 98s1024 is offline
Starting issues
When turn the key on first click. It cranks the motor over. But if you turn farther to crank the motor over. It turns the accessories on. What could be wrong?
98s1024 is offline
post #2 of 7 Old 07-11-2019, 04:43 PM Thread Starter
1998 s10 base model. Regular cab. 4x4 5 speed
98s1024 is offline
post #3 of 7 Old 07-12-2019, 12:06 AM
Been there Done it
oldeerslayer's Avatar
User is: oldeerslayer is online now
Re: Starting issues
Sounds like an ignition switch problem.
Post a video.
post #4 of 7 Old 07-12-2019, 08:06 PM
User is: 2011rex87 is offline
Why don't you replace the ignition inside the column and go from there?
post #5 of 7 Old 07-15-2019, 10:50 AM Thread Starter
Got it figured out. Someone before I owned it. Put a jumper wire in the safety switch for the clutch. It was making contact with the power supply and sending signal for the starter to crank. Pulled the wire out. Pushed the clutch in and cycled the key and it worked as it should.
98s1024 is offline
post #6 of 7 Old 07-15-2019, 01:28 PM
Been there Done it
Re: Starting issues
The ghosts of previous owners haunt many of us.
Except one member who still drives the same truck 24 years after buying it new.
post #7 of 7 Old 07-15-2019, 01:29 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Starting issues
Who's that?
Apple Red 96 SS
You may post new threads
You may post replies
