Just replaced spider assembly; misfiring even worse now; ODB2 readings - S-10 Forum
 6Likes
  • 1 Post By Hoosier Rick
  • 1 Post By Rhotpursuit
post #1 of 27 Old 05-18-2019, 04:35 PM Thread Starter
User is: jej1997 is offline
I just replaced the fuel injectors (with the new version) on my 2000 S10, and it's running even worse now. I really hope I did something stupid like put the injectors in the wrong holes. Here are my ODB2 logs. Can anyone comment on the fuel trim readings? I don't know which one is correct -- 25% or 50% -- and which cylinders the banks correspond to.
jej1997 is offline
post #2 of 27 Old 05-18-2019, 04:44 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Just replaced spider assembly; misfiring even worse now; ODB2 readings
Sorry...no magnifying glass....
Apple Red 96 SS
post #3 of 27 Old 05-18-2019, 04:46 PM Thread Starter
A larger version: https://i.imgur.com/sYvH86R.png
jej1997 is offline
post #4 of 27 Old 05-18-2019, 06:20 PM
Registered Hoosier
Hoosier Rick's Avatar
Injectors in the wrong holes was the first thing I thought of. Did you see where they were marked on the plastic block? Next would be vacuum leak.
jej1997 likes this.
1992 rcsb 4.3,at 357,000 miles. Rust in Peace
2002 rcsb, 2.2 at, 289,000miles
1967 C10
2006 Colorado
post #5 of 27 Old 05-18-2019, 08:11 PM Thread Starter
I just figured out how to look at the misfire counters. At idle, it says cylinder 2 is misfiring consistently. But if I give it some gas (~ 3000 RPM) it shows only cylinder 1 misfiring.
Since cylinder 1 and 2 are on opposite sides of the engine, it seems extremely unlikely that I somehow swapped those fuel injectors.
I am way out of my depth here.
jej1997 is offline
post #6 of 27 Old 05-18-2019, 08:13 PM Thread Starter
How does the computer detect which cylinder is misfiring? If it's looking only at fluctuations in the crankshaft speed, it would seem logical that it's less accurate at higher RPMs because the fluctuations would be smaller. Maybe it just guesses cylinder 1 when it can't determine which cylinder is misfiring?
jej1997 is offline
post #7 of 27 Old 05-19-2019, 12:01 AM
oldeerslayer's Avatar
Computers don't guess. You are giving them AI and the ones in cars haven't been developed to that point, yet.
The fuel trim numbers must have been taken at idle. Nothing ever really changed.
The drivers side of the engine is bank one even when it is turned sideways in a fwd. If you stand at the flywheel end looking toward the water pump the left side is bank 1.
post #8 of 27 Old 05-19-2019, 08:34 AM Thread Starter
Care to speculate why only cylinder 2 would misfire at idle, but only cylinder 1 would misfire at 3000 RPM?
Well, the bank 2 short term fuel trim shows a gradual decrease from 26% down to 12%, then fluctuating thereafter.
The bank 1 short term fuel trim seems to be pegged at 50%.
Yes, this log was recorded at idle, shortly after starting the engine.
So, the odd-numbered cylinders. Good to know, thanks.
jej1997 is offline
post #9 of 27 Old 05-20-2019, 08:39 PM Thread Starter
Thanks for this suggestion. I have found at least two problems so far.
One is a 7/32" hose that was obviously decayed. Not sure what it is, other than that it holds a vacuum and it goes in near where the PCV valve hose goes in. I replaced it.
Then I noticed there was a loud hissing sound near where the brake boost vacuum hose goes in. (At least that's what I think it is.) It needs a new o-ring.
Got any advice for how to identify all of these hoses and systematically look for vacuum leaks?
jej1997 is offline
post #10 of 27 Old 05-20-2019, 08:54 PM
Registered Hoosier
It's only got like 3. Pcv, brake booster, heater/storage tank,4x4 (if equipped)
jej1997 likes this.
1967 C10
2006 Colorado
post #11 of 27 Old 05-20-2019, 09:09 PM Thread Starter
How can I figure out what size o-ring I need for that brake booster connection?
jej1997 is offline
post #12 of 27 Old 05-20-2019, 09:27 PM
Registered Hoosier
Either take the old one to a hardware store, or go to the dealer.
jej1997 likes this.
1967 C10
2006 Colorado
post #13 of 27 Old 05-20-2019, 09:30 PM Thread Starter
The old one is kind of stretched out. I guess I'll try calling the dealer parts dept. tomorrow.
jej1997 is offline
post #14 of 27 Old 05-20-2019, 10:20 PM
B4U Task Force
Are you talking about the O ring on the manifold fitting?
Apple Red 96 SS
post #15 of 27 Old 05-20-2019, 10:27 PM Thread Starter
Yes.
jej1997 is offline
post #16 of 27 Old 05-20-2019, 10:36 PM
B4U Task Force
Yes.
Make sure the fitting is locked in place on the manifold. You can pick them up at the j/y for a buck or two...get several.
jej1997 likes this.
Apple Red 96 SS
post #17 of 27 Old 05-21-2019, 11:18 AM Thread Starter
I'm thinking I might need more than an o-ring. In
you can see some orange sealing parts, but on mine there's just an orange residue.
jej1997 is offline
post #18 of 27 Old 05-21-2019, 11:40 AM Thread Starter
Mine are shown here: https://imgur.com/a/wnjvBnk
There is some orange stuff in the slot where the o-ring used to be. Is that just orange paint, or does it matter?
jej1997 is offline
post #19 of 27 Old 05-21-2019, 11:55 AM Thread Starter
The dealer will sell me the o-ring for $2.44. Posting the part number for posterity: 24500514
I really hate the 10-minute editing timeout on this forum. Do I need to paint something on there to replace the orange stuff to make a good seal?
jej1997 is offline
post #20 of 27 Old 05-21-2019, 12:01 PM
B4U Task Force
Just put a little engine oil on it..
jej1997 likes this.
Apple Red 96 SS
post #21 of 27 Old 05-22-2019, 06:50 PM Thread Starter
Well, the hissing noise is gone now, but otherwise, no improvement.
I'm going to take it to a shop tomorrow and have them run the fuel injector balance test, just as a sanity check to make sure I didn't install a highly defective spider assembly.
Any advice on how to proceed after that would be welcome.
jej1997 is offline
post #22 of 27 Old 05-22-2019, 06:55 PM Thread Starter
Does the fact that the misfiring cylinder changes with engine RPM suggest a timing problem?
jej1997 is offline
post #23 of 27 Old 05-23-2019, 06:41 PM Thread Starter
If anyone is still reading this, I finally took the intake plenum back off and verified that the fuel injectors were in the correct holes.
However, I noted that I had forgotten to put on the gasket between the spider assembly and the intake plenum. D'oh! This is the level of incompetence we are dealing with here, folks.
I don't think the main intake plenum gasket was seated very well, either. It looked like some gas had leaked under it, and it was a little loose which made it very difficult to keep it in place while installing the intake plenum. So I put some oil on it and stuck the whole plenum in the fridge for an hour, and that helped. I'm pretty sure all of my vacuum seals are good now.
But it's still misfiring.
jej1997 is offline
post #24 of 27 Old 05-23-2019, 08:24 PM
B4U Task Force
There was need to put it in the fridge. Wiggling the spider while applying pressure tp the manifold will help slip into place.
Apple Red 96 SS
post #25 of 27 Old 05-23-2019, 10:03 PM Thread Starter
Oh, crap. I just watched a video of myself doing the original installation. I didn't forget the gasket. So where is it? I think I know.
jej1997 is offline
post #26 of 27 Old 05-29-2019, 02:22 PM Thread Starter
Paid $95 today to have a mechanic run the fuel injector balance test and tell me injector 1 is not delivering fuel.
Sending back the Chinese garbage to Amazon.
jej1997 is offline
post #27 of 27 Old 05-29-2019, 03:14 PM
B4U Task Force
AC/Delco or Delphi only.
jej1997 likes this.
Apple Red 96 SS
Similar Threads
1994 Chevrolet S10 4dr Blazer SUV Chevys10blaze Trucks For Sale 2 03-16-2019 03:43 PM
2003 X Code Spider Assembly Poconoracing 262ci Forum (4.3) 19 11-20-2018 08:43 PM
Map sensor voltage readings. legotech7 S10 / S15 1 02-22-2018 08:42 PM
Bought a 97 blazer - think it needs a 'spider' Torque262 262ci Forum (4.3) 23 09-19-2017 06:03 PM
Replaced my tailgate lock/latch handle timster Blazer / Jimmy / Bravada 0 12-19-2016 09:23 PM
