Help identifying wire connector - S-10 Forum
post #1 of 12 Old 06-09-2019, 04:27 AM Thread Starter
User is: jrbdjb is offline
While searching for a fuel injector problem, I found this hanging loose beside the passenger side inner fender. The wire comes from the drivers side and disappears into a wire loom there. I can find nowhere that it connects to, yet appears clean, like it had just came unplugged. Any ideas? Thanks!
jrbdjb is offline
post #2 of 12 Old 06-09-2019, 04:02 PM
New Member
Racer-X's Avatar
User is: Racer-X is online now
Re: Help identifying wire connector
Two things would help here. Knowing what year it is.
Also, carefully peel back the tape and plastic tubing and tell what colors the wires are (and what color stripe(s) if present).
Finally, I'm going to assume (bad, I know) that since this was posted in the tutu section, it's a 2.2L 4 cylinder engine. If that's not right, tell what engine you actually have.
Every machine is a smoke machine if you operate it wrong enough.
post #3 of 12 Old 06-09-2019, 08:01 PM Thread Starter
My mistake all around...it's a 95 Vin Z, 262 (4.3). I'll ask an admin to delete this and post in the proper forum.
jrbdjb is offline
post #4 of 12 Old 06-09-2019, 08:09 PM
B4U Task Force
Rhotpursuit's Avatar
I'll just move it...
Apple Red 96 SS
post #5 of 12 Old 06-09-2019, 11:49 PM
Been there Done it
oldeerslayer's Avatar
Still need the wire colors to id it.
post #6 of 12 Old 06-10-2019, 09:39 AM Thread Starter
They are orange and yellow
Thanks again
jrbdjb is offline
post #7 of 12 Old 06-10-2019, 09:50 AM
Engineer, Member SAE
User is: daveca is offline
It may have been connected to the knock sensor on the side of the cylinder head... if not I have the original manual and could look it up by colors.
daveca is offline
post #8 of 12 Old 06-11-2019, 12:12 AM
Been there Done it
The 2 wires going into a single connector are orange and yellow? Very odd color combination. Orange usually has something to do with courtesy lighting. Maybe an under hood light that is no longer there? Yellow is usually used for accessories like power windows or windshield washers. Never seen the 2 combined on one plug since they both tend to be positive circuits.
If it were orange and black, black with a white stripe, or brown, I'd definitely guess under hood light.
I went through all 67 pages of the 1995 wiring diagrams and found no connector that had orange and yellow to it.
post #9 of 12 Old 06-12-2019, 08:08 PM
User is: Roguedog is offline
cold air sensor on air intake pipe coming from fender?
Roguedog is offline
post #10 of 12 Old 06-12-2019, 11:42 PM
Been there Done it
Nope.
Air Intake / Charge Temperature Sensor Connector
post #11 of 12 Old 06-15-2019, 11:20 PM
bronc3buster84's Avatar
User is: bronc3buster84 is offline
Is the truck 4wd. Only seen that connector on a few trucks. Goes to a solenoid to lock the front diff in.
post #12 of 12 Old 06-16-2019, 08:19 AM
Been there Done it
Never seen a 95 with that solenoid. Only seen them on newer trucks with the 4 button transfer case.
You may post new threads
You may post replies
