1989 s10 blazer cold issues - S-10 Forum
 5Likes
  • 1 Post By unorthodox122
  • 1 Post By oldeerslayer
  • 1 Post By Rhotpursuit
  • 1 Post By matt12ar
post #1 of 9 Old 08-18-2018, 05:42 AM Thread Starter
matt12ar's Avatar
User is: matt12ar is offline
Whenever the vehicle is cold started 10 seconds after start it has a high to low idle it repeats and sometimes stall, usually after a restart and a blip on the gas it corrects the issue, while the vehicle is still cold after going into drive and moderately stepping on the gas the vehicle will bog down and have its "pop" this also sometimes may stall the vehicle. Once the vehicle is at operating temperature all the symptoms go away. I replaced the coolant temperature sensor I replaced the cap and rotor,I replaced the spark plugs along with the wires
matt12ar is offline
post #2 of 9 Old 02-19-2019, 11:02 AM
User is: Tulsaguy is offline
Re: 1989 s10 blazer cold issues
Hey Matt. This is Lloyd in Tulsa. I'm having the same problem with my 91 4.3L. Did you ever find out what your problem was? Any help would be greatly appreciate.
Tulsaguy is offline
post #3 of 9 Old 02-19-2019, 11:08 AM
unorthodox122's Avatar
User is: unorthodox122 is offline
Hi Lloyd, there's a good chance you'll be waiting for a reply for a while, he hasnt been on in a few months. Better off trying to create a new thread. Lot's of helpful people here.
Try checking the IAC besides the throttle body.
ala_frosty likes this.
91 S10 V8 Tahoe TBI AWD 3.73 disc brakes, 2.5 dual exhaust
post #4 of 9 Old 02-20-2019, 01:45 AM
oldeerslayer's Avatar
Is there an echo in here?
post #5 of 9 Old 02-20-2019, 01:54 AM
B4U Task Force
Rhotpursuit's Avatar
^^^Not now...
Apple Red 96 SS
post #6 of 9 Old 02-20-2019, 02:43 AM
User is: ala_frosty is offline
Nope. No echo.
post #7 of 9 Old 04-20-2019, 05:02 AM Thread Starter
matt12ar's Avatar
the answer/ fix in case anyone was wondering so that any poor soul who finds them self's in this pickle
I stumbled upon it accidentally I was retiming the engine with a timing light and noticed the right injector was dripping.this was a clogged injector. after a trip to my local parts yard, took a low mileage TBI system from a 5.7 1993 Cadillac fleet wood, worked like a charm and in my case the engine runs ok, one clue to look for is when your 0bd1 is running a lean code under heavy acceleration
matt12ar is offline
post #8 of 9 Old 04-20-2019, 06:34 AM
Surprised that it's not running rich with the 5.7L Caddy injector. The actual injectors on those are capable of a much higher 61lb./hr flow rate than the 45 lb./hr. on a 4.3L. Guess the ECM must be capable of compensating for the 35% higher flow rate.
post #9 of 9 Old 04-21-2019, 02:43 PM Thread Starter
matt12ar's Avatar
never once threw a rich code
matt12ar is offline
