Where does this go- Intake gasket job - S-10 Forum
post #1 of 13 Old 01-01-2016, 08:25 PM Thread Starter
User is: Wnys10 is offline
First time post. Not sure this is the right section Doing a lower intake manifold gasket on my winter beater.(2001 4.3L 4x4) Truck was leaking coolant from front passenger side. Got the intake manifold off and after I got it out found this o ring sitting on the valve cover. Where does it go. And a pic of one of the plugged coolant ports
ID:	242601   Click image for larger version
Wnys10 is offline
post #2 of 13 Old 01-01-2016, 10:05 PM
User is: hotrodray1 is offline
Re: Where does this go- Intake gasket job
I think it goes toward the rear of the upper intake there is a fitting that it goes on. I just did same intake gasket Monday night there was a replacement orang that size in the kit. I did not use mine. It may be for the vacuum hose fitting for the brake booster.
post #3 of 13 Old 01-02-2016, 05:35 PM
User is: sparkybuoy is offline
that gasket kit might cover the years that had a Distributor and that would likely be the Distributor O-Ring
Usually the Gasket carton gives you a part number and usage breakdown on the front of it
post #4 of 13 Old 01-03-2016, 08:02 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
This looks like a 4.3, yes? ^^^ good call. Dizzy seal.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #5 of 13 Old 01-03-2016, 08:28 PM Thread Starter
Well got the lower back on and I still can't seem to figure out where this goes. There's two ports on the right of the upper intake with both orange o rings that look similar. But this one doesn't fit correctly into either
Wnys10 is offline
post #6 of 13 Old 01-03-2016, 11:16 PM
Like I said above...the GASKET KIT CARTON tells you what comes in it and what they're for
BTW...you're a 4.3 and this is the 60 degree V6 forum not the 90 degree V6 forum
post #7 of 13 Old 01-04-2016, 12:18 AM Thread Starter
Sorry bout that. All it says is o-ring on the description but this didn't come with the gasket kit. It fell off something as I pulled the lower intake off and I can't find where it goes now. There is no O-ring the same size in the gasket kit.
Wnys10 is offline
post #8 of 13 Old 01-04-2016, 12:45 AM
B4U Task Force
Rhotpursuit's Avatar
Did you check the distributor for a gasket or "O" ring? I seem to remember mine having a gasket.
Apple Red 96 SS
post #9 of 13 Old 01-04-2016, 09:58 AM
etaomicron's Avatar
User is: etaomicron is offline
The distributor has a o ring, in the 2.8's I've seen it as a very common oil leak problem
post #10 of 13 Old 01-04-2016, 10:15 AM Thread Starter
Would probably be on the shaft itself right. Above the gears on the bottom
Wnys10 is offline
post #11 of 13 Old 01-04-2016, 11:50 AM
etaomicron's Avatar
Yes.
post #12 of 13 Old 01-04-2016, 01:19 PM
B4U Task Force
And this applies to a 4.3 how?
Apple Red 96 SS
post #13 of 13 Old 01-07-2016, 08:45 AM
Boozebag
Mad Max's Avatar
Did you consider this o ring may have been from another job?
It may have been sitting there the whole time and you just noticed it...
That has happened to me a few times.
S10 addiction:
Mad Max is offline
You may post new threads
You may post replies
