Where are all the ground locations at? - S-10 Forum
post #1 of 4 Old 02-13-2019, 07:06 PM Thread Starter
Tonguen4202000's Avatar
User is: Tonguen4202000 is offline
I've been having issues with my headlights and other electrical components. I've read a lot in here about maybe having a bad ground connection somewhere. Was just wondering if anybody has the locations of all the grounds so I can go through them one by one.
post #2 of 4 Old 02-13-2019, 07:07 PM Thread Starter
Oh yeah it's a 1982 s10 2.8l engine. 2wd
post #3 of 4 Old 02-15-2019, 01:57 PM
Awww..you ain't got shit!
jimmykicker's Avatar
Re: Where are all the ground locations at?
Driver's side head there should be a strap on the 82...by the firewall. Also check the corners of the dash. Imagine if your e brake is up. Directly above the footpad.... and I mean on the padded part of the dash above the footpad....and mirrored spot on the other side. Lights get wonky if those are loose. 10mm I think.
I had to cut my nut in half .
post #4 of 4 Old 02-15-2019, 01:59 PM
Also check at your rear bumper. Driver side...I think.
Similar Threads
Ground G104 Location for possible P0135 o2 fix MikeT2002 Electrical / Lighting 4 01-07-2019 07:10 PM
Finding a ground ECM Connectors Reddos S10 / S15 2 09-05-2017 12:04 PM
Under dash ground point cut wire JAD S10 / S15 4 08-19-2016 01:25 AM
No injector ground pulse 2000 Olds Bravada ben.dunklee 262ci Forum (4.3) 0 07-31-2016 07:22 PM
S10 Xtreme ground effect parts (Titusville, fl ) Timewarp Parts 0 05-25-2016 04:44 PM
You may post new threads
You may post replies
