unburned fuel, bad idle - S-10 Forum
post #1 of 7 Old 07-16-2015, 12:00 PM Thread Starter
Belgian User
User is: SimonV is offline
I have 2.8V6 Tbi.
It idles bad ( after I changed the sparkplugs because it didn't idle at all anymore ) , can't seem to find leaks.
It also smokes when I accelerate or even when it's iddling. It's not oil and / or blue smoke. Really looks like fuel that doesn't get burned. Ok I might change the sparkplugwires to be sure but I don't think that's the problem. My Blazer can also run on propane and it does not seem to have problems when it does run on that.
So I do think somethings wrong with the fuel supply somehow. Any suggestions ?
SimonV is offline
post #2 of 7 Old 07-16-2015, 12:40 PM
Maybe later.
tytotheler92's Avatar
Re: unburned fuel, bad idle
Does it run on Propane?
1988 S-15 - 5.5/6 drop
1985 S10 Blazer 4WD
1998 Blazer ZR2 5 Speed!
post #3 of 7 Old 07-16-2015, 12:45 PM Thread Starter
Belgian User
Yes, seems to have no problems in that case. But I want the original fuel-system to be ok, just in case I run out of propane before I reach a gas-station where they sell it.
As soon as I switch to propane ( and original fuel-supply get's switched off ), rpm goes up and it's running fine.
SimonV is offline
post #4 of 7 Old 07-19-2015, 09:26 AM
overthinker extraordinar
jcricket's Avatar
User is: jcricket is offline
wild ass guess, timing.
Propane has a higher octane and could run okay with advanced timing. Gas, well it would cough and sputter a bit if it was too advanced.
Like I said, WAG
good luck
mark
jcricket is offline
post #5 of 7 Old 07-20-2015, 05:26 AM
User is: damanx is offline
I'm curious as I don't know the technical specifics of the system for propane in conjunction with gas, but is there a different computer and injector system for that, or does the propane use the same ecm and injectors?
1985 GMC S-15 Gypsy ext cab.
3.4l, Edelbrock intake, a 4.3l throttle body controlled by an '88 TBI ECM. 700R4 with 3.73 rear. Real time tuning using a CF-30 Toughbook with a Moates Ostrich 2 emulator.
damanx is offline
post #6 of 7 Old 07-20-2015, 09:15 AM
jcricket's Avatar
sorry, I don't know. I am guessing at the timing thing too.
jcricket is offline
post #7 of 7 Old 07-21-2015, 08:52 AM Thread Starter
Belgian User
Checked the idle, maybe one degree off. That's not going to be the problem I guess.
About running on propane, it uses the same ECM. All what happens is that fuel supply is cut off and propane is injected before the throttle body.
I am starting to think I have a melted or clogged cat ? Melted because running on propane is a lot hotter. It's throwing also two codes: to rich and to lean mixture ....
SimonV is offline
