TT 3.2 stroker build. -update- - S-10 Forum
post #1 of 2 Old 08-19-2015, 04:03 PM Thread Starter
User is: x1991Dimex is offline
Block is at the machine shop
Heads are being tore completely apart.
Ported/ polished and built with all SS performance head kits from ARI.
Block is getting a 100% make up.
Got my 3.1 camaro crank on order from.
Now just gotta find some 2.8 connecting rods
And then get my pistons from Summit Racing
My intakes are done. Im using a different set of injectors due to the 450cc ones not fitting into my mpfi camaro rail...super bummed out about that.
Still contemplating the tuning. If I wanna do it myself, or take it to a shop
But.. I got my interior done. Carpet is gutted.
Rhino lined the floor.
Starting fab work on body and then while thats happening the rear end is getting changed. Picked up a 96+ 4x4 blazer rear end 28 or 29spline axles, posi, 373 gears, rear disc brakes.
All body work will be completed by the first weekend of October, due to the passanger side inner rocker panel not being available and being apart of the cab.. so thats gotta be custom fabbed up..
Manifold flanges need to be re done. The shop I took them to to be cut out... ended up messing them up.. sooo.. that was a set back.
But its coming along very well.
post #2 of 2 Old 08-23-2015, 05:35 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Re: TT 3.2 stroker build. -update-
PIX !!!!
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
