Tranny cooler/towing - S-10 Forum
post #1 of 9 Old 10-08-2014, 03:15 PM Thread Starter
User is: bestof1987 is offline
So i have a 2.8l 5 speed and I am soon to start driving. My mom does lawn care and has like a 18-24 foot trailer, seems to pull good under 20mph, i already installed a 7pin flat for the trailers and i was wondering if anyone knows if you do put a tranny cooler in a manual and what else can i use to bump up my towing.
post #2 of 9 Old 10-08-2014, 04:25 PM
4 Year Intermediate Tech
greasemonkeys10's Avatar
User is: greasemonkeys10 is offline
Re: Tranny cooler/towing
Won't need one, the case for a manual has a ribbed pattern much like a heat sink. The main reason for a cooler is only needed in automatic transmissions. The torque converter generates a lot of heat. A manual has no pump and relies on splash oiling so make sure your fluid is topped off.
1985 2.8L V6 S10 completely restored with 65,000 miles on body, frame, and rear axle. Weber 38 DGES Powered SOLD
1989 Nissan D21 Z24i 8 Wire Wonder
1995 Chevy S10 ext cab 4.3 Z 40,000 Miles On Rebuild.
post #3 of 9 Old 10-08-2014, 04:27 PM
If anything you might look to get a engine oil cooler but they leak 80% of the time.
post #4 of 9 Old 10-08-2014, 04:30 PM Thread Starter
got it i read some stuff and its always on auto but thanks for the
help
post #5 of 9 Old 10-13-2014, 08:25 AM
Awww..you ain't got shit!
jimmykicker's Avatar
Is the trailer really 18+ feet? That seems really heavy for an old S truck with stock powertrain man...
I had to cut my nut in half .
post #6 of 9 Old 10-13-2014, 02:06 PM
User is: scrappyk5 is offline
Wow, 18'-24' trailer with lawnmowers. Lotsa weight for an s10 with a 2.8. I am glad your staying under 20mph, any faster and that weight will pull the s10 into a ditch. Good luck on the clutch lasting a long time.
post #7 of 9 Old 10-13-2014, 04:55 PM Thread Starter
Ive had no problem towing it
post #8 of 9 Old 10-14-2014, 04:58 AM
Didnt say the " little s10 that could ", would have a problem towing it. Its the aftermath that might get you, whether you cook the little clutch disk, or having to swerve and the weight of the trailer pulling you into the ditch cause it weighs more than the truck itself. This was just kind of a fyi. They are tough little trucks in the stock form, maybe not alot of power, but tough.
post #9 of 9 Old 10-17-2014, 09:45 AM
I pulled a 3 axle heavy duty trailer with a Ford Taurus cop car on my 2001 4.3 5spd once. This was truly a big truck in a little truck body. NV3500, 8 inch rear...strong 4.3. Only issue? BRAKES!! YE GODS! That was some scary shit! What a deathtrap! It would have been better with the Blazer dual calipers, but it was too heavy. Tranny mount didn't really appreciate it either...But as far a pulling went? Perfect! Do the math on that and see how much weight it was.
