Starter issue - S-10 Forum
post #1 of 4 Old 09-05-2015, 11:21 PM Thread Starter
etaomicron's Avatar
User is: etaomicron is offline
Starter issue
Alright I've been having an intermittent problem. My truck won't crank I give it a while and it cranks. Well now it won't. Batts good everything has ground and when I jump the starter terminals I get nothing but sparks, no clicks it doesn't even try to start. This starter is a year old. I even jumped straight to the starter strip on the bottom bolt of the starter, nothing.
post #2 of 4 Old 09-06-2015, 08:57 AM Thread Starter
etaomicron's Avatar
Starter issue
Well I got it to crank this morning, with both bypassing the starter and using the key. I jumped the battery off to do it. What's weird is last night I had had it hooked up to another truck for 30 minutes and it made no difference. It would move real slow and click once or twice and not work anymore.
Could it be the starter binding?
I do currently have 20w50 in it but I haven't had any problems and I even turned the crank to make sure it wasn't seized
The battery is a 1100 ca interstate battery roughly a year old
And the alternator was just rebuild in april
post #3 of 4 Old 09-06-2015, 04:46 PM Thread Starter
etaomicron's Avatar
Re: Starter issue
So it's still not cranking. Another thing is I when I touched the solenoid casing, it's really hot. The starter is find it's just the solenoid. But until it wants to crank so I can get it back to my house I can't do anything. And corrosion has almost eat one side of my pos battery connector
post #4 of 4 Old 09-08-2015, 09:35 AM Thread Starter
etaomicron's Avatar
Re: Starter issue
Well imma see if I can bench test the starter today. Battery is good. I don't know if it's because I bought a reman one but next time I'll buy new
You may post new threads
You may post replies
