Smell of gas fumes after parking - S-10 Forum
post #1 of 5 Old 10-02-2014, 11:58 AM Thread Starter
4 Year Intermediate Tech
greasemonkeys10's Avatar
User is: greasemonkeys10 is offline
I drive about 26.4 miles to work and after parking a few minutes I smell slight gas fumes. Is this normal for a carb with a open element? Has a electric fuel pump with returnless system. Pressure in the fuel lines reaches as high as 10 psi with underhood temps and engine off but usually goes to 0 after the engine cools and sits a few hours. No startup problems or fuel leaks.
1985 2.8L V6 S10 completely restored with 65,000 miles on body, frame, and rear axle. Weber 38 DGES Powered SOLD
1989 Nissan D21 Z24i 8 Wire Wonder
1995 Chevy S10 ext cab 4.3 Z 40,000 Miles On Rebuild.
post #2 of 5 Old 10-02-2014, 02:19 PM Thread Starter
Re: Smell of gas fumes after parking
Alright I think I figured it out. Fuel tank vent hoses, and charcoal can are venting under the hood. Really need to get rid of that thing and vent the tank to the air cleaner with a custom barb fitting. Also need to run the float vent somewhere
post #3 of 5 Old 10-02-2014, 05:04 PM Thread Starter
Man this thing smells like a giant gas spill haha
post #4 of 5 Old 10-05-2014, 11:45 AM
HJR
HJR's Avatar
User is: HJR is offline
Sounds like you need a new canister. Don't know if these are the type, but some were designed so you just replaced the element inside.
1987 S-15 Extended Cab 4x4. 2.8L 5 Speed.
HJR is offline
post #5 of 5 Old 10-05-2014, 10:25 PM Thread Starter
Canister isn't connected to anything lol, the hoses I moved to the inner fender area.
