S10 2.8 leaked oil cost to rebuild ? - S-10 Forum
post #1 of 10 Old 05-17-2015, 12:02 AM Thread Starter
User is: 86 S10 tahoe is offline
Sad story. Just bought a low milage 1986 S10 blazer tahoe.
31K miles. Been driving it 10 days. Backing into a friends
driveway i see a trail of oil. Looked like the idiot light sender
was leaking alot. After replacing both that and the guage sender
because i thought it was that one at first The engine sounds noisy in
the bottom end. I did drain and refill after replacing the senders.
As i was dumping the drain pan i noticed metal flakes. I will drain it
again to see whats in the pan his time. Also no leaks after all this.
I am not sure its worth spending $2000 + . There are pictures of it
in the gallery.
post #2 of 10 Old 05-18-2015, 10:09 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Re: S10 2.8 leaked oil cost to rebuild ?
Bottom end rattle?
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #3 of 10 Old 05-20-2015, 12:49 PM
6th Incarnation
FoaRyan's Avatar
User is: FoaRyan is offline
Yikes, same thing happened to my 3.4 last year, trail of oil and everything. Oil pressure dropped to 0 when I let off the gas in traffic. Fortunately I pulled over and killed the engine before it did some serious damage. It was my gauge sender as well.
If you can rebuild it yourself I'd say go for it, or find another block and swap. Just curious do you know how much oil was left in there before you drained/refilled?
[ 2002 ZQ8 S10 ("Time Vortec" V8, once accelerated really fast | 1995 3.4 Camaro | @FoaRyan on Twitter
FoaRyan is offline
post #4 of 10 Old 05-21-2015, 12:08 AM Thread Starter
I wish i would have measured it. Guessing 2 quarts. Now i am
not sure the new guage sender is working right. At startup it
goes to about 50 psi and stays there even after shutting off the key.
Turning the key to on makes it return to zero. I had a quote
Of $2000 for a complete rebuild not including removal and install
Of course. This blazer is really nice except for the silver paint wanting
To peel along the bottom.
post #5 of 10 Old 06-10-2015, 01:33 PM
lowmileage's Avatar
User is: lowmileage is offline
Aren't 3.4 swap replacements around $1500. That's what I'd do if yoy have the 2.8
1985 S-10 2.8ltr. Radio delete, 2WD positraction, gauges, halogen lights and off-road tire option (standard tread front, off-terrain tire rear - now running 4 Winterforce tires). Delco gas shocks. Dad was original owner. 95K miles now. Single stage urethene repaint was the summer of 2011 project (now faded, don't buy Eastwood's paint).
post #6 of 10 Old 06-10-2015, 01:40 PM
lowmileage's Avatar
Went to look it up. Are these 3.4 crates discontinued?
post #7 of 10 Old 06-11-2015, 09:46 AM
4 Year Intermediate Tech
greasemonkeys10's Avatar
User is: greasemonkeys10 is offline
3.4 crates have been discontinued, only option is to rebuild or find a 3.4 out of a camaro or any other rwd.
post #8 of 10 Old 06-11-2015, 12:28 PM
overthinker extraordinar
jcricket's Avatar
User is: jcricket is offline
I know this is not exact, but contact them. They might have your engine in stock at the same price. They had mine. It was about $800 shipped to me. Hope it helps.
http://www.ebay.com/itm/New-Remanufa...c48c66&vxp=mtr
jcricket is offline
post #9 of 10 Old 06-23-2015, 05:38 PM
jcricket's Avatar
try this
http://www.ebay.com/itm/New-Reman-85...6db257&vxp=mtr
jcricket is offline
post #10 of 10 Old 06-26-2015, 11:51 AM
Awww..you ain't got shit!
jimmykicker's Avatar
That's why I bought mine. Because I knew they were going to be discontinued. I bet you can find one if you still look though. But just buy a rebuilt one or grab one from a junkyard and either rebuild it yourself or get someone to build it.
I had to cut my nut in half .
