Rochester varajet ii - S-10 Forum
post #1 of 10 Old 01-16-2016, 10:51 PM Thread Starter
User is: TheSimpleStoner is offline
I think it's my carb when I press gas pedal fast theres a pop hiss sound then It just dies. Any idea what could be happening
post #2 of 10 Old 01-19-2016, 02:57 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Re: Rochester varajet ii
Not too great a description. Does it start up afterwards?
Maybe a little more detail would help.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #3 of 10 Old 01-22-2016, 12:18 AM Thread Starter
Yeah it starts back up but it idles rough even before you press the gas to fast and a pops and dies. The gas pedal is also hard to to move not like to hard just abnormally hard to press
post #4 of 10 Old 01-22-2016, 12:18 AM Thread Starter
But the throttle on the carb isn't hard to move
post #5 of 10 Old 01-23-2016, 02:01 PM
odat's Avatar
User is: odat is offline
Just a thot here - My 84 S10 blazer with 2.8 was doing that when the timing chain was stretched - you could try popping your dist cap off and rotate the crank pulley back and forth and see if there is a lot of lag in the dist button movement to rule out a bad chain
odat is offline
post #6 of 10 Old 01-25-2016, 05:17 PM Thread Starter
I'll try it
post #7 of 10 Old 01-27-2016, 01:25 AM
Maybe later.
tytotheler92's Avatar
My Rochester had a very stiff throttle. Have you checked general timing? A Weber carb fixes everything....
If you decide to take on the timing chain, while you have the timing chain off do the upper intake and while you're at it take a look at the cam and make sure it looks ok.
1988 S-15 - 5.5/6 drop
1985 S10 Blazer 4WD
1998 Blazer ZR2 5 Speed!
post #8 of 10 Old 01-27-2016, 03:03 AM Thread Starter
I haven't checked much I'm not super mechanically inclined
post #9 of 10 Old 01-27-2016, 09:00 AM
Boozebag
Mad Max's Avatar
If you are interested... you will become mechanically inclined.
There is so much more accessible info than there ever used to be.
You could rebuild your engine just by watching YouTube...
S10 addiction:
Mad Max is offline
post #10 of 10 Old 02-07-2016, 08:25 PM
oldS10srule
fellchase's Avatar
User is: fellchase is offline
I have 85 S10 Blazer 2.8 it Varajet II CARB it had really bad bog I changed EGR Fixed it.
