Max I live in columbus GA which is about an hour outside of atlanta. Ok so if I use my intake and all my other stuff including my water pump it will work
Put everything from your old motor on the new one. Intake, front cover, water pump, oil pan etc. The only thing I'd worry about it the oil pan. Just make sure it's the same at the rear. It probably is, but there has been some question about a couple of different model year compatibilities.
Ok so we found a motor in a yard and it still ran Tore it down and the bearings are still good no sign of scratching but the crank its different its bigger like its heavier duty any clue why?
The motor is in the machine shop right now the block is getting bored the head is getting milled and the crank is getting polished I will measure it when it gets back. If it is the 3.31 would that mean someone put it in there
Related Threads
S-10 Forum
8.8M posts
183.1K members
Since 2001
