question on this plug in connector - S-10 Forum
post #1 of 5 Old 06-21-2015, 11:36 AM Thread Starter
lowmileage's Avatar
User is: lowmileage is offline
Looks like the top hose connection to this connector is a permanent stay. Can I eliminate the connector and run 4 individual hoses to the switch that is on the intake OR does the connector perform a function other than a convince.
1985 S-10 2.8ltr. Radio delete, 2WD positraction, gauges, halogen lights and off-road tire option (standard tread front, off-terrain tire rear - now running 4 Winterforce tires). Delco gas shocks. Dad was original owner. 95K miles now. Single stage urethene repaint was the summer of 2011 project (now faded, don't buy Eastwood's paint).
post #2 of 5 Old 06-22-2015, 10:23 AM
4 Year Intermediate Tech
greasemonkeys10's Avatar
User is: greasemonkeys10 is offline
That is a thermal vacuum switch, at a certain temp a valve inside will divert vacuum to other sources such as egr, e cell. Honestly i got rid of it, finding a 4 tube is absolutly impossible. You can leave the valve still installed but kick the lines out.
post #3 of 5 Old 06-22-2015, 10:24 AM
mainly a emissions system part.
post #4 of 5 Old 06-22-2015, 01:41 PM Thread Starter
lowmileage's Avatar
Re: question on this plug in connector
Thanks Grease for rhe reply back. I ended up running direct individual lines to the switch FWIW.
post #5 of 5 Old 06-23-2015, 10:21 PM
overthinker extraordinar
jcricket's Avatar
User is: jcricket is offline
that is what I did. It made the emission Nazis happy too.
jcricket is offline
