perofrmance mods question - S-10 Forum
post #1 of 16 Old 09-14-2014, 08:08 PM Thread Starter
Pop A Lockin and droppin
User is: Chia is offline
So Im converting my 2.8 fi in to a 2.8 carbed. Long story short wiring in the truck is so ****ed dont wanna mess with rebuilding it. So question i have. I am doing the following mods
Edelebrock Cam
Edelbrock performer manifold
Electric fan swap
custom exhaust
headers of some type
Roller cam chain.
What else can i do. Is it worth buying one of the high end dizzys or go with a factory one one for the carb. Also msd? wires plugs. Jet underdrive pulleys? Not trying to make huge numbers but would like something that can move out of its way. And i am only using a stock 2b carb if that helps.
Scott "Chia" Holland
Chia is offline
post #2 of 16 Old 09-15-2014, 09:10 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Re: perofrmance mods question
Sounds cool to me... except for the choice of carb.
I don't know what your budget is, but a healthy cam will require a larger carb just so the engine will idle properly. The stock carbs on these trucks run way too lean, and it is not easy to re-jet them.
If you install a big cam. the Weber 38/38 outlaw carb will work well, the 32/36 will be too small, or you can run a Holley 350 CFM 2 barrel with an adapter also.
As Greasemonkeys can tell you, make sure you break in the cam correctly - according to manufacturer's recommendations. I would also run an electric fuel pump. This will elimnate the possibilty of wearing out the cam lobe for the pump.
Do you have a cam in mind? RV type? Performance type?
I installed a Mallory dizzy in the Voodoo truck, it offers faster advance than the stocker. You can run a non ECU dizzy (pre 86) and it will work fine. The Mallory units are NOT cheap. I think I paid about $325 for mine. I also run a Hyfire 7 box, but I don't think it is neccessary for a street truck.
Post pics when you do the job.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #3 of 16 Old 09-15-2014, 04:55 PM Thread Starter
this is the cam I have. http://www.edelbrock.com/automotive/...3790&submit=go Do u have a link for that holley carb and adapter. And I am running no ecu on this truck. Whol wiriing harness is coming out and being replaced by a painless performance kit.
Chia is offline
post #4 of 16 Old 09-15-2014, 05:02 PM Thread Starter
https://www.holley.com/products/fuel...s/parts/0-7448 this one. where do i get the adapter
Chia is offline
post #5 of 16 Old 09-15-2014, 06:18 PM Thread Starter
and should i use a fpr. I am just using my stock tank with electric pump.
Chia is offline
post #6 of 16 Old 09-16-2014, 10:11 AM
4 Year Intermediate Tech
greasemonkeys10's Avatar
User is: greasemonkeys10 is offline
Yes break in the cam or you will be spending another 400$ just like I did. 19,000 miles down the road. Shine a flashlight down the cam bore and inspect the bearings. Replace if peeling or deeply pitted/burned. Usually you can tell by the smell.
1985 2.8L V6 S10 completely restored with 65,000 miles on body, frame, and rear axle. Weber 38 DGES Powered SOLD
1989 Nissan D21 Z24i 8 Wire Wonder
1995 Chevy S10 ext cab 4.3 Z 40,000 Miles On Rebuild.
post #7 of 16 Old 09-16-2014, 10:25 AM
I was suggested this pump by a member on the forum. Works great and is super quiet. I've got a weber inline fpr and Holley guage for fuel pressure. I highly recommend the Holley fuel pump wiring kit. Comes with all wires needed and a relay. Had it wired in under a hour.
http://m.ebay.com/itm/360717636130
post #8 of 16 Old 09-17-2014, 09:43 AM
Boozebag
Mad Max's Avatar
I recommended this carb also, but thinking about it... You will suffer with poor fuel mileage. It is jetted more for a V8 that sucks gas.
I have the same 350 CFM carb on the Moo truck... (90 Ford Ranger with a 5.0 litre in it - and yes, it is painted like a cow)
The truck SUCKS fuel. Stock 5.0 with dual exhaust.
I think you would do better with the Weber 38/38 like Greasemonkeys has, or a 390 CFM Holley 4 barrel.
The 2 barrel 350 CFM is giving the engine a large dose of juice all the time, while the 38/38 or 390 has much smaller venturis.
S10 addiction:
Mad Max is offline
post #9 of 16 Old 09-17-2014, 09:52 AM
Boozebag
Mad Max's Avatar
Sorry for the 2x post...
Read this:
https://www.s10forum.com/forum/f106/2...e-mods-520930/
S10 addiction:
Mad Max is offline
post #10 of 16 Old 09-17-2014, 11:26 AM Thread Starter
ok gonna do the weber carb then.
I already have the manifold for the 2 barrel dont wanna spend more money to get the 4 barrel adapter.
Chia is offline
post #11 of 16 Old 09-17-2014, 12:21 PM
Boozebag
Mad Max's Avatar
Check out Ebay Dood. You may find a used one or something affordable.
Better jump on this... you only have 2 hours.
http://www.ebay.com/itm/Weber-38-DGA...r#ht_67wt_1123
S10 addiction:
Mad Max is offline
post #12 of 16 Old 09-17-2014, 02:30 PM
Also final note on the weber. Watch out for faked carbs. A genuine weber will have the name cast into the accelerator pump housing and the flat bowl. I paid about 347$ for mine new. Fakes will have a weber sticker. And no casting marks.
post #13 of 16 Old 09-18-2014, 08:25 AM
Boozebag
Mad Max's Avatar
WOW... Chinese knock offs... what next?
S10 addiction:
Mad Max is offline
post #14 of 16 Old 09-18-2014, 09:21 AM
I know it's bad
post #15 of 16 Old 09-18-2014, 09:25 AM
This will help you
http://genuineweber.blogspot.com/200...nd-up.html?m=1
Mine had "weber" on the accelerator pump "made in Spain" on the float bowl and a white choke housing. Hope this helps.
post #16 of 16 Old 10-13-2014, 01:33 AM Thread Starter
keep this up top
Chia is offline
