New 2.8 issue - S-10 Forum
post #1 of 6 Old 07-16-2015, 02:37 PM Thread Starter
S10tahoe28's Avatar
User is: S10tahoe28 is offline
New 2.8 issue
Alright I'm having another issue. And Id like opinions before I check it. I'm getting a moderate vibration when I'm on throttle. If I release the pedal the vibration dies down and goes away. It's because of that I don't think that it's a suspension issue. I can feel it all through the truck but I do hear a rough noise coming from the rear.
post #2 of 6 Old 07-16-2015, 03:57 PM
Awww..you ain't got shit!
jimmykicker's Avatar
Re: New 2.8 issue
I had something similar on my x-cab. Look at the center bearing rubber. I bet it's falling apart. Mine turned out to be mostly that but the rear end was also leaking and dying. I replaced it and it was better. Also I wound up rebuilding the transmission not much later. The vibration stopped completely when I rebuilt it. I was weird because all of it came from different sources working together. Check that bearing. A suspension shop can fix it. New u joints and all...bout $60 10 years ago. Oh yeah...check the rear transmission mount. I did that one too. All this happened when the truck had about 250k miles.
I had to cut my nut in half .
post #3 of 6 Old 07-16-2015, 04:27 PM Thread Starter
S10tahoe28's Avatar
Re: New 2.8 issue
I've got new u joints but I haven't installed them yet, and center bearing is 2000 miles new. But I'll check that other stuff as well, I have noticed a fluid leak out of the joke joint seal on the rear axle
post #4 of 6 Old 07-16-2015, 06:53 PM Thread Starter
S10tahoe28's Avatar
Re: New 2.8 issue
Well it's drivetrain. I just heard a click when I put it in gear.
post #5 of 6 Old 07-17-2015, 03:00 PM Thread Starter
S10tahoe28's Avatar
Re: New 2.8 issue
I found out what it was. Going down the road slight vibration turned into major vibration. Pulled over and I've got a broken ujoint. Fml
post #6 of 6 Old 07-17-2015, 08:22 PM Thread Starter
S10tahoe28's Avatar
Re: New 2.8 issue
That's how I pulled it out. One of the u joint holes for the caps got messed up imma try and Dremel it out and save it for now
