Letís Play - What the Heck is This??? - S-10 Forum
 5Likes
  • 2 Post By ToddS15
  • 2 Post By oldeerslayer
  • 1 Post By dime-dozen
post #1 of 15 Old 06-26-2019, 11:04 PM Thread Starter
Yowakawaka's Avatar
User is: Yowakawaka is offline
What’s up s10 people
Anyone know what this is? It’s making a buzzing sound so I want to replace it. I’ve tried parts stores and even rock auto and no one knows what it is.
It’s in side the air box. It has two prongs that go through the air box and connects to two tires. One of the wires goes to the large tube that runs off the air box. The other wire goes to this “thing” that connects to the air box. There’s photos of this attached.
If I had to guess, I’d say it has to do with emissions and that’s why no one knows what it is
Anyone?!?
ID:	317765   Click image for larger version
ID:	317767   Click image for larger version
Zip Em Up and Zip Em Out....
post #2 of 15 Old 06-26-2019, 11:09 PM Thread Starter
Yowakawaka's Avatar
One photo is of the two prongs with the wires connected. The wires connected to the round thing on the air intake tube is the first wire I was talking about. The one with the orange thing going through the air box is where the second wire goes.
ID:	317771   Click image for larger version
ID:	317773   Click image for larger version
post #3 of 15 Old 06-27-2019, 12:37 AM
Been there Done it
oldeerslayer's Avatar
Re: Letís Play - What the Heck is This???
Those appear to be vacuum hoses, not wires. I'm pretty sure that you are correct about it being an old emission gadget of some kind. I suspect it is an early vacuum method to control something based on incoming air temperature. I think it is called a TVS (Thermal Vacuum Switch). Seen a number of vehicle where the holes in the air cleaner was all that remained.
You might be able to find a replacement in a JY. I believe they were on a lot of GM engines in the early 80's.
Have you looked it over with a magnifying glass for a possible part number? Not that anyone makes them today.
post #4 of 15 Old 06-27-2019, 01:12 PM Thread Starter
Yowakawaka's Avatar
@oldeerslayer the thermo vacuum switch is the thing with the orange tip. At least that’s what it shows on rock auto.
I’ll look into a junkyard and for a part number.
Thanks
Anyone else have an idea
post #5 of 15 Old 06-27-2019, 06:10 PM
User is: ToddS15 is offline
It it's the control for the vacuum diaphragm that opens and closes the hot air coming off the exhaust manifold. Those are vacuum lines to it.
goes2fast and TomA like this.
ToddS15 is offline
post #6 of 15 Old 06-27-2019, 11:48 PM
Been there Done it
So basically a hot air intake until it warms up?
post #7 of 15 Old 06-28-2019, 12:45 AM
time to get cereal
manbearpig's Avatar
User is: manbearpig is online now
It's called a stove pipe. Pretty much all early emissions cars had them. Mostly carbs and TBI. MPFI cars usually had coolant ran through the throttle body.
There's no emissions diagram under the hood?
post #8 of 15 Old 06-28-2019, 06:40 AM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
Itís a Thermac Air Filter sensor.
Funny,because I still remembered thermac sensor for high school auto tech..10 second google found this.
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
post #9 of 15 Old 06-28-2019, 08:04 AM
Been there Done it
In my high school auto shop we learned how to change the oil in the air cleaner.
You'll also notice in the picture the removable cartridge oil filter and the resistor for the 12 volt coil.
Cool old power steering pump also but it cost a fortune to replace the generator because of it.
About $25 more, which was 3 days pay. In today's money that's like $350.
oldgold1985 and TomA like this.
post #10 of 15 Old 06-28-2019, 10:20 AM
New Member
User is: dime-dozen is online now
not that old
it has an electric wiper motor vs vacuum
superj likes this.
post #11 of 15 Old 06-28-2019, 12:43 PM
Old Fart
goes2fast's Avatar
User is: goes2fast is offline
Originally Posted by dime-dozen View Post
not that old
That is a 1955 Chevy 265 the oil filter was optional and if you look close the optional electric wiper motor has the switch mounted on it and was operated by a cable connected to the knob on the dash. I know this because I have owned several Tri5s over the years. My first 55 Belair had the vacuum wipes that stopped whenever you went up a hill or mashed on the gas.
Too Much Horsepower is ALMOST ENOUGH!
"I have a car-sickness. I need to be checked into the HENRY Ford Clinic." -Tim "The Tool Man" Taylor
post #12 of 15 Old 06-28-2019, 10:13 PM Thread Starter
Yowakawaka's Avatar
I knew someone here would know what it is. I can only find one on eBay for forty bucks and it looks used. I think I’m gonna have to just fix it or try to find one at the junkyard. It buzzes super loud when I connect the vacuum lines. I’m sure it’s supposed to make some noise but damn!!! Any ideas?!?
@manbearpig this is the only sticker under the hood. That wire diagram might as well be in Chinese. I have to watch the a YouTube video on how to read it right and know what’s what.
ID:	317811   Click image for larger version
ID:	317813   Click image for larger version
post #13 of 15 Old 06-28-2019, 10:42 PM
time to get cereal
manbearpig's Avatar
Your air cleaner is in the top right of that diagram. The diaphragm on the air cleaner snorkel is for the stove pipe (the metal foil looking pipe coming from the exhaust manifold.) The piece you took a picture of is labeled Temp Sensor, and the SEC VAC BRK TVS is the thing on the back with all of the vacuum lines coming out.
post #14 of 15 Old 06-28-2019, 11:42 PM
Been there Done it
What he said.
post #15 of 15 Old 07-02-2019, 06:01 PM
Awww..you ain't got shit!
jimmykicker's Avatar
User is: jimmykicker is online now
Yuck...glad my truck is fuel injected now. I hated all those ****** hoses!
I had to cut my nut in half .
You may post new threads
You may post replies
