I need a favor - S-10 Forum
post #1 of 5 Old 11-05-2015, 11:42 AM Thread Starter
User is: CWP_MS3 is offline
I need a favor
I have an 83 s10 and I just put the heater core in. I took pictures of the way the switches were wired, and the way the cables are connected, but I didn't get a good enough picture apparently to rewire it 100% correct. I need to know which color wires belong on which prongs.
Is there any chance one of you fine people can pull the heat/ac controls out enough to snap a good picture? Especially the AC switch in the back of the control head that actually turns the compressor on (not the slide knob). I would appreciate it. I've got the car back together and this is all I need to finish it up.
If you've never done it, its like 10 minutes to disassemble it and put it back together. lol Just pull the dash panels with a torx and then, I believe its 4 small 7/32 screws, or phillips.
Thanks.
CWP_MS3 is offline
post #2 of 5 Old 11-05-2015, 12:07 PM Thread Starter
Re: I need a favor
It looks like this turd. I'm not sure what years that belongs to.
CWP_MS3 is offline
post #3 of 5 Old 11-06-2015, 10:21 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Re: I need a favor
The wires to this control are not separate. They are in a plug that plugs directly to the fan control switch.
Another point - this looks like a non a/c
panel. IIRC, this is cable controlled with no vacuum.
Take a pic of the backside of this unit. It will be more helpful.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #4 of 5 Old 11-19-2015, 06:33 PM
blazed2's Avatar
User is: blazed2 is offline
Re: I need a favor
thats right, only cable , no vacum hoses.
and the wires are not separate theres a plug.
88 s10 blazer, 2door with 4x4 frame ( 5"/5" drop)
modded 2.8 , 700r4 .
doing black on black on black
phantom grill, side marker lights, tinted tail lights
and a lot of other mods.
7,000 rms audio system ( nasty )
"" old school build ""
92 s10 blazer 2dr,2wd,4.3
no rust. bagging it. and switching over all the stuff from 88.
doing all 2nd gen. blazer brakes.
blazed2 is offline
post #5 of 5 Old 11-21-2015, 09:11 AM
Boozebag
Mad Max's Avatar
Re: I need a favor
This I for an '82 to '85 S10. I'm at home, I'll look and see if I have one.
S10 addiction:
Mad Max is offline
You may post new threads
You may post replies
