Help Identifying a Sensor - S-10 Forum
post #1 of 12 Old 11-21-2015, 08:15 PM Thread Starter
little_yellow_s10's Avatar
User is: little_yellow_s10 is offline
Question Help Identifying a Sensor
Hi there, I have an '87 S10 2.8 v6, and am struggling to identify a sensor/sending unit that has deteriorated. Any help would be greatly appreciated.
post #2 of 12 Old 11-21-2015, 09:31 PM
User is: 4pt9fiero is offline
Re: Help Identifying a Sensor
That should be your coolant temp sensor for your temperature guage.
1992 S10 Extended Cab, 2.8, 5 speed - paid $50 for it 11 years ago - still running strong (as strong as a 2.8 can)
1995 Blazer, 4.3, Auto, 4x4 - Sold
1987 Porsche 944
1981 Porsche 924 Turbo
post #3 of 12 Old 11-21-2015, 09:43 PM Thread Starter
I thought that was the sensor next to the water neck on the intake. I just replaced that one.
post #4 of 12 Old 11-21-2015, 10:59 PM
User is: The_Raven is offline
The one next to the thermostat is for the ECM.
The daily driver: 2005 Blazer
Tha other Toy: 1923 T-Bucket
post #5 of 12 Old 11-22-2015, 10:18 AM Thread Starter
K so are they both identical sensors and one is temperature for the ecm and one is for the temperature gauge?
post #6 of 12 Old 11-22-2015, 10:28 AM Thread Starter
My Haynes manual refers to the thermostat location as the "engine coolant temperature sensor" and the cyclinder head location "coolant temperature sensor". Theres only a coolant temperature sensor available online so I'm assuming they're the same piece in both locations?
post #7 of 12 Old 11-22-2015, 02:13 PM
blazed2's Avatar
User is: blazed2 is offline
yes, same thing.
same part.
88 s10 blazer, 2door with 4x4 frame ( 5"/5" drop)
modded 2.8 , 700r4 .
doing black on black on black
phantom grill, side marker lights, tinted tail lights
and a lot of other mods.
7,000 rms audio system ( nasty )
"" old school build ""
92 s10 blazer 2dr,2wd,4.3
no rust. bagging it. and switching over all the stuff from 88.
doing all 2nd gen. blazer brakes.
blazed2 is offline
post #8 of 12 Old 11-22-2015, 03:28 PM
No, not the same part. That should be blatantly obvious, just by looking at them.
post #9 of 12 Old 11-25-2015, 12:17 PM
blazed2's Avatar
there the same on my truck..................
blazed2 is offline
post #10 of 12 Old 12-01-2015, 10:02 AM
etaomicron's Avatar
User is: etaomicron is offline
The connectors are different. You could probably cut and splice the new connect on and use the same style for both.
post #11 of 12 Old 12-08-2015, 11:00 AM Thread Starter
Yeah you're right, the connector tops are just different. The one on the intake seems to be called coolant temperature sensor, and the one on the head a coolant temperature sender. Rockauto has both. Mystery solved thanks guys.
post #12 of 12 Old 12-26-2015, 09:26 PM
User is: sparkybuoy is offline
RAVEN is correct - they are NOT the same...not just the connection is different but internally the way the pass/alter the signal is different
Pay close attention...one is WITH GAUGE and one is WITHOUT (light)
http://www.oreillyauto.com/site/c/de...1392&ppt=C0039
You may post new threads
You may post replies
