S-10 Forum
S-10 Forum (https://www.s10forum.com/forum/forum.php)
-   60v6 Forum (2.8/3.4) (https://www.s10forum.com/forum/60v6-forum-2-8-3-4/)
-   -   Help Identifying a Sensor (https://www.s10forum.com/forum/f106/help-identifying-a-sensor-734841/)
little_yellow_s10 11-21-2015 08:15 PM
Hi there, I have an '87 S10 2.8 v6, and am struggling to identify a sensor/sending unit that has deteriorated. Any help would be greatly appreciated.
http://i66.tinypic.com/2cr3ngp.jpg
4pt9fiero 11-21-2015 09:31 PM
Re: Help Identifying a Sensor
That should be your coolant temp sensor for your temperature guage.
little_yellow_s10 11-21-2015 09:43 PM
I thought that was the sensor next to the water neck on the intake. I just replaced that one.
The_Raven 11-21-2015 10:59 PM
The one next to the thermostat is for the ECM.
little_yellow_s10 11-22-2015 10:18 AM
K so are they both identical sensors and one is temperature for the ecm and one is for the temperature gauge?
little_yellow_s10 11-22-2015 10:28 AM
My Haynes manual refers to the thermostat location as the "engine coolant temperature sensor" and the cyclinder head location "coolant temperature sensor". Theres only a coolant temperature sensor available online so I'm assuming they're the same piece in both locations?
blazed2 11-22-2015 02:13 PM
yes, same thing.
same part.
The_Raven 11-22-2015 03:28 PM
No, not the same part. That should be blatantly obvious, just by looking at them.
blazed2 11-25-2015 12:17 PM
there the same on my truck..................
etaomicron 12-01-2015 10:02 AM
The connectors are different. You could probably cut and splice the new connect on and use the same style for both.
little_yellow_s10 12-08-2015 11:00 AM
Yeah you're right, the connector tops are just different. The one on the intake seems to be called coolant temperature sensor, and the one on the head a coolant temperature sender. Rockauto has both. Mystery solved thanks guys.
sparkybuoy 12-26-2015 09:26 PM
RAVEN is correct - they are NOT the same...not just the connection is different but internally the way the pass/alter the signal is different
Pay close attention...one is WITH GAUGE and one is WITHOUT (light)
http://www.oreillyauto.com/site/c/de...1392&ppt=C0039
vBulletin Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright 2016 VerticalScope Inc.
