HELP HELP HELP!!!! EGR TVS needed, how do I fix/bypass - S-10 Forum
post #1 of 7 Old 10-15-2014, 09:11 PM Thread Starter
overthinker extraordinar
jcricket's Avatar
User is: jcricket is offline
Hey Folks,
I took my 1985 2.8L s10 to firestone to get the A/C compressor charged. They screwed my truck, bad. Behind the compressor on the top of the intake manifold, right next to the thermostat is a 4 port vacuum control switch. The knocked the tubing off and they busted one of the plastic ports. My truck will not pass emissions without this switch. It controls the EGR valve.
So does anyone know where to get a four ported EGR TVS. I checked with the chevy dealers. The part is no longer made. I did find a 5 ported version made for jeeps, but I have no idea which ports do what. I think I am going to pull the switch and heat it with boiling water. Then I can test and see what happens.
Anyone have any ideas? I have checked all the CL ads for parts cars - nada. I will call some salvage yards and see if I can find one. This part would only be on a 1985 or older vehicle. Newer ones used fuel injection.
daaaaammmmmm firestone................
jcricket is offline
post #2 of 7 Old 10-15-2014, 09:40 PM Thread Starter
jcricket's Avatar
Re: HELP HELP HELP!!!! EGR TVS needed, how do I fix/bypass
I found one on the bay, dang tough to find
http://www.ebay.com/itm/TOMCO-13216-...50952a&vxp=mtr
if anyone else needs one
Airtex 7P1055 Ported Vacuum Switch
or
TOMCO 13216 PORTED VACUUM SWITCH
this will hopefully be of use to some other poor soul
jcricket is offline
post #3 of 7 Old 10-15-2014, 10:13 PM
4 Year Intermediate Tech
greasemonkeys10's Avatar
User is: greasemonkeys10 is offline
I was about to say I've got a brand new one in the box here
1985 2.8L V6 S10 completely restored with 65,000 miles on body, frame, and rear axle. Weber 38 DGES Powered SOLD
1989 Nissan D21 Z24i 8 Wire Wonder
1995 Chevy S10 ext cab 4.3 Z 40,000 Miles On Rebuild.
post #4 of 7 Old 10-15-2014, 10:47 PM Thread Starter
jcricket's Avatar
Well thanks just the same!!!
I noticed I am only at about 12" vacuum at idle. Time to start looking for a vacuum leak. I found this break when I was looking. I capped it off and it didn't help that problem at all.
I think I if find all of the vacuum ports that have to do with pollution and cap them, then check vacuum, I will be able to see better how my motor is doing.
jcricket is offline
post #5 of 7 Old 10-16-2014, 11:04 PM
12" hg at idle is very low for these. With the stock cam it should run at 17-18" hg at 800 rpms hot idle in park or neutral. Remembering how many lines I had running off the varajet carb you can bet you have some vacuum leaks. You are testing from the brake booster line correct?
post #6 of 7 Old 10-16-2014, 11:07 PM
You may need to advance the dizzy a few degrees. Altitude also plays a part in hg. For every 1000 ft above sea level subtract 1" hg.
post #7 of 7 Old 10-17-2014, 07:38 AM Thread Starter
jcricket's Avatar
No I was testing on a different line. I will try the brake line and post back. I have my timing set at about 13-14 btdc. I should be around 15, maybe even 16.
I have replace all of he lines that came off the carburetor. And yeah, they were completely shot and leaking terribly.
jcricket is offline
