Harmonic Balancer Bolt Threads Oops - S-10 Forum
post #1 of 4 Old 08-26-2015, 08:02 PM Thread Starter
oldS10srule
fellchase's Avatar
User is: fellchase is offline
I stripped my threads on 85 Blazer 60v6 crank where pulley bolt goes in. Threads in crank ruined. oops. I was using bolt to run harmonic balancer up had my air impact the bolt is M12x1.5 metric fine thread. Would have been okay one time but I pulled HB three or four times long story. Got a new bolt. Anyway do you guys have any experience repairing these crank threads with HeliCoil? Is it scary? Thanks. Love my 60v6.
Chase in Alabama
post #2 of 4 Old 08-28-2015, 02:37 PM
Awww..you ain't got shit!
jimmykicker's Avatar
Re: Harmonic Balancer Bolt Threads Oops
Would it not be easier to retap it a larger size and use a larger bolt?
I had to cut my nut in half .
post #3 of 4 Old 08-31-2015, 10:33 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Ooofff... Bad news Dood.
Two options... a longer bolt by 1/2" or ^^ what JK said.
Only problem here... the bolt is a specialty fastener. You will have to go to a fastener supply like Fastenall or similar to find what you need.
How bad did you rip the threads out? Completely?
I have never seen a Heli-Coil that size, but that doesn't mean they don't make one.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #4 of 4 Old 09-01-2015, 01:53 PM
overthinker extraordinar
jcricket's Avatar
User is: jcricket is offline
If it were me, I would try to clean up the threads and see if you could get the balancer on one last time. I would then Loctite he bolt in place after I seated eh HB. If that didn't work, then I would sit back and drink a cold one or two and think hard on what to do next.
Definitely get a longer bolt to at least start the balancer with. I think an extra 10mm longer would be plenty good. I would also bet it is only the first 5mm(ish) that is wrecked. So the longer bolt would get you into good threads and then allow it to seat. Obviously, you would need to put the original bolt back in to completely seat the HB.
Good luck
jcricket is offline
