Found the leak! 2.8 Oil Filter housing O-Ring - S-10 Forum
post #1 of 9 Old 09-11-2015, 12:35 AM Thread Starter
Maybe later.
tytotheler92's Avatar
Also, I found the gasket.
http://www.oreillyauto.com/site/c/de...2295&ppt=C0026
However, it would seem that it's not leaking from the gasket really, (although if I'm going to remove the motor mount I might as well do the housing gasket.) but it seems to be leaking from the o-ring around the hold down bolt.
What kind of o-ring would work as a replacement?
1988 S-15 - 5.5/6 drop
1985 S10 Blazer 4WD
1998 Blazer ZR2 5 Speed!
post #2 of 9 Old 09-11-2015, 08:25 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Re: Found the leak! 2.8 Oil Filter housing O-Ring
I'm pretty sure it's not an o ring. I think it is a flat copper washer. It's been a while since I replaced mine, but that's what my memory thinks...
My 3.4 had the typical oil filter housing leak, it was a gusher. I bought the Fel Pro replacement - they seem to be the best quality.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #3 of 9 Old 09-11-2015, 04:05 PM Thread Starter
Maybe later.
Alright, yeah I looked at it again after I posted this and its rubber, BUT its also metal. I have a feeling an oil drain plug washer with the rubber center will work. Or I'll just use a copper crush washer.
1985 S10 Blazer 4WD
post #4 of 9 Old 09-13-2015, 11:09 PM Thread Starter
Maybe later.
It was an o-ring!
I got an o-ring from a $1 universal dorman kit. Worked great.
1985 S10 Blazer 4WD
post #5 of 9 Old 09-23-2015, 03:40 PM
Boozebag
Mad Max's Avatar
Yep, my memory is soggy.
Must be the beer.
I am quitting that stuff.
O ring baby.
S10 addiction:
Mad Max is offline
post #6 of 9 Old 09-23-2015, 04:33 PM Thread Starter
Maybe later.
Hahaha, no problem.
As more and more of these trucks come out of the wood work, it's good information to have on the forum anyways.
1985 S10 Blazer 4WD
post #7 of 9 Old 09-25-2015, 05:09 PM
Awww..you ain't got shit!
jimmykicker's Avatar
That thing is a pain in the ass to get to is it not? I think I remember taking the exhaust pipe off on that side, removing the mount and jacking the motor up? The bolt wouldn't clear the mount bracket!!
1984 xcab s-10 3.4L GM crate engine 91 S10 TBI swap w bored intake, Edelbrock headers. 2" Rough Country Lift. Flowmaster, shift kit, e-fan.
I had to cut my nut in half .
post #8 of 9 Old 09-28-2015, 02:16 AM Thread Starter
Maybe later.
You have to remove the motor mount. and jack the engine up. It's a ****ing pain. Better then the 4.3s though and their damn oil cooler line issues.
As I tell people though - if you want something with tons of room to work on get a full size. lol.
1985 S10 Blazer 4WD
post #9 of 9 Old 09-28-2015, 12:27 PM
Yep...I also got a 93 Ford F-150 that I affectionately call Earl. Earl has the inline 300 inline 6 which incidentally may be the most bulletproof engine ever made. Easy breezy to turn wrenches on for sure. The 2.8 is actually very easy to work on too...Just a few a-hole repairs. That being one of them. The exhaust gaskets suck too.
