Every oil seal and gasket bad - S-10 Forum
post #1 of 13 Old 12-29-2014, 08:25 PM Thread Starter
LJSilvers
LJSilvers's Avatar
User is: LJSilvers is offline
Send a message via AIM to LJSilvers Send a message via Yahoo to LJSilvers
2 days after I bought my 84 s10 it started to puke oil big time. I parked it until I got to have it looked at to day. Its not just the timing cover as I thought. It had sat quite a while before I bought it. It was slightly oily when I looked at it, but no drips or really oily spots on it. Well, that's what 30 years, low miles and storage does. Gasket n seal kit comes in next week.
Telling people what I think when they deserve it.
90 GMC Jimmy Gypsy RIP
84 Chevy S10 Extra Cab 5/3 Drop
post #2 of 13 Old 12-30-2014, 08:11 AM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Re: Every oil seal and gasket bad
Lots of blow by past the rings can push oil past the seals. You say it has low miles so the rings may not be worn, but they might be stuck from sitting for years. Take the oil filler cap off and put your hand over the hole while it's running to feel for combustion blow by.
Teamsters Local 1150
SH-60B is offline
post #3 of 13 Old 12-30-2014, 11:49 AM Thread Starter
LJSilvers
LJSilvers's Avatar
No blow by just very hard crispy crunchy gaskets.
post #4 of 13 Old 12-30-2014, 11:52 AM
Registered Hoosier
Hoosier Rick's Avatar
Distributor o ring was a common cause of leaks on 2.8 engines.
1992 rcsb 4.3,at 357,000 miles. Rust in Peace
2002 rcsb, 2.2 at, 289,000miles
1967 C10
2006 Colorado
post #5 of 13 Old 12-30-2014, 03:28 PM
4 Year Intermediate Tech
greasemonkeys10's Avatar
User is: greasemonkeys10 is offline
good luck i rebuilt my 85 2.8 and even after a speedy sleeve to repair the groove in the back journal it still leaks a crap ton of oil
1985 2.8L V6 S10 completely restored with 65,000 miles on body, frame, and rear axle. Weber 38 DGES Powered SOLD
1989 Nissan D21 Z24i 8 Wire Wonder
1995 Chevy S10 ext cab 4.3 Z 40,000 Miles On Rebuild.
post #6 of 13 Old 01-02-2015, 05:48 AM
User is: scrappyk5 is offline
The first gasket you should replace is the distributor o ring and then the valve cover gaskets. I bet alot of your leaking will stop. But if you bought a kit to do all of them, good idea.
post #7 of 13 Old 01-02-2015, 09:00 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
It may sound like alot of work (it is) I have found that removing the engine and setting it up on an engine stand, degreasing the entire unit, then priming and painting goes a long way.
Oh, and while the engine is out, resealing everything.
I would also replace the timing chain, rear main seal, clean out the oil pan and so forth.
I am doing this exact process to an old 2.5 Duke. It was leaking oil so badly, it looked like a sludge dump from an oil refinery...
The main leak (I found out) was the rear main seal which spins in it's housing. It had shrunk!
One other famous leak on the 660 is the oil filter housing to block gasket. I've had to replace a few of those over the years...
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #8 of 13 Old 01-02-2015, 09:27 AM Thread Starter
LJSilvers
LJSilvers's Avatar
Mad Max, thats what we are doing, going to make it look like it matches the rest of the truck. And oil filter housing to block gasket, Ill check that out too thanks.
post #9 of 13 Old 01-02-2015, 09:43 AM
Registered Hoosier
this. You need to pull the engine to get the oil pan off anyway.
1967 C10
2006 Colorado
post #10 of 13 Old 01-09-2015, 12:35 PM Thread Starter
LJSilvers
LJSilvers's Avatar
Engines out, being cleaned and so is the engine bay. Had to weight on the parts. Now everyone is taking turns with a cold or flu. Might, I hope, be done on Mon.
post #11 of 13 Old 07-02-2015, 11:20 PM Thread Starter
LJSilvers
LJSilvers's Avatar
Almost 6 months and absolutely leak free. After a week found out the fuel pump was leaking oil too. Then the trans pan gasket split on the pass side. Now I just need to get a dual voice coil sub and install my Pioneer CD and speakers.
post #12 of 13 Old 07-05-2015, 09:07 AM
6th Incarnation
FoaRyan's Avatar
User is: FoaRyan is offline
Woohoo, that's a nice accomplishment! I don't think I've had a truly leak-free vehicle in 15 years. I was just thinking yesterday I should probably plan to pull my 3.4 engine next year and reseal, mostly because I was doing an oil change and wiping sludge off everywhere.
[ 2002 ZQ8 S10 ("Time Vortec" V8, once accelerated really fast | 1995 3.4 Camaro | @FoaRyan on Twitter
FoaRyan is offline
post #13 of 13 Old 07-08-2015, 04:43 PM
Awww..you ain't got shit!
jimmykicker's Avatar
Here's your leaky gaskets most common...basically all of them
1. Valve covers. Use rubber gaskets. Only use RTV where the head meets the intake. Nowhere else. Fixes it every time
2. Distributor O-ring. Put a 350 paper gasket under the mount for extra protection
3. Oil filter adapter. Make sure completely clean. Check the rubber gasket around the bolt!!
4. Rear seal on old 85-down. Shitty design
5. Front Seal on 85- down. Shitty design.
I had to cut my nut in half .
