evap. can delete ? now stumbling .. - S-10 Forum
post #1 of 3 Old 11-23-2015, 04:06 PM Thread Starter
blazed2's Avatar
User is: blazed2 is offline
hi guys,
i have deleted my can .
i have the tank line running to the evap. tvs on the intake.
so when the motor worms up the valve opens and sucks the vap. from tank.
but i have been having problems and not sure 100% if this is doing it.
but after some time, my truck starts staving of fuel. well seems like it.
you go to give it gas and it stumbles and if your on the gas it starts lossing some power then it goes back up.
could these be the problem?
o and when i put gas in , removing the cap you can here there's a vacuum in the tank.
has anybody deleted your can?
if so how ?? were is your line run ?
88 s10 blazer, 2door with 4x4 frame ( 5"/5" drop)
modded 2.8 , 700r4 .
doing black on black on black
phantom grill, side marker lights, tinted tail lights
and a lot of other mods.
7,000 rms audio system ( nasty )
"" old school build ""
92 s10 blazer 2dr,2wd,4.3
no rust. bagging it. and switching over all the stuff from 88.
doing all 2nd gen. blazer brakes.
blazed2 is offline
post #2 of 3 Old 11-23-2015, 09:57 PM
User is: damanx is offline
Re: evap. can delete ? now stumbling ..
Sounds like a vacuum leak regarding that vacuum circuit, but then it sounds like you aren't sure if the stumbling has occurred prior to this.
1985 GMC S-15 Gypsy ext cab.
3.4l, Edelbrock intake, a 4.3l throttle body controlled by an '88 TBI ECM. 700R4 with 3.73 rear. Real time tuning using a CF-30 Toughbook with a Moates Ostrich 2 emulator.
damanx is offline
post #3 of 3 Old 11-24-2015, 02:21 PM Thread Starter
blazed2's Avatar
ya not 100% sure this is it..
im going to pull the line and see how the truck acts..
and i know there's no vacuum leaks.
blazed2 is offline
