Distributor hold down nut size? - S-10 Forum
post #1 of 15 Old 06-19-2015, 08:20 AM Thread Starter
lowmileage's Avatar
User is: lowmileage is offline
My 1/2, 5/8" tool doesn't fit so I assume it's a metric size. I can't get my fingers inthere to do any trial fitting. Anyone know the size offhand? Thanks much.
1985 S-10 2.8ltr. Radio delete, 2WD positraction, gauges, halogen lights and off-road tire option (standard tread front, off-terrain tire rear - now running 4 Winterforce tires). Delco gas shocks. Dad was original owner. 95K miles now. Single stage urethene repaint was the summer of 2011 project (now faded, don't buy Eastwood's paint).
post #2 of 15 Old 06-19-2015, 08:33 AM
S10tahoe28's Avatar
User is: S10tahoe28 is offline
Re: Distributor hold down nut size?
Mine is 15mm. And I have to order the wrench
post #3 of 15 Old 06-19-2015, 08:41 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
15MM baby.
A 3/8 universal joint and short 15MM socket on a long extension does the trick!
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #4 of 15 Old 06-19-2015, 09:05 AM Thread Starter
lowmileage's Avatar
Originally Posted by Mad Max View Post
15MM baby.
Woopee , I will try that trick - thanks for the prompt response
post #5 of 15 Old 06-19-2015, 09:08 AM Thread Starter
lowmileage's Avatar
Ouch - took me a half hour to find the bolt, conveniently located behind the plastic protective tube encasing wires. Thanks for the sizing data and quick reply.
post #6 of 15 Old 06-19-2015, 11:18 AM Thread Starter
lowmileage's Avatar
I'll need the specific 15 mm dz wrench. I ground down a 15mm socket short but I cannot get it on the bolt.
post #7 of 15 Old 06-19-2015, 12:05 PM Thread Starter
lowmileage's Avatar
Ok, I removed a bracket and was able to fit a small socket wrench and my cut down socket to loosen it. Thanks
post #8 of 15 Old 06-24-2015, 02:57 PM
Boozebag
Mad Max's Avatar
^^ Huh?? I have several 2.8/3.4s and have never had to go through what you went through.
Wow...
S10 addiction:
Mad Max is offline
post #9 of 15 Old 06-24-2015, 03:26 PM Thread Starter
lowmileage's Avatar
Actually by removing that bracket, you can get a 15mm open end wrench on it which is how I tightened it.
post #10 of 15 Old 06-24-2015, 07:42 PM
S10tahoe28's Avatar
I can usually get my hand down beside the engine and get a 15 mm ratcheting open ended wrench in there. I've only for enough room for one click though. It's not worth taking the coil and everything else out of the way. But if the engines hot I do get burned a few times on the air tube and exhuast. And with a 3 inch body lift makes it worse. I have to sit on top of the motor to get it lol
post #11 of 15 Old 06-24-2015, 08:15 PM
overthinker extraordinar
jcricket's Avatar
User is: jcricket is offline
I always use a 15mm socket(3/8 not 1/2) next a swivel, and then usually two 3/8 extensions. I can get the bolt loose and out in about 3 minutes now. Any other combination I have tried is more difficult.
jcricket is offline
post #12 of 15 Old 06-24-2015, 09:50 PM
Boozebag
Mad Max's Avatar
^^^ exactly what I do.
Am I missing something?
Must be too much beer..,
S10 addiction:
Mad Max is offline
post #13 of 15 Old 06-25-2015, 06:30 AM
S10tahoe28's Avatar
I've never had good luck with swivels -.-
post #14 of 15 Old 06-26-2015, 03:53 AM
Maybe later.
tytotheler92's Avatar
I use a stubby combo wrench...lol
1988 S-15 - 5.5/6 drop
1985 S10 Blazer 4WD
1998 Blazer ZR2 5 Speed!
post #15 of 15 Old 06-26-2015, 09:02 AM
Awww..you ain't got shit!
jimmykicker's Avatar
I don't even recall using anything other than an extension and "maybe" a swivel. Been a while.
I had to cut my nut in half .
