Did I ruin my truck? - S-10 Forum
post #1 of 14 Old 01-01-2019, 01:44 PM Thread Starter
User is: S10 Novice is offline
My roommate just bought a 2.5 and we set the timing yesterday by first jumping the upper right two pins in his service connector. I decided to do the same to my 2.8 since I've been running a little rich since I bought the truck. Put the paperclip in, and now the truck won't start.
Is the procedure the same with my 2.8 or did I screw something up with that pin? I can get it to run but barely. Thanks in advance for the help this is my first chevy.
post #2 of 14 Old 01-01-2019, 02:19 PM
94 4x4,01 Blazer
Jayhawke's Avatar
User is: Jayhawke is offline
Re: Did I ruin my truck?
more info needed- year would help
32yrs of wrenching- 8 for Uncle Sam and the rest at various Garages.A bit of knowledge on everything from 2cyc Weedeaters to Jet turbines,with Civil Engineering and Computer As/Repair as a kicker.
Jayhawke is offline
post #3 of 14 Old 01-01-2019, 02:24 PM
B4U Task Force
Rhotpursuit's Avatar
I'm guessing it's the '91 in his other thread.
Apple Red 96 SS
post #4 of 14 Old 01-01-2019, 02:36 PM Thread Starter
Sorry, yes a 91. Battery is good, fuses are good. I drove it 10 minutes before sti king that paperclip in and that's all that changed before the no-start.
post #5 of 14 Old 01-01-2019, 03:52 PM
oldeerslayer's Avatar
Have you checked every fuse?
post #6 of 14 Old 01-01-2019, 04:19 PM Thread Starter
Every fuse under the dash is good and I have new plugs and wires.
I can get it to start now and it runs smooth with my foot on the throttle, but if I rev it it back fires like too much fuel, and it idles so low it basically dies.
I'm about to check spark right now and regap the plugs.
post #7 of 14 Old 01-01-2019, 04:22 PM
User is: The_Raven is offline
That's not how you set the timing on a 2.8, and pretty sure it's not correct for the 2.5 either.
there's a connector above the passenger foot well that you disconnect to set timing.
Grounding the ALDL connector in the same way you would check codes won't cause it not to run though.
Yukon: The daily driver
Tha other Toy: 1923 T-Bucket
post #8 of 14 Old 01-01-2019, 04:34 PM Thread Starter
I wonder why I read that yesterday.
So I guess this is just a crazy coincidence that I'm having this issue. It's running like my timing is way off but I've been trying to set it for an hour with no luck.
post #9 of 14 Old 01-01-2019, 05:01 PM
jayyk31's Avatar
User is: jayyk31 is offline
Make sure your using the correct timing mark on the balancer. Theres 2 thin lines and 1 fat line. Its the fat line you use. Engine should be at operating temp. And make sure you have the 1 cavity connector unpligged in the passenger side footwell. Also hopefully your reading the timing gun correctly if it has a dial.
Also how deep did you short out the 2 pons on the aldl? Hopefully you didnt booger up the terminals by sticking in the clips to far and rough
-NEW DAILY. '86 Blazer 54k miles!!!
https://www.s10forum.com/forum/f20/my-new-gem-815417/
'92 EXTENDED Cab 408 LSx t56 Magnum!!!
Build thread-
https://www.s10forum.com/forum/f213/l...56-n-a-665850/
-2000 RCSB 2.2 5 speed.... SOLD!!!
jayyk31 is offline
post #10 of 14 Old 01-01-2019, 05:15 PM Thread Starter
Yeah I set the timing correctly yesterday morning, it wasn't until later that i messed it up.
I just swapped out the IAC and it fired right up but was idling very very high.
I'm going to clean out the throttle body port where the IAC sits and see if that brings the idle down to a point where I can set the timing.
Thanks.
post #11 of 14 Old 01-01-2019, 06:51 PM Thread Starter
Update:
I got it running and driving back to normal but the timing mark is at the 5 o'clock not 1 o'clock. I'll just leave it as is until I do some more research. Thanks for the help.
post #12 of 14 Old 01-01-2019, 07:22 PM
B4U Task Force
Does your truck require the wire disconnect on the passenger side in the cab?
Apple Red 96 SS
post #13 of 14 Old 01-02-2019, 06:06 AM
jayyk31's Avatar
Thanks.
Also make sure your minimum air is correctly set. Has the idle set screw been messed with? Have you changed the tps at all?
Build thread-
jayyk31 is offline
post #14 of 14 Old 01-02-2019, 06:09 AM
jayyk31's Avatar
Does your throttle shaft have any play in it? Is your minimum air set correctly? Tps set correctly? Truck wont ever idle or run right if these things arent correct
Build thread-
jayyk31 is offline
