Coolant Leak between Valve cover and Intake - S-10 Forum
post #1 of 16 Old 10-03-2015, 04:33 PM Thread Starter
Boulky12's Avatar
User is: Boulky12 is offline
I noticed coolant between the pass. side valve cover and the intake manifold yesterday and soaked it up with paper towels. I drove her 70 miles this morning and its back.
I was thinking intake manifold gasket but doesn't the coolant usually mix with the oil? I drive at least 150 miles a week, check the oil every week, and it looks great.
What do you guys think. This is my daily so I'd really appreciate the help. Thanks.
Boulky12 is offline
post #2 of 16 Old 10-03-2015, 05:30 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Coolant Leak between Valve cover and Intake
First thing to do is clean the area off...but...it looks like its leaking from the radiator hose or thermostat housing.
Apple Red 96 SS
post #3 of 16 Old 10-03-2015, 05:37 PM Thread Starter
Boulky12's Avatar
Changed the thermostat with a new gasket a couple weeks ago but I'll check it out and the hose.
Thanks.
Boulky12 is offline
post #4 of 16 Old 10-03-2015, 05:47 PM Thread Starter
Boulky12's Avatar
Now that I took a closer look it does look like theirs a mark going down the manifold from the housing like it was wet before. Will putting gasket sealer around the housing then bolting it down do the trick?
Boulky12 is offline
post #5 of 16 Old 10-03-2015, 06:13 PM
B4U Task Force
What kind of gasket did yu use? I've never had to use sealer. You might check the housing and the manifold to make sure they are straight. If you must use sealer, get The Right Stuff by Perma-Tex.
Apple Red 96 SS
post #6 of 16 Old 10-03-2015, 07:02 PM
User is: bonestock is offline
The thermostats in my 87 and 92 use a rubber ring seal around the outside of the thermostat. Those do not come with the stat and have to be bought separetly. O'reilies has them separate.
Bonestock
post #7 of 16 Old 10-03-2015, 08:15 PM Thread Starter
Boulky12's Avatar
Bonestock
Hmmm. When I got the thermostat, from oriellys, it came with that rubber ring. Think I'm gonna try the permatex. It's a tiny leak so it should get the job done.
Boulky12 is offline
post #8 of 16 Old 10-03-2015, 08:17 PM Thread Starter
Boulky12's Avatar
Cant believe I was thinking it was an intake manifold gasket. I need to take it slower next time and thoroughly examine.
Boulky12 is offline
post #9 of 16 Old 10-03-2015, 08:29 PM
B4U Task Force
It's an S10...hope for the best...expect the worst...lol
Apple Red 96 SS
post #10 of 16 Old 10-04-2015, 08:37 AM
Post Whore
chevymec's Avatar
User is: chevymec is offline
The 2nd pic looks like a crack to me although it looks like the leak is still coming from the thermostat housing.
1997 SS---Built and Blown... almost
My build thread... https://www.s10forum.com/forum/f30/pr...ecs-ss-513887/
chevymec is offline
post #11 of 16 Old 10-04-2015, 08:55 AM
B4U Task Force
Looks more like irt and grime to me.
Apple Red 96 SS
post #12 of 16 Old 10-05-2015, 08:27 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Suggestion:
I bought a tstat housing gasket (Felpro) and installed the O ring.
No more leaky.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #13 of 16 Old 10-05-2015, 04:43 PM Thread Starter
Boulky12's Avatar
I just ended up tightening the clamp on the hose real good with a 5/16 and rachet. Took it for 60 miles, checked, not a single drop. I think I'm going to start using the 5/16 instead of the flathead for these clamps
Boulky12 is offline
post #14 of 16 Old 10-05-2015, 04:56 PM
B4U Task Force
Good plan...lol
Apple Red 96 SS
post #15 of 16 Old 10-06-2015, 08:37 AM
Boozebag
Mad Max's Avatar
BTW... ^^^ nice throttle return spring. Any pressure on the pedal??
S10 addiction:
Mad Max is offline
post #16 of 16 Old 10-06-2015, 08:06 PM Thread Starter
Boulky12's Avatar
Lol It was like that when I got it but feels fine to me
Boulky12 is offline
