Code 45, o2 Sensor, Rich Exhaust - S-10 Forum
post #1 of 24 Old 09-18-2014, 12:48 PM Thread Starter
User is: dross93ranger is offline
My truck is misfiring like crazy after warming up and I have this code. The o2 sensor is only a year old. Should I go ahead and replace the sensor and is there only 1? I have only located 1 and it is under the truck. Or is there another cause making the o2 read it as being rich?
post #2 of 24 Old 09-18-2014, 02:26 PM Thread Starter
Re: Code 45, o2 Sensor, Rich Exhaust
Update, the truck runs great under WOT, otherwise runs like crap. It smooths out a lot when the CEL is on.
post #3 of 24 Old 09-20-2014, 07:15 PM Thread Starter
I have changed spark plug wires and the ignition coil with no results. It still misfires at idle right after started and then drives fine for the most part, after about 15 minutes of driving it starts stumbling really bad and doesn't want to run and hesitates when given throttle followed by it lurching forward. Everything is good when WOt.
post #4 of 24 Old 09-20-2014, 07:56 PM Thread Starter
Just ordered an ignition module, symtoms seem to be similar.
post #5 of 24 Old 09-22-2014, 12:17 PM
User is: ross.brown1 is offline
What year truck, throttle body or carb? If throttle body might want to check voltage on tps sensor. Mine was showing low voltage kinda had same symptoms. May also want to check timing.
post #6 of 24 Old 09-22-2014, 01:21 PM Thread Starter
Thanks, its a 1991 TBI
post #7 of 24 Old 09-22-2014, 01:50 PM Thread Starter
TPS checked out fine with the multimeter.
post #8 of 24 Old 09-22-2014, 03:20 PM
Mine is also 91 TBI. I just put a new engine in mine. Had same problems. Found out distributor bolt was a bit loose and timing changed a bit.
post #9 of 24 Old 09-22-2014, 08:34 PM
When you checked voltage on tps sensor you had .5 volts with key on not started and 4.5-5 volts when you open throttle wide open. You want to open throttle gradually to make sure their is no spike in voltage reading.
post #10 of 24 Old 09-23-2014, 11:25 AM Thread Starter
Yeah thats exactly how it read. I have a map sensor and ignition module shipping to me right now to try.
post #11 of 24 Old 09-25-2014, 03:54 PM Thread Starter
Ignition module made no difference, Map sensor arrives tomorrow. I guess next in line is EGR or 02 sensor? So far I have changed:
Wires, ignition module, ignition coil, and checked the TPS. Spark plugs are only a year old and I'll change them as well if issues continue.
post #12 of 24 Old 09-26-2014, 12:53 AM
Drege's Avatar
User is: Drege is offline
I'm having same issue in my 87.
new O2, CTS, TPS, MAP, EGR sol, rebuilt TB. I'm at my wits end.
I'm now convinced the cat is clogged, punched hole in check port - ran even worse!
87 S-10 Blazer 4x4 - 2.8l 4spd automatic - 2door - - 206xxx = possible rebuild
87 Toyota Tercel 4wd wagon - 3a 1452cc (1.5l) SOHC - 5spd standard - - 221xxx
78 Dodge M500 (10 ton HD chassis) 30 foot RV - 440-3 4bbl - 727 loadflite high torque 3 spd auto - - 29xxx miles
80% of time is working, 12% sleeping, 4% eating, 3% dreaming and 1% enjoying the fruits of 99% of my time.
Drege is offline
post #13 of 24 Old 09-26-2014, 04:03 AM Thread Starter
Please let me know if you figure it out, I'll keep this thread up to date until I find the issue. I'm lost as well.
post #14 of 24 Old 09-26-2014, 10:28 AM
Drege's Avatar
Man I been dorking with this thing and posting here for ideas for upwards of 2 months with <strike>little to</strike> no progress.
hell I even bought another beater to relieve the stress of having a crappy running s10 and my replacement car ate its transmission last weekend, so I'm convinced the universe is plotting against me.
One factor that puzzles me is that when at idle if I quickly rev the engine, like snap rev; the idle comeback is less and less until it chokes and dies, every other vehicle that you do that on will either steady ramp up rev or respond per rev and keep steady idle.
Today I'm reseating the TB gasket, checking fuel pressure, replacing cap and rotor (again), checking ground straps, checking/setting timing, then I suppose I'll just eat the 10MPG to reno and back for a replacement tranny for my toyota.
Drege is offline
post #15 of 24 Old 09-26-2014, 04:55 PM
4 Year Intermediate Tech
greasemonkeys10's Avatar
User is: greasemonkeys10 is offline
Clogged cat can be determined easily with a vacuum guage in the brake booster line and 2500 rpms.
1985 2.8L V6 S10 completely restored with 65,000 miles on body, frame, and rear axle. Weber 38 DGES Powered SOLD
1989 Nissan D21 Z24i 8 Wire Wonder
1995 Chevy S10 ext cab 4.3 Z 40,000 Miles On Rebuild.
post #16 of 24 Old 09-26-2014, 06:12 PM
Drege's Avatar
yea well I'm a cheap bastard. was looking at a fuel pressure gauge at orileys when I saw it was $52 I said "I'd rather save $30 and get a new fuel pump.
same thing with the cat, I'm going to Reno for a transmission for my tercel and I'd rather just buy a new cat at the summit racing for $45 and have some oakland hipster weld it in.
Runs a little better now, well as bad as it did when it started running like shit, reseated the TB and put tacky on both sides, new cap and rotor, reset to 10BTDC and fixed a bad connection at the starter.
**** it, if donner pass eats it its available on I-80 for free, I'll leave the title in the glove box.
I'm so done with this piece of shit.
Drege is offline
post #17 of 24 Old 09-27-2014, 01:30 PM
Drege's Avatar
Hmm I wonder if yours is like mine Dross93; at low RPM's, low speed acts like shit, power to brake booster and idle downturn when brakes applied - get on the freeway and it screams; just did overall average of 60MPH up and over donner pass, there is a sweet spot in the acceleration, I'll say ~2800 - 3200 RPMS in 3rd gear, but when it kicks into overdrive it struggles a little bit, coasting in OD is a jerky thing, best done in 3rd, keeps the RPM's higher in the 2000's.
I'm going to adjust the TPS again and think more about the cat on this cold day in reno.
Drege is offline
post #18 of 24 Old 09-27-2014, 04:04 PM Thread Starter
Sounds familiar, I don't have a cat either.
post #19 of 24 Old 09-28-2014, 12:34 AM
Drege's Avatar
Well unless I move to nevada (cali resident now) I need to keep the cat on.
Drege is offline
post #20 of 24 Old 09-28-2014, 09:01 PM Thread Starter
Since USPS lost my new map sensor, I went to the junkyard and grabbed a couple to try and the first one I threw on made it run great! I swear I can hear a slight misfire at idle, but I drove it for 30 minutes with no issues. I bet the misfire is just fouled plugs from running rich. I will update later on in the week if the issue reoccurs.
post #21 of 24 Old 10-03-2014, 01:12 PM Thread Starter
Update, the truck still has a misfire, but it driveable now. The only time I notice the misfire is at idle when I can hear the exhaust making a puffing noise. Here are the parts I have changed:
Spark plug wires
Spark plugs
Ignition coil
Ignition module
Tested TPS
Map sensor (this fixed the stuttering while driving)
Ran seafoam through tank and put through brake booster line
I am thinking to change my o2 sensor next, how many o2 sensors are there? There is one I see down by where the cat was, but I do not see any others.
post #22 of 24 Old 10-07-2014, 02:56 PM Thread Starter
I still havent touched the 02, just been driving it. I drove it an hour from home the other day with no issues besides the miss at idle, pulled hills great. Could the EGR or EGR solenoid cause this rough idle?
post #23 of 24 Old 10-10-2014, 02:26 AM
Drege's Avatar
I seem to have one also, mines driverside before the merger/cat.
Drege is offline
post #24 of 24 Old 10-15-2014, 08:46 PM Thread Starter
Still misfiring at idle only, this is killing me. I guess I will buy a TPS and IAC soon to try.
