carburation and jets - S-10 Forum
post #1 of 7 Old 07-27-2015, 07:57 PM Thread Starter
overthinker extraordinar
jcricket's Avatar
User is: jcricket is offline
Hey folks,
I am currently working on dialing in my 85 2.8l. I put a new motor with crower cam and a weber 38dgas on it. It still is not quite right. I am trying to understand what each jet does so that I can make educated guesses on what to do.
Idle jets - pretty self explanatory. Mixes air/fuel ratio for the engine when it is at idle. These do not come into play at higher rpms. So I have read.
Air corrector jets. I am guessing here. I think these jets determine how much air will be mixed with the fuel. A smaller jet will give a leaner mix, a larger jet will give a richer mix.
Main jets, again I am guessing. The main jets determine how much mixture the carb can draw into the engine. The larger jet allows more mixture, and thus a richer burn, smaller is also leaner.
I am not certain this is right. Can anyone who knows carbs educate this poor old soul???
Thanks in advance.
mark
jcricket is offline
post #2 of 7 Old 07-28-2015, 06:39 PM Thread Starter
jcricket's Avatar
Re: carburation and jets
I just leaned up my carb. I replaced all 6 jets to one size down. Now she runs awesome. I mean AWESOME!!!!!
I had her at about 600rpm and you could almost balance an egg on her.
jcricket is offline
post #3 of 7 Old 07-28-2015, 07:13 PM Thread Starter
jcricket's Avatar
A couple of tings. On my carb, I was adjusting the idle fuel mixture. I turned it almost all the way in until I had any affect. Then about 1/8 turn more and it bottomed out and died. I assumed, and correctly I believe, that the jets were too rich. I put leaner jets in and they worked well. I may order one step leaner yet and try them.
jcricket is offline
post #4 of 7 Old 07-29-2015, 08:37 AM
4 Year Intermediate Tech
greasemonkeys10's Avatar
User is: greasemonkeys10 is offline
your on the right track
post #5 of 7 Old 08-08-2015, 03:13 PM
Zagan's Avatar
User is: Zagan is offline
Send a message via Yahoo to Zagan Send a message via Skype™ to Zagan
I hope this link will help you out. http://www.redlineweber.com/html/Tec...as_tunning.htm It has helped Me out a bunch.
Zagan is offline
post #6 of 7 Old 08-09-2015, 11:11 AM
B95
Early Member
B95's Avatar
User is: B95 is offline
I always used a vacuum gauge. Tuning by ear is good to a point, if your hearing is not screwed up by listening to loud music. When using a vacuum gauge, the gauge will indicate where your engine is set best. And the sound will be good. Also make sure you have no vacuum leaks.
1995 Black S-10 X-Cab 4.3 CPI. '96 Jimmy 4dr Power-leather seats. '97 Camaro gauge needles. '98/99 Bravada core support, headlights and grille. Envoy bumper cover and fog lights. 2" drop spindles. Headlight wire upgraded with relays. Blazer floorshift and console. '96 Blazer leather steering wheel and air bag. '96 Jimmy leather door panels. 310,xxx miles. ZQ8 steering box. SS Mirrors.
B95 is offline
post #7 of 7 Old 08-11-2015, 09:02 AM Thread Starter
jcricket's Avatar
I have not heard of or seen this method. I'll look into it.
Set it to highest vacuum? Is that the goal?
jcricket is offline
