Best transmission fluid - S-10 Forum
post #1 of 8 Old 01-17-2019, 11:47 PM Thread Starter
Yowakawaka's Avatar
User is: Yowakawaka is offline
Hi everyone. I have a 83 s10 2.8 v6 Rear TWD. I’ve been calling around different places for transmission fluid and have been hearing different things from all of them. I’ve heard dexron 2, 3, 4, and 6. Someone told me dexron 6 is for the newer GM vehicles. Is this correct and what should I be using? I’m looking for a good quality fluid that will take care of my transmission!!!
Zip Em Up and Zip Em Out....
post #2 of 8 Old 01-18-2019, 01:23 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Re: Best transmission fluid
For the most part, the early tucks (like yours) used Dexron III.
You can switch to a synthetic counterpart also ($$).
Remember, the pan only holds between 3 and 4 quarts... the rest is in the converter.
Unless you have a flush done, you will still have old juice in the tranny.
A flush consists of hooking a machine to the transmission coolant lines at the radiator and power flushing the old juice out.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #3 of 8 Old 01-18-2019, 07:20 AM
Registered Offender
User is: Watthour is offline
It is generally safe to switch to Dex VI in any 1980+ Hydramatic, including the "T" series transaxles. As Max pointed out, it's going to cost a little more.
If you are changing because of a shifting or performance problem, I would suggest only performing a pan drop to fit in a new filter/pickup and clean/inspect what is exposed. It would also be advantageous to install a drain plug to make future changes a lot cleaner and faster, something like this:
And when the pan and gasket are installed, be absolutely, positively, overnight certain that this hole does NOT get covered:
Watthour is offline
post #4 of 8 Old 01-18-2019, 10:37 AM Thread Starter
Yowakawaka's Avatar
Watthour
The photos you posted are blocked for me to see. I know the drain plug your talking about. I don’t know the hole you mentioned when everything is back on. Can you elaborate a bit more please?
I just bought the truck so this is the first fluid swap I’ll be doing. Does it matter if the fluid I put in is different from what’s already in there. For example, dexron 3 already in it and I put in dexron 6; or, if valvoline brand is in it and I put in Mobil 1 brand?
If I don’t know what’s in there should I just get it flushed all together? It seems to shift a little rough but overall pretty good.
post #5 of 8 Old 01-18-2019, 10:52 AM
New Member
Racer-X's Avatar
User is: Racer-X is online now
Dexron III is what is specified for that year. Nearly any good, new conventional Dex/Merc fluid will do. A "high mileage" formulation might be a good idea, provided it's not a full synthetic fluid.
I'm a believer in regular (30,000 miles) drain and fill with a fresh filter.
The down side to switching to synthetic is that you can discover a bunch of leaky seals (external and internal). The external leaks (tail shaft, input shaft) will drop fluid on the ground and be obvious. The internal leaks will make for poor shifting and poor operation. Worst case, you can lose gears (1st and reverse completely gone is the most common as that's the most used parts that move the most cycles).
If you still want to switch out to a Synthetic fluid, a "flush" will get it all. Drain and fill with a new filter won't change the fluid in the torque converter.
Every machine is a smoke machine if you operate it wrong enough.
post #6 of 8 Old 01-19-2019, 06:44 PM Thread Starter
Yowakawaka's Avatar
Cool thanks everyone. I purchased a ATP filter kit and Valvoline Dex III. Ill be changing it out today and I'll be sure to let you know how it goes.
post #7 of 8 Old 01-19-2019, 07:07 PM
B4U Task Force
Rhotpursuit's Avatar
.....messy.
Apple Red 96 SS
post #8 of 8 Old 01-20-2019, 12:37 AM
User is: Hellcat1 is offline
Originally Posted by Yowakawaka View Post
Hi everyone. I have a 83 s10 2.8 v6 Rear TWD. Iíve been calling around different places for transmission fluid and have been hearing different things from all of them. Iíve heard dexron 2, 3, 4, and 6. Someone told me dexron 6 is for the newer GM vehicles. Is this correct and what should I be using? Iím looking for a good quality fluid that will take care of my transmission!!!
Dexron III is what your truck should call for. That being said TSB #04-07-30-037E: superseads all previous Dexron fluids with Dexron VI and is fully synthetic.
Sent from my SM-G892U using Tapatalk
Kenneth R Zink II
2001 Chevy S10 SL 4.3L Turbo SFI - Black Beauty
2000 GMC Jimmy SLT 4.3L SFI - J10
1994 Olds Bravada - Rocket (4.3L CPI...for now)
Hellcat1 is offline
You may post new threads
You may post replies
