A few 2.8 - 4.3 TBI swap questions. - S-10 Forum
post #1 of 7 Old 12-13-2015, 10:09 PM Thread Starter
User is: Cathairez is offline
I've been looking at trying this, and reading through old posts. I still have questions, this is my only vehicle ATM so I want to do it right.
What has to be taken off the 2.8 throttle body and put on the 4.3 besides injectors (my blazer is an 86 2.8 and I know where an 87 astro with 4.3 is)?
Do I use the 2.8 tps or the one on the 4.3? Do I use the 2.8 idle air valve or 4.3? On another site I saw mention of having to make idle adjustments, it was on Isuzus. Will I need to make adjustments idle speed and other things?
Thanks for help.
post #2 of 7 Old 12-14-2015, 12:32 PM
User is: The_Raven is offline
Re: A few 2.8 - 4.3 TBI swap questions.
Both TPS and IAC should be the same. If not, you use the parts that fit the throttle body you are using. The signals/control are the same.
The daily driver: 2005 Blazer
Tha other Toy: 1923 T-Bucket
post #3 of 7 Old 12-14-2015, 01:02 PM Thread Starter
Thanks! I get so worried about the details.
post #4 of 7 Old 12-14-2015, 05:39 PM
User is: damanx is offline
Correct me if I am wrong, but, if what are planning is to put the 4.3 throttle body on top of the stock 2.8 intake, I don't believe it will work because the bores and butterflies on the 4.3 throttle body are bigger than the holes in the 2.8 intake.
1985 GMC S-15 Gypsy ext cab.
3.4l, Edelbrock intake, a 4.3l throttle body controlled by an '88 TBI ECM. 700R4 with 3.73 rear. Real time tuning using a CF-30 Toughbook with a Moates Ostrich 2 emulator.
damanx is offline
post #5 of 7 Old 12-15-2015, 06:21 AM
DarkKnite2009's Avatar
User is: DarkKnite2009 is offline
It wont do any good without the intake mod..... but it should work...
1993 S10 (Tahoe) 2.8 5spd
post #6 of 7 Old 12-17-2015, 09:55 AM
Awww..you ain't got shit!
jimmykicker's Avatar
Despite what I read I believe that it wouldn't open all the way, I remember sitting the 4.3 TBI on the 2.8 intake stock and it did open all the way, but without the plenum being bored it's a waste of time. It cost me like $70 I think to do mine.
Cut the gaskets when you replace them...not worth the time to pull the rods. People will say not to do it, but I've done it plenty of times without issues. Just make sure to use a little RTV to keep them in place.
I had to cut my nut in half .
post #7 of 7 Old 12-20-2015, 10:36 AM
Hard Driver's Avatar
User is: Hard Driver is offline
You need to enlarge the intake bores to 4.3 size,mark it using a 4.3 tb gasket.As I recall the the Astro and Safari van 4.3 TBI fits without throttle bracket / linkage needs no mods.
S10 blazer 85 2dr 2wd sbc,200 4r trans. 8.5" 3:42 disc brake rear. Quick ratio box,33 mm front bar / 23 mm rear. 2" ds / 1" ds front / 3" ds rear with drop shocks.
S10 blazer 87 2dr 2wd 3.4 700 r4 trans. 7.6 disc brakes w/ thorsen 3"42 .
You may post new threads
You may post replies
