'86 S15 4x4 -3.4 swap - Page 2 - S-10 Forum
 3Likes
post #51 of 65 Old 05-22-2018, 08:43 PM Thread Starter
GM
GM's Avatar
User is: GM is offline
Send a message via AIM to GM
Re: '86 S15 4x4 -3.4 swap
Got my problems solved. Code 32 was just a vacuum line to the egr valve that had popped loose.
Cut open the filter after the first oil change and it looked super clean.
Untitled by Andrew Schwerdtfeger, on Flickr
upgraded from a 75 interstate to a 34/78 optima yellow top for the winch,
Ended up replacing the cat because I quickly got tired of the backfiring through the exhaust when downshifting
Also replaced the donut gaskets on the manifolds as they both had small exhaust leaks. What I get for being cheap and not doing it in the first place. I also utilized the camaro heat shields and manifold gaskets while I was at it. Totally forgot I had them.
Now I'm just putting miles on it. I was hoping for slightly better fuel economy. Tough to gauge though as I've been 4x4ing it and haven't really done a tank on just hwy miles. Should get a better idea this weekend maybe and actually calculate some economy #'s
Overall I'm really stoked on this swap. The truck is actually a pleasure to drive now. Just idles around and part throttle to make it up some of the steep hills that before I was wide open on just to maintain my speed.
GM is offline
post #52 of 65 Old 11-12-2018, 04:23 PM
heeter_33's Avatar
User is: heeter_33 is offline
I love this truck so much.
1985 S10 2.8
2010 Cobalt SS
1972 Honda CB100
post #53 of 65 Old 11-12-2018, 07:32 PM Thread Starter
GM
GM's Avatar
^ thanks heeter,
quick update,
Spent the bulk of the summer camping out of the truck and did awesome, random camping pics,
then in august we hit a deer...
The damage was mostly cosmetic, except the rad got hit by the clutch fan. The trans had been making a bad rattling noise when loading it up at lower rpms and it wasn't downshifting unless there was 100% throttle so I stripped the front end and pull the engine/trans/t-case all together. Having done this both ways now I would way rather pull the engine separately.
Then I drained the oil and found this little disaster waiting to happen. Coolant mixing in with the oil. I narrowed it down the intake gasket and sure enough 3 of the nuts had loosened up on the back passenger corner of the intake gasket and it broke the seal. This was a lesson learned the easy way, always re-torque aluminium intake manifolds after they've heat soaked a couple times.
I inspected all the main bearings, rod bearings and cam and everything looked great. In the meantime I had the 700r4 rebuilt, new "beast" sunshell, heavy duty 3/4 clutches, complete overhaul kit and reman torque converter.
new intake gasket set,
put a new muffler on it, and redid the exhaust hangers so they slide back which makes it so easy to pull the exhaust out now.
resealed and ready to go back in,
back together minus body panels,
Found a core support and restored it,
Picked up a hood and fender as well, Just need to find a grill and oe fender and I'm going to get it painted again.
then back on the road for hunting season,
I was hoping to get it back on the road from the accident for less then a grand. I paid
hood- $60
Fender - $30
headlight bezel - $5
headlight - $3
Core support - $35
Rad - $50
so roughly $200. Leaves me about $800 for paint.
GM is offline
post #54 of 65 Old 11-12-2018, 07:43 PM Thread Starter
GM
GM's Avatar
I'm currently fighting an EGR code 32 though and I'm running out of ideas in a hurry.
The truck keeps throwing a code 32 when driving about 55 km/hr at partial throttle. Initially I had thought it was EGR solenoid and replaced it with a brand new unit. This did not solve the problem, next I pulled the EGR valve and cleaned it thoroughly even though it moved freely and held vacuum before hand. Reinstalled and the problem still exists. I then check both vacuum lines thoroughly to ensure they held vacuum and had no restrictions and they are in perfect shape.
Next I started using this diagnosis guide for the 4.3 w/tbi but it seems to operate the same way so I hope it's a suitable guide.
Step 1 - connect vacuum pump to throttle body side of EGR solenoid, when I apply vacuum it does not move the valve (according guide it should) so next step.
Step 2 - connect vacuum pump to egr valve, when I apply vacuum it moves very freely and holds the vacuum for longer then I care to wait (2 min+). This indicates the valve is good.
Now it says to
- Disconnect EGR electrical connector ( I'm assuming at the solenoid, only electrical connection)
-Connect test light between harness connector terminals
^^ I have no idea what the harness connector terminals are in this case. If anyone has a wiring diagram or could advise on how to proceed that would be greatly appreciated.
Andrew
GM is offline
post #55 of 65 Old 04-11-2019, 11:21 PM Thread Starter
GM
GM's Avatar
Originally Posted by The_Raven View Post
I just noticed you removed the bump/shark fin... Congrats you just ruined those heads and made them flow less than stock.
There's a reason that GM put them there, and it wasn't just because they could.
Just had to come back to this. Yeah after doing a bunch of reading and looking at some flow bench #'s posted on other forums you are undoubtedly correct. I assumed the gentleman that did the work for me knew better but apparently that was not the case. Hopefully some of the other work he did to the heads helped increase the flow but I doubt they flow better then they would have in stock form. Lesson learned the hard way on that one...
In regards to the above post I finally solved my code 32 issue with the help of another forum member. It was just simply the wrong EGR solenoid. Apparently 86-87' use a different solenoid although it looks identical to the later years. So if anyone is relentlessly chasing a code 32 make sure you verify you have the correct solenoid. I had multiple parts stores and my local GM dealer recommend the wrong one. The correct one for these earlier years is now completely discontinued and no longer stocked by anyone so you'll have to source one from the wreckers.
Lastly I pulled this from my local junkyard the other day.
They were having a 50% off sale so I yanked this 3.4 shortblock and grabbed a set of 3400 heads w/ uim & lim. I also grabbed the throttle cable, throttle body and a few other misc things. I got the whole package for $106 out the door.
After a pressure wash
Crank looks mint
Now I've just been endlessly reading on how to get this whole package together. I'll likely just purchase a new set of 3400 pistons. The tuning and wiring is a bit overwhelming at the moment but the more I read that seems to be fading slightly. For now it will just be a n/a budget build.
GM is offline
post #56 of 65 Old 04-12-2019, 10:48 PM Thread Starter
GM
GM's Avatar
Edit* sorry here's the pics
IMG_1139 by Andrew Schwerdt, on Flickr
IMG_1152 by Andrew Schwerdt, on Flickr
IMG_1153 by Andrew Schwerdt, on Flickr
Crank looks mint
IMG_1162 by Andrew Schwerdt, on Flickr
GM is offline
post #57 of 65 Old 04-13-2019, 12:19 PM
SFA3.4
User is: Randy Sweet is offline
My first 3.4 was carbed. I didn't want to deal with wiring and computer but rough off roading and the carb didn't mix. Finally got tired of the carb and pulled the entire engine, wiring and computer from a Camaro similar to yours. Ton more power and never dies off road.
ID:	316143   Click image for larger version
post #58 of 65 Old 04-16-2019, 12:08 AM Thread Starter
GM
GM's Avatar
Randy do you have any pics of your truck? How did the 3.4 work with a sfa? That's the direction I'm heading in the future.
I ended up bring back the 3400 top end to the junk yard and exchanged it all for a 3500 set up. The girls were really nice and just let me swap it out at no extra cost.
The reason I did this was because the heads on the 3400 I picked up where all cracked from the intake valve to spark plug. Also after doing some reading it seemed like this was just a much better option. The cracks were just a good excuse to go do it.
Pic of said crack
Untitled by Andrew Schwerdt, on Flickr
New top end out of a malibu,
On the work bench at home,
The Fwd applications are a joy to work on. I had both heads off in under 2 hours.
There are a couple of things I've got to do some more reading about. One being the throttle body that comes stock on the 3.5 is drive by wire. I'm hoping there is another substitute that will maintain the same size opening but cable operated.
GM is offline
post #59 of 65 Old 04-16-2019, 01:15 AM Thread Starter
GM
GM's Avatar
Just found the LX5 throttle body set up on wot, so that is no longer a concern.
GM is offline
post #60 of 65 Old 04-16-2019, 02:16 AM
SFA3.4
Works well. It's a Dana 30 from an XJ. You can use the Camaro oil pan since you don't have all that ifs junk in the way.
post #61 of 65 Old 04-16-2019, 10:35 AM
SFA3.4
Here is a better view. My Blazer is right at about 4:28.
post #62 of 65 Old 04-16-2019, 06:14 PM
User is: The_Raven is offline
I hate to break this to you, but you got the wrong 3500 top end. You got the LZ4 3500 top end, you need the LX9 3500 top end.
They will not interchange.
The bank angle is slightly different, the combustion chambers are too large for the 3.4/3400 cylinder, IIRC the head bolt locations are slightly different as well, the cooling system differences are not compatible. I'm sure there are other differences that are not coming to me right now.
Suffice it to say, you'll be making a trip back to the wrecking yard for the correct 3500 top end.
Yukon: The daily driver
Tha other Toy: 1923 T-Bucket
post #63 of 65 Old 04-16-2019, 11:03 PM Thread Starter
GM
GM's Avatar
no wayyy hahaha, ***** I'm a sucker for learning things the hard way.... Thanks Raven, I'll have to do just that.
GM is offline
post #64 of 65 Old 04-17-2019, 11:51 PM
User is: posonoma is offline
Nice build!
Not an engine for the back country but I had a z34 lumina in the late 90's same bell pattern? really liked that engine, just hated the car it was in and the wheels it drove.
posonoma is offline
post #65 of 65 Old 04-19-2019, 04:26 PM
I'm super serial
manbearpig's Avatar
User is: manbearpig is online now
It's the same engine with DOHC. Not the most robust version of the 60 degree V6 though.
