60v6 2.8 Timing Chain Question - S-10 Forum
post #1 of 9 Old 08-13-2015, 08:11 PM Thread Starter
oldS10srule
fellchase's Avatar
User is: fellchase is offline
Hey you guys got 150k miles on my 85 Blazer 2.8 got air blowing cold in Alabama but I think timing chain slapping. Haynes manual says the oil pan could be a problem when re-install cover anybody know do you loosen pan or what. Thanks long live first gens
post #2 of 9 Old 08-14-2015, 12:19 AM
User is: bonestock is offline
Re: 60v6 2.8 Timing Chain Question
You do not have to remove or even loosen the pan for access to timing chain.
Bonestock
post #3 of 9 Old 08-14-2015, 05:45 AM Thread Starter
oldS10srule
fellchase's Avatar
Thanks Bonestock gonna give it a try this weekend.
post #4 of 9 Old 08-18-2015, 05:45 AM Thread Starter
oldS10srule
fellchase's Avatar
Got it done piece if cake the bottom edge of front cover has a smooth lip that fits against same on oil pan two screws hold the lip tight RTV thanks
post #5 of 9 Old 08-18-2015, 10:07 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
How loose was the old chain? Flapping?
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #6 of 9 Old 08-25-2015, 04:46 PM
Awww..you ain't got shit!
jimmykicker's Avatar
Years ago on the old 2.8 I put a water pump on it and decided to go ahead and crack it open to see what was going on. Timing seemed a little "off". I was shocked to see the slack! It wasn't hitting the cover, but I don't know how it wasn't! It was a miracle it didn't jump time.
Is it really chain "s-t-r-e-t-c-h" or is it the gears wearing rapidly too? I mean look at a motorcycle chain and sprockets. They stretch not only the chain but the gear itself wears down.
I had to cut my nut in half .
post #7 of 9 Old 08-26-2015, 12:46 PM
Boozebag
Mad Max's Avatar
I bought a 72 Yamaha DT 250 once. The rear sprocket had nubs instead of teeth on it...
S10 addiction:
Mad Max is offline
post #8 of 9 Old 08-26-2015, 08:14 PM Thread Starter
oldS10srule
fellchase's Avatar
150k miles running pretty good but I thought I heard sumpin. Got it down looking at old timing chain on the right side it's tight but on the left side you could rattle chain maybe inch and a half. New chain tight both sides. There is a guide in middle that helps it run true. LOTTA bolts to take off and put back in this job. New Water pump got 6mm bolts that hold WP to TC cover at bottom of pump. threads pulled out of cover on those had to tear it back down and learn about Time Serts Got it back together with new v-belts. . Smooth and quiet.
post #9 of 9 Old 08-28-2015, 09:14 AM
Time Serts....that's a new one on me. Just checked that out. How well did it work? By the way, we live close. I am in McCalla.
