4.3 won't start cold/wet - S-10 Forum
 1Likes
  • 1 Post By Rhotpursuit
post #1 of 7 Old 01-28-2019, 07:00 PM Thread Starter
Corey7733's Avatar
User is: Corey7733 is offline
Probably asked a hundred thousand times. But the search isnt working today.
My 2000 Xtreme does this, my 2000 blazer does this and a zr2 I worked on did this.
When i washed the engine bay with just a garden hose the truck absolutely will not fire up. Turns over, won't fire untill it's dry. My blazer is doing this now but when it's cold out. Like -10 celcius or more. Absolutely won't fire untill it's warm outside. I can hear the fuel pump going and all that. Never figured out the source of this, just avoided it but I need to move my blazer and I don't want to push it. Any help is appreciated.
instagram: cb7733
00' 4.3 Xtreme | 13' Cadillac ATS 2.0T
post #2 of 7 Old 01-28-2019, 07:14 PM
B4U Task Force
Rhotpursuit's Avatar
Re: 4.3 won't start cold/wet
Easy.....don't go nuts with the water. Condensation forms inside the cap. Dry it out/spray with WD40 and you'll be good.
Corey7733 likes this.
Apple Red 96 SS
post #3 of 7 Old 01-29-2019, 10:21 AM Thread Starter
Corey7733's Avatar
I'll give this a try when I get ambitious. Thanks for the reply!
instagram: cb7733
post #4 of 7 Old 02-02-2019, 12:27 PM Thread Starter
Corey7733's Avatar
So I warmed up my dist. in my blazer with a torch. Yeah not a great way to do it but what evs. Tried to start it forever. Almost started once at the very beginning of my attempt. Turned the key off and on over and heald the starter on for longish periods of time. Not a single fire. Then I start giving it quick short bursts, a bunch of times and this made it start. Obviously took a few tries to get all that fuel burned out. Weird how log continuous tries wouldn't do anything. But a couple quick turns of the key did it.
Any thoughts on what this is?
instagram: cb7733
post #5 of 7 Old 02-02-2019, 12:36 PM Thread Starter
Corey7733's Avatar
4.3 5spd
instagram: cb7733
post #6 of 7 Old 02-02-2019, 12:45 PM
B4U Task Force
Why didn't you just take the cap off and visually inspect it?
Apple Red 96 SS
post #7 of 7 Old 02-02-2019, 05:47 PM
Been there Done it
oldeerslayer's Avatar
Most GM products with FI start best with short bursts. Voltage from the battery is highest when you first hit the key. The longer you crank the lower it gets. And since you're adding fuel it gets too rich inside the cylinder to easily light off. Even my old TBI plow truck starts on the second short burst, but not if I crank it. Haven't touched that engine in 10 years.
Doubt taking a torch to the ignition system helped matters.
You may post new threads
You may post replies
