3.4 "crate" engine parts list and info - Page 2 - S-10 Forum
 2Likes
post #51 of 84 Old 07-01-2013, 07:52 AM
User is: NT_Hardcore is offline
Re: 3.4 "crate" engine parts list and info
use a puller. im lucky to have a lot of tools to use. and air.
post #52 of 84 Old 07-02-2013, 07:00 PM
anyone have info on setting the timing chain up? dot to dot?
post #53 of 84 Old 11-08-2013, 10:36 AM
d4n63r's Avatar
User is: d4n63r is offline
Okay another bump for this.
Looking to put a motor in my 4x4 shortly. The plan is to buy a new style pan and pickup along with everything else for me to run serp. What i need to know is do I need a special 4x4 pan or will a 2wd pan work? rockauto doesn't list a separate pan for the 4x4 but i seem to think i have a slightly different cross member then a 2wd truck?
I dont have a problem doing some trimming id just rather not drop it in and be like oh great it doesnt fit...
82 - 4x4, 2.8 5spd, S.cab S.box, 31x10.5 TrXus M/T too much poke
83 - CM450 hipster magnet
04 - KTM 250 sx collar bone removal tool
06 - CRF250r cause i like sweet jumps
d4n63r is offline
post #54 of 84 Old 11-14-2013, 01:23 AM
86' S-10
User is: GEARS is offline
You need a 4x4 pan along with the proper pick up tube
1986 S10 PU "SCLB" 2WD 355 TH400 3.73 8.8"
Dart 215 headed full roller 355, Full manual TH400, Killduff Lightning Rods, 150 shot of spray, homemade traction bars
GEARS is offline
post #55 of 84 Old 11-17-2013, 09:10 PM
ddog800's Avatar
User is: ddog800 is offline
Originally Posted by ddog800 View Post
When I pull my engine and swap over the timing cover, I'll snap a pic and post it for sh*ts and giggles.
Better late than never....
'86 S-10 Blazer TBI 2WD automatic - 2.8 -- soon to be 3.4
ddog800 is offline
post #56 of 84 Old 11-19-2013, 12:16 PM Thread Starter
Awww..you ain't got shit!
jimmykicker's Avatar
That's an old cover....That might indicate one of two things...One that isn't the original motor...or two, if it is, it proves that early 86 EFI trucks used old motors left over from 85....Is there a block off plate behind the steering pump where a fuel pump would have been located?
1984 xcab s-10 3.4L GM crate engine 91 S10 TBI swap w bored intake, Edelbrock headers. 2" Rough Country Lift. Flowmaster, shift kit, e-fan.
I had to cut my nut in half .
post #57 of 84 Old 11-19-2013, 03:27 PM
ddog800's Avatar
I'll check when I get home this evening.
ddog800 is offline
post #58 of 84 Old 11-20-2013, 08:14 AM Thread Starter
Hey Max...is he gonna run into trouble with that cover on the 3.4? I don't think you can put the old pan on the 3.4 can you? I mean the way the rear of the pan interfaces with the crank seal? ddog800 if that is the case you're gonna need a front cover and pan too. Fortunately for you I have a crate motor cover....brand stinking new too that came with my motor. Since I put serpentine accessories like the 87 forward ones, I didn't need this one. It is for all practical purposes a regular 86 normal direction housing with the new sealer bottom....Hell man, even if you CAN use the old 2 bolt cover and pan, I wouldn't because that POS will leak eventually. That design never sealed well. Either that or convert to serp accessories like I did. I freakin love the single belt design. Especially when it comes to servicing the truck. My truck has an electric fan too, so it makes taking it on and off a very simple operation. If you did that you could use any 87+ front cover or pan which are extremely common....Even the F body one, but the issue with that is that there is no timing tab. Suppose you could add one, but I don't know how accurate you would get on it.
post #59 of 84 Old 11-21-2013, 07:25 PM
ddog800's Avatar
I'm too familiar with the mechanical fuel pump setup, but here's a pic.....
ddog800 is offline
post #60 of 84 Old 11-26-2013, 10:23 AM Thread Starter
That is definitely a newer block...right there in front should be where the pump should be if it existed....See the outline for the base? But there is no hole in the front. So unless there has been some part swapping this confirms some old covers and pans went on new motors for 86.
post #61 of 84 Old 01-12-2014, 11:10 PM
User is: spyder76 is offline
what about fuel sys and fuel pump
spyder76 is offline
post #62 of 84 Old 06-20-2014, 05:55 PM
85s10_4x4's Avatar
User is: 85s10_4x4 is offline
Correct me if I am wrong, but didn't GM discontinued the ht3.4 "crate"engine?
post #63 of 84 Old 06-26-2014, 04:04 PM Thread Starter
Yeah, but there are still sources for them I think if you dig. I bought mine back in 2010 assuming they would be gone before too much longer. Just now getting harder to find them.
post #64 of 84 Old 08-20-2014, 12:26 PM
User is: miracleman is offline
This might be a silly question, but I haven't seen it specifically addressed anywhere. Are you guys running stock clutches? I'm thinking about doing a similar swap, but I wasn't sure if the stock clutch would handle the roughly 210hp and 230lbft of torque I'm looking to make.
So I was curious if you guys just used the stock clutches, or upgraded to something like this: http://www.phoenixfriction.com/p-231...odeo-9-18.aspx
post #65 of 84 Old 09-16-2014, 08:43 AM
User is: exsubslr is offline
I've got an 91 reg cab short bed 2.8 5 speed that I've done the 3.4 camaro swap with 4.3 injectors.l have about 5 thousand trouble free miles on it and I want to thank the people who posted all the great info. About 1 month ago I decided to charge up the air and get it working again. This hilighted an inherant issue with this swap. The compressor would choke out the engine when driving fast and downshifting from 3rd to second. I installed an air/fuel guage and it was going fully lean at that moment and those old pancake compressors draw a lot of power so consequently it would kill the engine. Too dangerous to drive. Has anyone on this site had a similar problem? I'm working with a company called Motorvation to get a custom fuel curve added to the prom. The first attempt cured the lean condition and the air worked fine but the mixture was way rich. The stoich meter was fully rich throughout the driving range. No good. I'm waiting on the second chip to arrive. Im just wondering ifsomeone out there has had the same problem and already knows the ultmate solution. If so you will save me a lot of trouble. Any help will be greatly appreciated.
exsubslr is offline
post #66 of 84 Old 10-24-2014, 11:26 AM
User is: anjrinc is offline
Thank you for sharing this information..
anjrinc is offline
post #67 of 84 Old 10-24-2014, 12:32 PM Thread Starter
You are most welcome...glad we could help!
post #68 of 84 Old 10-27-2014, 05:17 PM
User is: mattryyc is offline
That PDF from page 1 doesn't seem to be up any more. Anyone else have a copy? The rear main seal in my 84 is finally letting go and I'm planning to hunt down a crate 3.4.
mattryyc is offline
post #69 of 84 Old 10-28-2014, 08:37 AM Thread Starter
Let me see what I can do
post #70 of 84 Old 10-28-2014, 09:21 AM Thread Starter
Here ya go bud.
https://drive.google.com/file/d/0BxV...ew?usp=sharing
Last edited by jimmykicker; 10-28-2014 at 09:27 AM. Reason: Gvgjfjgcjgfgjfjhfgvjhctjdjt;675.5;)'fthdhvgngchgczyx:#<|%~%
post #71 of 84 Old 10-28-2014, 01:18 PM
User is: scrappyk5 is offline
I have posted a progress thread on the start of my 3.4 swap from a camaro, but I am going to verify something here instead. I am still confused on the front cover situation even though I have read this thread a few times.
Soo, If I decide to stay with the serpintine setup that came with the 94 3.4 motor, I can leave the front just the way it is but I need to install a oil pan and pickup from a 87 and up 2.8 4x4 style. And I am aware that the front cover will not have a timing tab. Is this correct ?
But, if I decide to go with vbelts, from my 85 2.8, I will need to install the front cover, water pump,acessories,oil pan, and pickup. With also the thought that the front cover isnt the greatest because they are known to leak.
Is this correct ?
Last, If I decide to go vbelts and not use the old front cover, what exactly do I need and from what year 4x4 set up ?
post #72 of 84 Old 10-28-2014, 07:28 PM Thread Starter
I messaged you on this one...If you use Camaro accessories, use an S10 water pump unless you convert to electric.
If you stay V belt, you need a 1986 front cover from an S10. Your old cover won't work. The 86 is unique in that it has the newer style seal on the bottom, and still has the V belt water pump rotation. A crate engine comes with one although a different part number it is the same part. You will need a 1985 water pump, an 86+ oil pan, 86 front cover. You cannot use your 85 cover.
I'd source a 1987+ serpentine system and call it a day. The only snafu you will run into is that the outlet on the carb intake will interfere with the idler pulley bracket. A 90 degree elbow and a grinder will correct it.
I have a new 86 cover from my crate I did not use. PM me if interested.
post #73 of 84 Old 11-13-2014, 06:03 PM
User is: sparkybuoy is offline
Just waned to state that the reason why the 3.4L crate engine was not emissions legal was because GM screwed up and put a cam in it with a lot of overlap which means low speed smog checking would fail - replace the cam with the one with regular stock style overlap - available aftermarket as well from Melling, etc
post #74 of 84 Old 11-14-2014, 11:30 AM Thread Starter
I don't know if they screwed up, or just didn't care that they didn't make 1/50th of the nation's states' smog requirements. "California didn't make it...Oh well, put that stock cam back in it I guess! Those assholes in the other 49 will just have to deal" LOL.
post #75 of 84 Old 11-17-2014, 01:13 PM
Just wanting to get something straight and I am doing it here for others to know in the future. I have read different things about when swapping over or getting a new one, of the oil pump screen. Now from my understanding the oil pump pickup tube in my 2.8 is too small to fit in the camaro 3.4 oil pump. So I have read that I can either swap over the pickup tube and cover from the 2.8 to the 3.4, ( if its not worn out.). or I have read a pickup tube for a 4.3 is the same size as the 3.4. Now here's the confusing part. I have read the pickup tube in the 3.4 is about 3/4" and the pickup tube in the 2.8 is 5/8". Well I go to look online and all the pickup tubes I am finding for the 4.3 are also 5/8". Does someone have a part number that gets me a pickup that is
3/4" ? thanks. This is for a 4x4 application.
post #76 of 84 Old 11-17-2014, 01:29 PM Thread Starter
Try this and see if it has the part number from the crate. May be helpful, maybe not. https://drive.google.com/file/d/0BxV...ew?usp=sharing
post #77 of 84 Old 09-06-2015, 10:36 PM
User is: Wall-peter is offline
How about fuel consumption?
post #78 of 84 Old 09-11-2015, 08:25 AM Thread Starter
In my case? Better than 3.8. Better power to weight ratio. Getting about 18-19. I was getting 14-16, usually with the 4bbl and about freaking 12 with the Rochester.
post #79 of 84 Old 02-28-2016, 05:25 AM
User is: bigcountry87 is offline
You guys should make this a sticky! It would eliminate a lot of redundant questions. Here is a PDF I made of the parts list and I also included the start-up instructions for the motor at the end of the document.
http://www.tricky6.com/S10files/3-4%20Instructions.pdf
That's piggybacked on my band's site just in case you were wondering what the heck "tricky 6" is.
Enjoy!!
The link is dead and just leads to frontiers search bar
post #80 of 84 Old 02-28-2016, 05:26 AM
Dead link as well
post #81 of 84 Old 03-15-2016, 08:28 AM Thread Starter
Try this guys...
post #82 of 84 Old 10-11-2017, 05:47 PM
heeter_33's Avatar
User is: heeter_33 is offline
Just subbing this thread so I never forget.
1985 S10 2.8
2010 Cobalt SS
1972 Honda CB100
post #83 of 84 Old 02-08-2019, 08:49 PM
Yowakawaka's Avatar
User is: Yowakawaka is offline
So does the 3.4 motor mount straight where the 2.8 was or do you need to get new motor mounts?
post #84 of 84 Old 02-10-2019, 11:42 PM Thread Starter
Absolutely. The 3.4 is a drop in. Other than an electric fuel pump conversion and a couple other things it’s straight up drop in.
