3.4 "crate" engine parts list and info - S-10 Forum
 2Likes
post #1 of 84 Old 01-23-2010, 10:02 PM Thread Starter
Awww..you ain't got shit!
jimmykicker's Avatar
You guys should make this a sticky! It would eliminate a lot of redundant questions. Here is a PDF I made of the parts list and I also included the start-up instructions for the motor at the end of the document.
http://www.tricky6.com/S10files/3-4%20Instructions.pdf
That's piggybacked on my band's site just in case you were wondering what the heck "tricky 6" is.
Enjoy!!
1984 xcab s-10 3.4L GM crate engine 91 S10 TBI swap w bored intake, Edelbrock headers. 2" Rough Country Lift. Flowmaster, shift kit, e-fan.
I had to cut my nut in half .
post #2 of 84 Old 01-30-2010, 01:21 PM Thread Starter
Re: 3.4 "crate" engine parts list and info
I am also going to post pictures of all the front covers from 4 different applications so we'll know which is which.
post #3 of 84 Old 01-30-2010, 10:49 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Questions........on this site..............redundent?
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #4 of 84 Old 01-31-2010, 05:04 AM
Rebel_US's Avatar
User is: Rebel_US is offline
Jimmy, I like the pdf so far...
Their is a 'conversion chart' referenced in the instructions: Pg1, right side, 1st para - for those converting with a manual trans or a 4X4 - unless I am missing it, I don't see it,
I'm following ALOT of threads regarding the 2.8 to 3.4 swap - it would be awesome if we had all the info in one place and as a sticky.
1986 S10 Regular cab w/2.8L -220 TBI - 4 speed manual transmission - 230K Original Miles and STILL going!
1997 S10 Xtend cab w/4.3L (X) Vortec -Automatic - 160K Miles (NEW 5/2011 - $ 750 bucks!)
http://easyautodiagnostics.com/index...articles_1.php
Rebel_US is offline
post #5 of 84 Old 01-31-2010, 01:00 PM Thread Starter
Yeah, that is the whole kit and kaboodle man. I noticed that too, but didn't see the info either. Maybe we are both crazy.
post #6 of 84 Old 01-31-2010, 01:00 PM Thread Starter
Okay, here is the skinny on the front covers. Pay close attention to the swirl patterns in each cover to make sure you know what you are getting, as well as the lack or presence of the bolts that enter from the bottom.
Cover 1 is the 1st style for the 82-85, and rumored at this point to be used on early 86. It uses the two bolt fastening system on the front. It uses a standard rotation water pump and is used with V belts.
Cover #2 to the right is the F body type used in Camaro and Firebird 3.4s. It starts I think in 93. It uses a reverse rotation water pump for a serpentine belt. It has no timing tab. You can add one, and use this for a serpentine system setup on an S-10. Notice the lack of bolts at the bottom. Requires newer style S-10 87 (late 86) to 93 oil pan.
Cover number 3 is for 87-93 S-10. Reverse rotation water pump. Reverse swirls. Use this with serpentine systems. Always use newer oil pan for correct fit.
Cover number 4 is the crate engine front cover. Part numbers cross over and identify it as the same cover used on later 86 models. Rumor has it that the first 86s used the original two bolt type number 1 cover and original oil pan, so watch out. This cover is unique in that it fits like number 2 and 3 as far as the oil pan is concerned, but rotates like #1. Don't throw away your old timing cover because this one does not come with it's own tab. You'll likely have to grind the goofy tamper proof bolts off to get it off.
Hope this helps. Please make this a sticky!!!
post #7 of 84 Old 02-01-2010, 01:05 AM Thread Starter
Here is something I found that might help the average Joe putting a 3.4 in place of a 2.8
Swap Your Chevrolet 2.8L For A 3.4L
0
Overview:
The 2.8L sixty degree V6 engine was used throughout the First Generation S-10/S-15, Blazer/Jimmy production so it, understandably went through several updates and improvements. In normal GM fashion, not all the upgrades were made at the same time so this clouds the picture.
From 1982 to 1985 engines were carbureted and used a mechanical fuel pump. The rear main seal was a 2 piece seal prone to failure. The bearing journals were a weak spot and spun rod bearings were common. The front [timing] cover is machined for the water pump to rotate in the same direction as the crankshaft using multiple vee belts to drive the accessories. This engine is externally balanced using weights welded onto the flywheel/flex plate.
Despite its shortcomings, many of these engines are still running and many have been turned into boat anchors.
The year 1986 was a year for big changes. The bearing journal was increased. A single piece rear main seal was added and the heads were upgraded to 1.72″ intake valves and 1.42″ exhaust valves. The biggest change was throttle body fuel injection (TBI). This system consisted of a 2 barrel throttle body with each bore measuring 1 3/8″ with a single injector for each barrel. The injectors sat above the throttle body and mixed with the fuel and air before the throttle blades. An On Board Diagnostic (OBD) 1 computer system controlled the injectors along with spark control for the engine. There was also an in tank electric fuel pump to deliver fuel. Pressure was controlled by a regulator mounted on the throttle body. Pressure was between 11 and 13 PSI. Power increased to 125 hp. and 150 ft. lbs. The front cover is the same as the older engines and vee belts were still used and the balance was still external.
1987 introduced the serpentine belt. This required the front cover to be machined to work with a water pump turning in the opposite direction from the crankshaft. The only visible difference between the front covers is the direction of the ’swirls’ machined in the area behind the water pump impeller. This makes a difference in the coolant flow and an engine with the wrong front cover will have cooling problems. The belt tensioner is usually mounted with a #55 TORX fastener. The belt driven component brackets were re-designed to hold the components in a stationary position for the serpentine belt. This engine was still external balanced.
1988 is the introduction of internal balanced components. The flywheel/flex plate changed to a neutral balance assembly free of welded counter weights. The 2.8L stayed the same until it was discontinued.
60 Degree Evolution:
General Motors continued to utilize the 60 degree engine in various RWD and FWD applications. The most popular RWD vehicle was the Camaro/Firebird which used the 2.8L through 1990. In 1991 the engine was stroked into the 3.1l for a 10% increase in displacement. The block stayed the same and is a direct bolt in replacement for a 2.8L engine. In 1993 the block casting was strengthened and bored to 3.4L for another 10% increase. The FWD version made the same advancements and the D.O.H.C. 3.4L in the Grand Am shows how far GM took this design. FWD engines are utilized in transverse mountings and have the starter mounted on the opposite side when compared to RWD engines. FWD engine also use different motor mounts, thus the block does not have the mounding holes drilled and taped for RWD mounts. First generation FWD engines used the same cast iron heads and the RWD vehicles but later changed to an aluminum head. The aluminum heads are NOT available with an intake for TBI or Carbureted engines. There are ways to convert you vehicle to using a different fuel injection system along with these late model heads and intakes. But this article will not discuss these possibilities. For choosing a block it is recommended to choose from RWD blocks to ease your swap.
Sources of 3.4L Engines:
The ideal used engine is the 93-95 Camaro and Firebird and they are readily available throughout the country. Engine re-builders sell 3.4L long block setups for the Camaro. The Ideal NEW engine is the GM HT 3.4L Crate engine.
The GM HT3.4L is GM’s new, bolt in, long block for carbureted 82 to 85 S-10 vehicles. Their advertising says it cannot be used on TBI applications because GM only emissions approved it for 82-85 automatics. This is due to each variety [auto and standard] need their own approval and the newer EFI units would need the same. They cannot recommend that you use the engine for an application that is a violation of the Federal Air Pollution laws. When you consider the requirements of installing the crate engine in an 82 to 85, it becomes clear that it is more suitable to the newer (EFI) vehicles. Using this block in and EFI vehicle however, will void the factory warranty on the engine.
If you are going to use the crate for a TBI truck the crate engine comes with the front cover for vee belts, You must change this (except on an 86) so your water pump will work properly. Remember it was discussed earlier that the serpentine belts require the water pump to turn in the opposite direction that vee belts do. Then ALL of your existing 2.8L accessories, sensors, manifolds, mounts, a neutral balance flywheel (if applicable), intake and throttle body.
For a carbureted engine you need an electric fuel pump because there is no place on the block to mount a mechanical fuel pump, this applies is using the crate or a Camaro engine. Also 82 to 83’s with a cable clutch need to change over to a hydraulic clutch system because there is no ‘boss’ for the clutch cable pivot. Also it is recommended to install a fuel pressure regulator for your carburetor, you can however use the regulator on the old mechanical pump but this is a jobber solution at best. Then continue with swapping over all of your existing 2.8L accessories, sensors, manifolds, mounts, a neutral balance flywheel (if applicable), intake and throttle body.
If you have chosen to use a Camaro engine on your TBI truck with serpentine belts remember that the Camaro was a car that used a serpentine setup. BUT you still need to remove the pump and front cover and use your S-10 components. The front cover does not have a pointer on it to set timing and the pump will not work with the S-10 pulley which will be needed for your clutch fan. However, there is one exception. If you are going to use an electric fan for your S-10 you can use the Camaro water pump for your swap. The Camaro pump uses a smaller pulley, this will not cause any problems as the tensioner will absorb the small amount of extra slack. You will actually benefit from an over driven water pump and have more water flow. If you are using the Camaro engine for a carbureted truck everything on the Camaro block must go an you must use your original S-10 parts.
General Swap Information:
Serpentine belt front covers will not work on vee belt engines. In 1986 The S-10 used a combination vee belt and serpentine belt drive. This truck still uses the normal vee belt front cover.
Anyone with a 4X4 needs to swap the oil pan and pick up over to the 3.4L as the 4X4 has a different sump than the 4X2 and the Camaro.
A Camaro oil pan will NOT work on an S-10. Always use your S-10 oil pan weather it be 4X4 or 4X2 or the crate pan if you own a 4X2.
If you have a truck (4X4 or 4X2) with vee belts and you are doing the Camaro swap it is suggested that you buy a new style oil pan that came on the serpentine belt equipped trucks and the crate motor’s front cover. This new style pan will mate with the crate motor’s front cover and you will NOT have to use the old style cover. The old cover and pan’s design is far inferior to the newer setup. The new setup also uses a rubber gasket which will seal much better. If you are doing a crate swap then 4X2 owners will have no problem. 4X4 owners should buy a new style pan to mate with the crate motor’s front cover. However if you are on a really tight budget with your swap then you may use the old style pan and cover. Remember that they MUST be use together you cannot mix and match parts.
TBI systems from 2.8L engines will run lean on a 3.4L unless you make some modifications. This will be discussed later in the article
Remember that if you are not using a new engine you are using something with WEAR always inspect a used engine. Cam, lifters, timing gear, bearings and seals all need to be checked and replaced if bad.
The Camaro engine can be re-cam’d w/ a low-mid torque cam like the one in the crate engine. This is a good solution for camshaft wear.
Your 2.8L headers and other bolt on items will fit onto the 3.4L block.
Always prime the oil system in any 60 degree engine. The hex shaft under the distributor fits a 6point 8mm socket. Tape it onto an extension and use a hefty electric drill to turn the oil pump until oil comes up ALL the pushrods. Smaller drills won’t have enough torque once the oil starts to fill the system.
TBI systems have two temperature sensors, one in the intake manifold and one in the corner of the driver’s side head. The plug in the head has an 8mm square hole. This is hard to find. On a new crate engine, ROBO GRIP type pliers can remove the plug. Vise Grips won’t. NOTE: the passenger side head has the same plug facing the firewall. This would be the ideal place to hookup an aftermarket temperature gauge.
The Knock Sensor screws into the water jacket on the starter side. On Camaro engines it is close to the motor mount and clears the starter. The crate engine only has one threaded block drain and it’s close to the starter. They don’t look like they would interfere when the engine is out and the exhaust manifolds are off. The plug won’t hook up to the knock sensor as the small wire on the starter solenoid is in the way. A 1/4″ x 1″ NPT pipe nipple and a 1/4″ elbow move the sensor away enough to hook it up. Do this before the engine is installed.
ALWAYS change the o-ring on your distributor. When you do this tape the shaft of the distributor with electrical tape all the way from where the groove for the o-ring starts to the very bottom the the gear. This will protect the new ring from any nicks or cuts. Then slide the o-ring, coated in oil, up to the groove where it sits.
The rotor points to 7:00 o’clock when #1 is at TDC Firing.
When the distributor starts to come out, the rotor will move to 6:00 o’clock position. When you install it; start with the rotor pointing to 6:00 o’clock and is should swing over to 7o o’clock. The new o-ring will make it snug, work at it till it is completely seated. Make sure that the engine is on compression and the timing marks are lined up at zero. If it won’t start, line the marks up and take off the cap. If the rotor is pointing at 2:00 o’clock; you were 180 degrees out, do it over.
Camaro flywheels are thicker than S-10 flywheels so you can’t use a Camaro flywheel in the 2.8L bell housing because there is no room for the fork. 82 thru 87 truck owners with manual transmissions need to obtain a neutral balance flywheel from an 88-93 2.8L S-10. Or have a machine shop remove the weights and neutral balance the flywheel with a flywheel resurface, this would be as good as buying a new flywheel.
In your Camaro block you will notice some extra holes. These come from the cam position sensor, the crank position sensor and the block heater (if equipped). Fill these holes with the proper sized frost plugs to ensure a quality swap. NEVER just cut the wires short and leave the sensors to keep the hole plugged.
You cannot use any of the Camaro accessories on a TBI truck because they all have some differences from the S-trucks. The alternator has the same internals and in theory would work but the case is different. The power steering pump is the same on the outside but the pressure regulator is different, as it was use on a rack and pinion system in the Camaro. The water pump, like the alternator, is the same inside but the shaft and snout on the pump is a shorter length, While you can use the Camaro water pump and pulley, you cannot use it with a clutch fan.
The starter for both engines are the same inside and out except for the 12 volt supply post on the 2 are different sizes. The S-Truck one is larger than the Camaro.
When putting on the engine mounts from an S-10 on to the 3.4L you may have to grind part of the mount to clear the casting around the base of the engine (where the oil pan bolts up) it may be necessary to remove about 1/4 inch of material off the mount.
Doing The Swap:
Drain all your fluids first!
Remove the engine and bell housing as one unit and remove the transmission and drive shaft on their own. The transmission must be removed to free the engine and the driveshaft must come out to remove the transmission. The drive shaft is removed by un bolting the retaining clips in the rear. If you have a 2 piece shaft un bolt the carrier bearing also. With all the bolts undone slide the shaft forward until it is free from the rear and then slide it back in the other direction to pull it from the transmission. Now remove your cross member to aid in the removal of your transmission. On a manual you can just un bolt the transmission from its bell housing and pull it out. On an auto you will have to un bolt the bell housing from the engine. To do this it will be easier to remove the transmission cross member first and then drop the transmission tail down to make it easier to access the top bolts. Before you drop out your transmission be sure to remove all of the connectors and fuel line clamps. When removing the slave cylinder from a manual you just need to remove the blots and SLOWLY back it off from the clutch fork. Allowing it to just spring out may introduce air into the lines or even damage the slave or master cylinder. Some people have removed and reinstalled the engine with the transmission in tact but it is much trickier. With your driveline out it is time to move forward with the engine removal.
Drain all your fluids first and disconnect your battery and remove it! Remove the upper fan shroud, unhook the hoses from the radiator and remove it and the lower shroud. Remove the bolts holding the clutch fan to the water pump shaft and remove the fan. Start removing the belt driven items. Remember to keep the power steering pump upright and slide it into the corner behind the driver’s headlight, the hoses should allow this but it will leak if it is not upright. Hopefully the A/C compressor can be moved to the passenger side and stay connected (either of the author’s trucks did not have air) and all the rest of the accessories and the mounting brackets get removed from the engine compartment. This is a good time to unhook and remove the fuel line and return line from the TBI, watch out for fuel under pressure. Fuel WILL spill, mop it up. This makes a lot of space in front of the engine where one can stand, after climbing over the radiator support, and work on the engine. Use lots of penetrating oil on the exhaust manifold bolts, start applying it a few days before you want to start removing them. The exhaust manifold and ‘Y’ pipe can stay in the truck. Remove the bolts connecting the manifolds to the engine.
Remember that it really helps to take pictures of the general layout of the engine compartment before tearing things out and it is the only way to remember the location of the items that share the manifold bolts! A shop manual will also be a great asset.
Remove the air filter assembly and note the vacuum hose connections. Remove the distributor. Remove the fuel lines or just move them out of the way. You can choose weather or not you want to remove the intake manifold. If you leave it remove the TBI unit from it, if not the TBI can be left on the manifold and just remove the manifold and TBI as one. Use a 13mm offset wrench, the kind where the opening is dropped below the plane of the wrench handle, to loosen the two middle fasteners blocked by the Intake manifold body. Remove the distributor. The hex shaft that drives the oil pump might come out with the distributor. Remove the coil and EGR controller from the rear lift eye. This will make room to get to the grounds bolted to the back of the driver side head. You should be able to stash the top engine electrical harnesses over the wiring running behind the engine. Pull the bottom harness back after unhooking the knock sensor and the starter wires. Unhook the oil pressure sending unit(s) and unscrew them from the oil filter mount. Set up a chain and your hoist, you should be ready to remove the engine mount through bolts. Double check that everything is disconnected and tighten up the hoist and make sure it starts to lift the engine. Triple check that everything is loose and start lifting. Work the exhaust manifolds around the oil filter, mounts and the starter until the engine is free (the spring loaded bolts to the ‘Y’ pipe allow them to move around a bit). If you left your transmission on your engine you will have to lift on a very extreme angle to the truck. You will have to work very slow and a few hands may be needed to do some lifting and turning. If you have already removed the transmission then your angle will not be as extreme but may still require some help so you don’t chip any paint. Swap all your necessary components and ready your self for reinstallation.
Some reinstallation tips. When installing the transmission and engine together you will reach a point where the upper engine mounts are sitting on the front half of the lower mount and it seems that it won’t go any farther. Get a jack under the transmission tail shaft area and jack the transmission up against the floor boards. This will raise the back of the engine and allow it to be lowered over the bottom mounts. If you choose to install everything separate the just reinstall the reverse of the removal. If you have a manual transmission be sure to align the clutch pack before you reinstall the engine. This will allow easy installation of your transmission. When you install your manual transmission put it in the highest gear (5th or 4th depending) so that you can turn the shaft by hand to allow it to slide into the mating splines. Then shift your transmission into neutral so that it can turn freely to install the drive shaft.
Carburetor Owners:
When you have your swap done you will be fine using your carburetor and fuel delivery will not be a problem. However you may have to adjust your regulator which you will now have if you followed the previous advice given in the article. 12 switched supply will have to be given to your new fuel pump. Some further tuning to fuel delivery may have to be done to achieve a desirable fuel curve.
TBI Owners:
There is a few extra steps involved in your swap. You need to supply more fuel to the engine. The old 2.8L injectors will not suffice. The simplest and surefire way to do this is to buy a set of 4.3L injectors to add the extra fuel. Simple and effective, they bolt right on, no modifications to anything is necessary. Some other option include a custom PROM for the computer. A Holley 502-3 TBI unit will also supply the fuel flow and give some extra air flow.
The 2.8L TBI is equipped with 33 lb/hr injectors, and the computer “pulses” the injectors at a rate commensurate with the 2.8L displacement. The idea is to keep the air / fuel ratio as close to 14.7 to 1 as possible. The computer can adjust for variances from engine to engine and different driving conditions, but the 3.4L is more adjustment than the computer can ideally achieve. As a result, drivability problems, such as hesitation and stalling in open loop, are common with 3.4L engines running stock 2.8L injectors. Installing the 4.3 injectors (45 lb /hr injectors) solves these problems and improves overall performance by allowing the injectors to flow more fuel using the same band pulse width (BPW) that is programmed in the 2.8L ECM. Running the 3.4L engine with 2.8L (33 lb/hr) injectors can cause a dangerously lean condition, especially at RPM’s above 4000 because the air to fuel mixture is far too lean than what is required.
Sources for injectors are abundant. The cheapest option is to go to a salvage yard and pull injectors off a 4.3L engine. Look for the newest ones you can. When you get them home it is HIGHLY recommended you get a rebuild kit and replace the gaskets and o-rings. Or just go out an buy a new set. GM OEM injectors are the injectors of choice but several makers offer their own equivalents.
When you are ready to install them there could be nothing simpler. Assuming the TBI is already installed on the truck. Remove the air cleaner assembly. Un bolt the 2 fuel lines from the injectors. There is one o-ring on each of the lines. If these are cracked or hard they need to be replaced or they will leak. After you remove the fuel lines, un clip the wiring harness. Un screw the 3 Torx bolts holding the injectors to the base. Remove the injectors. If the injector base gasket is damaged then replace it. Now place the new 4.3L injectors on the base and screw them down. Reverse the rest of the procedures to finish the job. Start the truck or apply power to the fuel pump prime lead and check for leaks. If there are no leaks have fun!
Final Thoughts:
This article was written twice. First it was based on installing a HT 3.4L crate engine into a 1988 Tahoe, small cab/long bed 4×2 truck with a 5 speed transmission. The decision to pull engine and transmission together was based on the author’s previous experience changing a clutch. The top two bell housing to engine bolts are almost impossible to remove and the T-5 seemed more compact than an automatic so it seemed possible. Tractor trailer jack stands were used under the rear axle and the front air dam was almost on the ground. This might not be achievable by many people that don’t have a level concrete floor and huge jack stands to work with. One alternative would be to strip off the intake and both heads. One person used to say you could then straddle the engine block and get at those two top bolts. Later this article was revised when the second author used a Camaro engine to install in a 1993 GMC Sonoma, extended cab, 5 speed. This author first removed the engine with the transmission, based on previous advice. But realized later it was better to remove the transmission from the bell housing instead. This is how the engine was reinstalled. The clutch pack was first aligned with an alignment tool.
Working alone, the first author spent almost thirty hours, working nights after work (used a bay in the shop @ work) and one weekend to complete the swap. One shop mechanic helped for around 15 min. He had the idea to raise the transmission to get it to fit. A forklift was used to do the lifting and the shop parts washer allowed each part to be cleaned after it was removed. Groups of parts and their fasteners were stored in big zip loc bags and piled inside the cap covered bed. The crate engine was kept inside its bag until ready to dress w/ the parts off the 2.8L. It is easy to change the clutch when the transmission and engine are sitting on a skid!
The crate comes with a cardstock covering the intake area. This was removed and a bunch of clean rags covered this area and the cardboard was placed over the rags. The intake was installed after the engine was back in the truck and the distributor waited until the engine was filled with oil and the oil system was primed. You cannot use a wimpy drill to prime the system as the building pressure results in the need for a lot of torque to keep the oil pump turning. Make dams out of rags to keep the oil from spilling all over and prime the system until oil comes out of ALL the pushrods, the last few will take some time to get oil.
The second author did the swap in a house garage. However, it was very well equipped. Lots of help was on hand. The swap was done over a longer period of time and several modifications were made to the engine. Everything was cleaned when removed and then bagged or put in groups with its relating parts. The Camaro engine was fully rebuilt, cleaned and painted.
4X4 Swaps are similar. One person said that she did not even remove the transmission and transfer case from the vehicle and just left it supported by jack stands.
Written by Mark Wismer and Geoff Moore -Source
http://www.s10mods.com/archives/37
post #8 of 84 Old 02-01-2010, 03:03 AM
4x4 v6 blazer
neo71665's Avatar
User is: neo71665 is offline
Thats the link I always post, want more of his work?
http://members.shaw.ca/betterthanyou/
scroll down to his links
87 blazer tahoe 2 door, 5.7, auto, sfa 4x4
91 noma reg cab, 3.4, 5speed, lowered
President of the Arkansas chapter Anti-bag Coalition
"Bags are for groceries"
Originally Posted by alarm_the_alarm View Post
Lift That Sh*t, Fat Girls Can't Jump
i just made love to your bowels......and then reported them.
neo71665 is offline
post #9 of 84 Old 02-01-2010, 01:28 PM Thread Starter
Yep, that is pretty dogone thorough. Who do we need to contact to make this a sticky? The pix and posts would eliminate a load of redundant questions.
post #10 of 84 Old 02-01-2010, 04:11 PM
4x4 v6 blazer
neo71665's Avatar
I think What? made my code thread a sticky. Told me to contact him directly if there was anything else I ever needed.
Betterthanyou (Geoff) also once gave me the ok to basically rip all his stuff off on the site I mod, giving him full credit of course.
neo71665 is offline
post #11 of 84 Old 02-01-2010, 08:10 PM Thread Starter
Well between the covers, the installation tips and the parts list, I think it just about has it covered. Can you think of anything else?
post #12 of 84 Old 02-24-2011, 01:12 AM Thread Starter
Awesome! It's a sticky! This should really help the guys in the forum. Thanks "what?" for adding it!!!
post #13 of 84 Old 03-02-2011, 12:44 PM Thread Starter
Something to add from betterthanyou's post
"Serpentine belt front covers will not work on vee belt engines. In 1986 The S-10 used a combination vee belt and serpentine belt drive. This truck still uses the normal vee belt front cover."
That is MOSTLY true. There is some speculation that the lower part of the cover is the same on some early (two bolt design) 86 trucks as the 82-85, but the 86 cover's bottom design should fit like the 87. The ONE difference between that and the 87+ cover is the swirls in the cover. My guess is that there may have been left over 85 covers and pans, so they used them till they ran out on 86. That's of course an educated guess at best.
post #14 of 84 Old 03-03-2011, 12:53 PM
ddog800's Avatar
User is: ddog800 is offline
When I pull my engine and swap over the timing cover, I'll snap a pic and post it for sh*ts and giggles.
'86 S-10 Blazer TBI 2WD automatic - 2.8 -- soon to be 3.4
ddog800 is offline
post #15 of 84 Old 03-03-2011, 03:53 PM Thread Starter
Cool...I'd like to get to the bottom of the 86 cover deal. There was another member that had an 86 that swears it has the two bolt cover instead of the rounded one. Sure not 100% on that. If it does wind up having the two bolt cover, research the VIN and see what it says the manufacture date and plant is. More than likely built right there in Louisianna I would think. I know they had a plant there that built S-10s, but not sure of Blazers.
post #16 of 84 Old 03-31-2011, 08:36 PM
86' S-10
User is: GEARS is offline
For anyone that wants to do a carb'd setup 3.4, I suggest you install a 180* thermostat... motor runs much nicer and doesn't heat up anywhere near as much in the summer time.
If you are running TBI, this cannot be done as the ECM does not read operating temperature until 185*...
I was able to run the 180* on my TBI, but I have a lil' secret for how I did that...
1986 S10 PU "SCLB" 2WD 355 TH400 3.73 8.8"
Dart 215 headed full roller 355, Full manual TH400, Killduff Lightning Rods, 150 shot of spray, homemade traction bars
GEARS is offline
post #17 of 84 Old 04-01-2011, 09:09 AM Thread Starter
That's where I have my fan kick on. Runs very cool. By the way, my unused crate (86) front cover is on eBay right now since I went to a serpentine setup. If one of you guys wants it, I'll pull it and sell it to you cheaper than the BIN. Just search for my username. Same dude! :0) Rather one of you guys have it honestly. Brand new, never installed, with the factory installed oil seal driven in already.
post #18 of 84 Old 05-12-2011, 10:01 AM Thread Starter
Talking Simple as it's gonna get....
Simplified Front Cover Explanation
Keep seeing a lot of questions about this...Got to thinking about it, and figured the easiest way to explain what will work on the 3.4 swap as far as covers, oil pans, and water pumps are concerned. This is pretty much a definitive list of compatiblity. They will only work in these combinations
V Belt setups 82-85
1. Use the original oil pan, front cover and water pump from your donor 82-85 2.8 that was already in your truck. Forget the Cam/Bird cover, pump and oil pan. Not the best choice though, cause the 2 bolt in the front oil pan is a notorious leaker.
2. Use a 1986 (or crate engine) front cover, an 87-93 oil pan, and the stock 82-85 water pump. This is great because it allows you to use the better sealing oil pan, yet still allows standard rotation water pump for the V-belts. Note: the part number for the “crate” 3.4 engine is different than the 1986 cover, but it IS the same exact part.
Serpentine Systems 87-93
1. Use the entire system from your S-10 (or a donor to upgrade if you have an 82-86, which is what I did cause I detest V-belts). Take the cover, pump and pan and put them on your Cam/Bird 3.4 motor. You COULD use the Cam/Bird front cover because the direction is correct, but there is no timing tab. In a pinch, you could probably add one. You cannot use the oil pan from the Cam/Bird. Use only a water pump from 87-93 S-truck. There is ONE exception. If you are using an electric fan, you can keep the Cam/Bird water pump. You can’t use it with an engine driven fan because it’s too short. It works just fine with the electric fan though. That’s how I have mine. It may actually provide a benefit, as the pulley is smaller too (underdrive). Don't worry though, the stock belt works fine, as the tensioner will eat the extra slack.
2. I have been told that the Cam/Bird accessories will clear everything if you wanted to retain all that. but you’ll have to rewire and reroute wiring and hoses, which seems hardly worth it to me, especially if you have existing parts. You’d still have to swap the oil pan regardless, so it you can’t just “drop in”. Remember too, no timing tab on the cover either.
Setups that definitely will NOT work
1. Don’t mix 82-85 front covers with water pumps from 87-93 or vice versa.
2. Oil pans from 82-85 won’t work front covers from 87-93 and vice versa
3. The 1986 cover will not work with 87-93 serp setups. Although it will bolt up, the swirl direction is like the 82-85.
4. Not sure what year part you have? Check the pics and research it. Water pump rotation is important. Make sure that the water pump direction is correct or IT WILL RUN HOT!!!
Hope that helps...Anyone anything to add to that ??
post #19 of 84 Old 05-12-2011, 01:02 PM
jman85's Avatar
User is: jman85 is offline
This flywheel is for a 88-up balance shaft 2.8l I have a picture of a non balance shaft 2.8l flywheel outta a jeep cherokee that shows the counter weight but I am not sure if it's different then a gm one.
Here's the one from the 88 n up as you can see there's holes drilled in one side of this flywheel that's done to balance the flywheel properly.
The cherokee one just to give an idea it looks like a gm one but here.
1985 gmc s15 4x4 high sierra 5 speed 2.8l reg cab short box 3 inch body lift SOLD
1991 gmc jimmy 2 door 4.3l auto 4x4 lifted 2 inches on air SOLD
highly modded 97 dodge diesel 4wd 5 speed fully loaded making 450hp and 28mpg.
93 sle 4wd 4 door jimmy
jman85 is offline
post #20 of 84 Old 05-12-2011, 01:02 PM Thread Starter
Jman also noted that it is impossible to bolt the wrong pump on the wrong cover due to the design...hadn't considered that, but I am pretty sure he is correct, so that's a non issue really. Anybody 100% on that?
post #21 of 84 Old 05-13-2011, 12:33 AM
jman85's Avatar
I am i contemplated what was different between the 85-87 motor for a week the shape is wrong n bolt patterns too
jman85 is offline
post #22 of 84 Old 05-16-2011, 02:38 PM
User is: xxiamdrewxx is offline
I may be able to add a little bit to the older vs 86 timing cover and water pump. I am currently swapping my v belt setup for the one that is currently on my 86 camaro. I will post pictures of both considering while I have the front of my motor off I am guna do the timing chain. I will add some pictures of them to this post soon as I get home from work. Both are the 2.8 but the camaro is setup with a serp belt for the alternator and water pump. Another fun little project is getting the camaro radiator to mock up in my truck :P.
post #23 of 84 Old 05-25-2011, 11:40 PM
User is: Summerbreeze is offline
New to forum so please excuse redundent questions. I bought a 95 Camaro 3.4 SFI engine and ut it in my 88 S-10 in place of the 2.8. Iwant to run the SFI. I got the PCM and wiring harness with the engine. I changed the oil pan from the 2.8 , had the fly wheel resurfaced punt in a new clutch package . Changed the 2.8 motor mounts over and bolted it in. if anyone has done this swap I would be very interested in the wiring changes needed. Many Thanks. Great Site.
post #24 of 84 Old 01-22-2012, 10:31 AM
iwillnc's Avatar
User is: iwillnc is offline
Above it is stated that "someone" made mention on how to easily remove the engine from the bellhousing.
I can confirm if you remove the heads from the engine you can remove the entire engine from the transmission without ever getting under the vehicle.
ALL the bolts are extremely easy to get to with the heads removed, use a 18mm IIRC
HOWEVER- I would highly reccommend getting a ratcheting wrench for it or your going to be turning that wrench for a very long time. those are very fine threads
By far easiest removal of engine I could imagine
iwillnc is offline
post #25 of 84 Old 01-22-2012, 10:34 AM
iwillnc's Avatar
Oh and just for the input since 87 was a mixture year for flexplate, my flexplate is in fact weighted on my 2.8
iwillnc is offline
post #26 of 84 Old 05-09-2012, 09:26 PM
iwillnc's Avatar
"TBI systems have two temperature sensors, one in the intake manifold and one in the corner of the driver’s side head. The plug in the head has an 8mm square hole. This is hard to find. On a new crate engine, ROBO GRIP type pliers can remove the plug. Vise Grips won’t. NOTE: the passenger side head has the same plug facing the firewall."
Just a note to anyone who may need help here -
In rockauto's tool section they sell the 8mm socket bit
It's a bit steep at almost $11.
But for those that have no idea what robogrips are and want the simplicity of a socket it's there.
iwillnc is offline
post #27 of 84 Old 05-10-2012, 09:32 AM Thread Starter
Steel stock from lowe's will also work. You could weld ya one up with a handle for a couple of bucks.
For me, I just ground down an el cheapo Harbor Freight extension till it fit. Worth the sacrifice
post #28 of 84 Old 06-21-2012, 07:31 PM
spongebob's Avatar
User is: spongebob is offline
i love this thread....
87 4X4 5 speed 2.8 being replaced with a goodwrench 3.4, fiero valve covers, intake bored to accept a larger 4.3 TB.
post #29 of 84 Old 09-28-2012, 03:14 PM
Should've had a V8.
s10_2.8's Avatar
User is: s10_2.8 is offline
This info is being saved haha, thanks guys
FS: First Gen brake lights, 4.3 TB, 2.8 intake manifold, 2.8 air cleaner housing, heater core shroud, first gen sun visor.
Click the name for the thread.
1992 s10 "Old and Un-faithful" 3.4L RIP
1995 s10 "What the hell, it runs?" 2.2L Long Bed RIP
1996 Saturn SL2, 2000 SL TWIN PILES OF CRAP
s10_2.8 is offline
post #30 of 84 Old 12-16-2012, 09:12 PM
Real human bean
Baja Blazer 85's Avatar
User is: Baja Blazer 85 is offline
I hate bringing back old threads just as much as everyone else, but does this PDF exist elsewhere? Link is dead.
-2002 Subaru Forester
2.5L, S
The daily beater
-1985 Chevrolet S10 Blazer
2.8L, 4x4, Sport
Project VIPER MKII https://www.s10forum.com/forum/f30/pr...permk2-757353/
-1985 Mercedes Benz 500SEL
5.0L V8
The sheik mobile, lowered and VIP'd
-1963 Sunbeam Alpine
1.7L, Convertible
Restored
post #31 of 84 Old 12-17-2012, 12:09 AM
spongebob's Avatar
i love this site.....
post #32 of 84 Old 04-30-2013, 11:01 PM
Should've had a V8.
s10_2.8's Avatar
you guys ever seen this site? I guess it lists all the parts you need to do this swap...
http://www.crateenginedepot.com/pdfs/V6_HT34.pdf
s10_2.8 is offline
post #33 of 84 Old 04-30-2013, 11:11 PM
spongebob's Avatar
hmmm i have a 87.......
post #34 of 84 Old 04-30-2013, 11:39 PM
Should've had a V8.
s10_2.8's Avatar
hows your swap coming along? You got a build thread man? I'm dropping mine in, in about 8 hours!!!
s10_2.8 is offline
post #35 of 84 Old 05-01-2013, 12:02 AM
spongebob's Avatar
i got the nose up and pulling parts off the 2.8.
i need my s-10 on the road, been down for a year now..
post #36 of 84 Old 05-01-2013, 12:22 PM Thread Starter
Mine is done and just swapped over to an EFI system from an 87. Did away with the 4bbl setup. Getting about 5 more miles to the gallon as a result....Let me know how I can help you guys in any way possible.
post #37 of 84 Old 05-01-2013, 07:27 PM
spongebob's Avatar
what was the power difference??
post #38 of 84 Old 05-02-2013, 12:24 AM Thread Starter
Well, I can't tell you what a 3.4 did with the 2.8 injectors and intake, but I can tell you that this SOB doesn't run like any 2.8 I ever drove before....The 3.4 with the carburetor made very decent power, but with the EFI system and 4.3 TBI and injectors, it runs incredible. It has a wicked amount of power for a V6. Especially one as small as a 3.4. It would outrun my 01 4.3 S10 x-cab I used to have easily....Compared from her roots which was a 2.8 with a Rochester maybe hitting 110 hp she is like a different truck. I haven't even begun to tune it yet, and not only is the power better than before with the 4bbl, but it's getting more than 4 more mpg too. Seems like a win to me.
SidecarDoug likes this.
post #39 of 84 Old 05-02-2013, 11:12 AM
spongebob's Avatar
i'm getting wood!!!
blacksheep1974 likes this.
post #40 of 84 Old 06-25-2013, 07:17 PM
User is: NT_Hardcore is offline
iv got a few questions i cant find answers for. iv almost got my 3.4 ready to go in my 87 2wd s 10 blazer. im looking at an oil pressure sensor that does not fit the 3.4 motor. how do i do this? do i just use the sensor of a 3.4? mine didnt have a working one (broken) and i can see what the conn is on the 3.4 one (2 prong, 3 prong)? any help would be great
post #41 of 84 Old 06-25-2013, 11:25 PM
Should've had a V8.
s10_2.8's Avatar
Use the one for the 2.8, I took the whole unit that mounts on the side of the block off my 2.8 and put it on the 3.4. (the entire thing, including what the oil filter screws onto.
s10_2.8 is offline
post #42 of 84 Old 06-26-2013, 12:43 AM
oh ok thank you so much. i think thats the only issue we were having.
post #43 of 84 Old 06-26-2013, 05:22 PM
Should've had a V8.
s10_2.8's Avatar
use the 2.8 timing cover too. Even if you don't use the timing tab, the outlet for the radiator hose is smaller on the camaro timing cover. Ask me how I figured this out -.-
s10_2.8 is offline
post #44 of 84 Old 06-26-2013, 10:34 PM
thank you ill make sure we change em out. i got the oil filter housing gasket today. its finally ready to go together and in the truck.
post #45 of 84 Old 06-28-2013, 07:19 AM Thread Starter
Wild...when I posted the pictures of that in 2010 I NEVER noticed that. It is in fact smaller than the S10 one...another good reason not to use it.
post #46 of 84 Old 06-28-2013, 09:18 AM
So were gonna pick up gaskets and pull the waterpump ect back off and change the cover lol.
post #47 of 84 Old 06-28-2013, 09:26 PM
pulled water pump, pully and harmonic balancer. figured we would just do the timing chain, gears and the guide. chain has so much slack it broke the guide lol
post #48 of 84 Old 06-28-2013, 09:43 PM
Real human bean
Start a thread and post pics! I wanna see this dude.
2.5L, S
The daily beater
2.8L, 4x4, Sport
5.0L V8
1.7L, Convertible
Restored
post #49 of 84 Old 06-29-2013, 05:31 PM
ill try and get one going. not many pics ill see what i have if we ever finish the project lol
post #50 of 84 Old 06-30-2013, 10:00 PM
Should've had a V8.
s10_2.8's Avatar
Any tips on pulling that balancer off? I didn't change my cover because I couldn't get the SOB off.
s10_2.8 is offline
