2.8 timing way off/failed emissions - S-10 Forum
post #1 of 10 Old 11-18-2015, 12:11 PM Thread Starter
User is: slicknick13 is offline
So I went for an inspection today and failed all of my idle tests:
CO: limit 1.2, actual 8.88
HC (ppm): limit 220, actual 1059
2500RPM tests were good:
CO: limit 1.2, actual 0.01
HC (ppm): limit 220, actual 50
We poked around a little in the garage with the tailpipe still hooked up, cleaned the EGR, plugged the evap, pulled the PCV etc. with no change in the idle emissions.
Next step was to check timing, which was retarded by a long shot. We're talking like the timing mark is in the 3 o'clock position. At that point, I had to leave the shop.
Got the truck home, the distributor loosened, and the base timing wire unplugged with no change. Tried to advance the timing but it naturally won't even get close to the marks. Plugged the scan tool in to make sure all of my sensors were sending data, though I don't know what to look for on a lot of them at idle. Temp and everything was OK.
Any suggestions out there? I just can't fathom why that timing mark was so off unless the balancer ring slipped or something.
Truck runs fine, but is pretty rich at idle. I put a kit on the throttle body very recently, so it's all cleaned out.
post #2 of 10 Old 11-29-2015, 02:26 PM Thread Starter
Re: 2.8 timing way off/failed emissions
Following up to this since I hate dead end threads:
Changed the O2 sensor. That got me some action that I didn't have before on my scan tool.
Rotated the engine to TDC and marked the balancer. I guess it slipped. Got the motor timed to what I think is around 10 degrees. The 'ol screwdriver in the spark plug hole technique has a little room for error.
At this point I was running pretty good. I had reset the ECM and was out driving to relearn everything. Took it up to the inspection shop and hooked it to the tester, numbers were a lot better but still not where it needed to be. A bump to the throttle to keep the engine off idle, but still within the idle specs of the testing equipment brought it in to passing. Barely.
Only "problem" I have left is that the truck won't go into closed loop at idle. Which is why I think we had to bump the throttle during the test to get it to pass, it would go into closed loop at that point and clean up.
New vacuum hoses and a hot air riser should get me into a pretty reliable state for the winter.
post #3 of 10 Old 11-30-2015, 05:22 AM
User is: damanx is offline
What BIN is in the ECM?
I have the 1228062 ECM with ATKX BIN and it goes into open loop at idle.
It does this to keep the engine cooler by dropping the BLM value to whatever amount is programmed in the BIN.
What scan tool are you using?
If you can see these numbers with it, what is the IAC count, and, what is TPS voltage value?
1985 GMC S-15 Gypsy ext cab.
3.4l, Edelbrock intake, a 4.3l throttle body controlled by an '88 TBI ECM. 700R4 with 3.73 rear. Real time tuning using a CF-30 Toughbook with a Moates Ostrich 2 emulator.
damanx is offline
post #4 of 10 Old 12-26-2015, 09:09 PM
User is: sparkybuoy is offline
It has to get to certain coolant temp to go into closed loop so if you have scan data...if you don't see it go over I think it was 140 degrees farenheit...it won't go into closed loop which usually points to a lazy thermostat - if it needs a thermostat get the correct 195er from NAPA and get the Premium - it's made by Robertshaw and is warranted forever against defects including laziness or sticking closed
post #5 of 10 Old 12-28-2015, 10:30 AM
Maybe later.
tytotheler92's Avatar
I agree. It sounds like a lazy thermostat at this point.
1988 S-15 - 5.5/6 drop
1985 S10 Blazer 4WD
1998 Blazer ZR2 5 Speed!
post #6 of 10 Old 01-03-2016, 04:59 PM Thread Starter
Thermostat is a 195, brand new.
Here's a snapshot after warming up to operating temp.
post #7 of 10 Old 01-06-2016, 08:05 AM
You've checked for vacuum leaks?
As stated, a lot of the BIN's for these ECM's go into open loop at idle and that is why you see the short term fuel trim locked at 128.
Has the maybe it's a cat problem?
What ECM are you using and do you know what the 4 letter code on is?
1000 rpm at idle after warm up seems high.
damanx is offline
post #8 of 10 Old 01-08-2016, 08:07 PM
That's REALLY fat at idle
Idle speed is too high however that's not going to cause you to be that fat
you might have weak spark and at idle that's gonna hurt ya
what's MAP voltage at wide open throttle?
Check MAP vacuum line for leaks
post #9 of 10 Old 01-08-2016, 08:14 PM
what year is yours?
I remember back then they'd go into open loop at idle and that mostly because they have the oxygen sensor way down stream without it being a Heated oxygen sensor
post #10 of 10 Old 01-08-2016, 08:26 PM
you can convert it to a HEATED Oxygen sensor and fix that issue and also gain mileage and driveability
