2.8 problems - Page 2 - S-10 Forum
post #51 of 56 Old 07-01-2015, 02:53 AM
User is: damanx is offline
Re: 2.8 problems
Use the 3.4 flex plate and yes, the motor will bolt right up to the tranny.
If I recall correctly, there isn't a provision on the 3.4 block to accomodate the hydraulics for a manual transmission.
I've also done this conversion, along with the TBI.
Jimmy seems to forget that.
1985 GMC S-15 Gypsy ext cab.
3.4l, Edelbrock intake, a 4.3l throttle body controlled by an '88 TBI ECM. 700R4 with 3.73 rear. Real time tuning using a CF-30 Toughbook with a Moates Ostrich 2 emulator.
damanx is offline
post #52 of 56 Old 07-06-2015, 12:17 PM Thread Starter
S10tahoe28's Avatar
User is: S10tahoe28 is offline
Re: 2.8 problems
So I through some 20w/50 in it. Does run a little better, still shitty going slow, jerky sometimes. But this morning I pulled at o2 rich code, so idk what's causing that
post #53 of 56 Old 07-07-2015, 08:26 PM Thread Starter
S10tahoe28's Avatar
2.8 problems
So looking at my injectors. Both of them are Misting fine, but they both look like they have a little bit of a drip to them. They don't trip when you turn the truck off though. But what I'm assuming is that below a certain rpm the injectors are flowing a little to much, and once engine speed increases it can handle the extra a little better. But is that possible while only throwing a rich code once? Basically how much slack does the computer give before it throws a code for to much or to little?
post #54 of 56 Old 07-09-2015, 12:14 PM
Awww..you ain't got shit!
jimmykicker's Avatar
Re: 2.8 problems
There isn't a boss for the cable on the 82-83ish. The hydraulic will work fine on the 3.4
I had to cut my nut in half .
post #55 of 56 Old 07-19-2015, 12:06 PM Thread Starter
S10tahoe28's Avatar
Re: 2.8 problems
Fuel injectors are bad. Ones shot spitting fuel out the top and the other one is dripping
post #56 of 56 Old 07-19-2015, 04:33 PM Thread Starter
S10tahoe28's Avatar
Re: 2.8 problems
So I took the tbi apart to clean it. And although I've heard that our trucks don't come with adjustable tps, mine is adjustable. So what should the meter read when I've got it set in the right spot? Also drilled out the cap for my idle set screw
