2.8 4 barrel swap - S-10 Forum
post #1 of 7 Old 02-09-2019, 11:11 AM Thread Starter
User is: Matthewswolf is offline
2.8 4 barrel swap
Hay all so I’m getting a for barrel intake for my little 2.8 and had a couple questions. First is what cfm carb should I run? 390? And my other question is the fuel pump. It’s mechanical right now should I remove that and go electric? And if so witch one? Thanks I’m advance!
post #2 of 7 Old 02-09-2019, 11:23 AM
B4U Task Force
Rhotpursuit's Avatar
Re: 2.8 4 barrel swap
You might look into a Weber swap....much better than a Holley/Rochester swap.
Apple Red 96 SS
post #3 of 7 Old 02-09-2019, 01:06 PM Thread Starter
I have a Weber on it but I found a Edelbrock 4 barrel carb compleate intake for 70 bucks. From a friend of mine.
post #4 of 7 Old 02-09-2019, 09:16 PM
oldgold1985's Avatar
User is: oldgold1985 is offline
Keep the Weber and change the upper intake. http://edelbrocksupercharger.com/i-1...ifold-top.html
1985 S-10 RCSB 2.8 4 spd 01/01, 1985 S-10 Blazer 2.8 auto 4X2, [parts truck] 07/16 , 1985 S-10 Blazer 2.8 4 spd 4X4, 03/17, 1985 S-10 Blazer Tahoe 2.8 auto 4x4, 09/17. 1984 S-10 3.4 auto [parts truck] 10/17
post #5 of 7 Old 02-10-2019, 03:16 PM Thread Starter
This is what I have. And I want to use.
ID:	314629   Click image for larger version
post #6 of 7 Old 02-10-2019, 04:47 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
I'd give you $125...
If you have a good Holley 390 CFM, give it a try.
You can always buy the 2 barrel top and run the Weber later.
It also helps to have a decent exhaust system.
Post your reaction to the Holley/Eddy set up.
If you have a 38/38 Weber, there isn't going to be a huge difference in performance.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #7 of 7 Old 02-12-2019, 09:03 AM
Awww..you ain't got shit!
jimmykicker's Avatar
I'd really like to hear the difference in performance too. I used to have the Holley/Eddy setup myself. Compared to the factory carb and intake it blew me away. Unbelievable the difference. I never ran the Weber, so I'm not sure how that would have run out on the truck. Max has done every conceivable version I think.
My truck currently has a 3.4 in it and I converted it to EFI. It uses a stock intake bored out with a 4.3 TBI unit on top of it. It runs out really good. Good enough to pull 235/75s still with plenty of available power. It's actually a 2wd truck with a small lift on it. 3.42 rears.
1984 xcab s-10 3.4L GM crate engine 91 S10 TBI swap w bored intake, Edelbrock headers. 2" Rough Country Lift. Flowmaster, shift kit, e-fan.
I had to cut my nut in half .
Similar Threads
2.8 to 4.3 swap ZRZ0088 262ci Forum (4.3) 6 11-08-2018 09:43 AM
2.8 to 3.4 swap few questions wmnixdorf 60v6 Forum (2.8/3.4) 15 09-30-2018 10:39 AM
2.5 to 4.3 swap seymourj98 262ci Forum (4.3) 3 11-04-2017 09:40 PM
2.8 to 4.3 swap S10miles S10 / S15 2 05-23-2016 01:11 AM
