1985 2.8 idle and miss issue(s) - S-10 Forum
 1Likes
  • 1 Post By Randy Sweet
post #1 of 9 Old 04-03-2019, 10:24 PM Thread Starter
User is: Adhwc is offline
Hey all,
Just purchased a 1985 S10 4x4 from a co-worker. Overall a decent little truck, but has an issue once its warmed up with an engine light and misfire. I've only had s10s with the 4.3 before and NEVER had any issues with any of them, so I don't even know where to begin. Please dumb things down as much as possible
What happens:
Upon cold start (ONLY if it has NOT been started for the day, even a cold start on the same day will not usually provide the same result!), it will idle a little rough and I will need to give it some gas for a short time before the choke seems to "set". Only about a 5 second process, but it happens every time when I start it for the FIRST time that day. Afterwards, zero issues starting or idling upon cold start.
Main issue - The truck will idle and drive perfect, with no check engine light for a good 5-15 minutes while driving until it reaches operating temps. I will be sitting at a light and all of a sudden I will feel a miss and the check engine light will illuminate once the truck has warmed up. Light & miss happen at the exact same time, every time. Neither happen by themselves.
This process will repeat itself indefinitely. If I start the truck very shortly after it has been driven (say getting gas, etc) it will miss and the light will illuminate. If it has been sitting for a few hours, it will be perfect until it warms up again.
What I've done:
Using the paperclip trick I received the three codes as listed:
CODE 13 - 02 sensor or circuit
CODE 45 - oxygen sensor or circuit - rich exhaust detected
CODE 21 - throttle position sensor or circuit - voltage high
Parts I've replaced since scanning codes:
Spark plugs, wires, o2 sensor, entire distributor, also cleaned the carb a little
Drove it home, same EXACT problem as before with the missing and light. I disconnected the battery last night after the repairs and let it sit until today. Reconnected, and drove. Issue again was reproduced.
Scanned the codes again to see if all three still showed up, or if I was getting something different:
Question:
Is there a way to adjust this sensor, or does it just need to be replaced? (Its cheap enough, not a big deal either way). ALSO, does this engine light and failure of the TPS correspond with the issues I am having, or is there something else? (MAP sensor, EGR, etc)?
I was thinking if I cannot find any information I would just replaced ALL sensors/valves, as parts are extremely cheap and I have access to cheap labor.
Thanks everyone!
Adhwc is offline
post #2 of 9 Old 04-10-2019, 10:34 PM
Awww..you ain't got shit!
jimmykicker's Avatar
Man. I’m so sorry no one has responded to you yet.
Apparently this truck is EFI since it has TPS and an ECM. Are you sure it’s an 85? Round gauges or the cluster that juts of the dash? If it’s in fact an 85 with a 2.8 it’s been retrofitted like mine.
To me this sounds fuel related. I’m going through a strange situation with my truck too that is a retrofit EFI. I think mine is related to possibly having the wrong hoses connected and the BS with the externally mounted pump. Bout to find out. I’m replacing the tank, the pump module to stock and rerouting the lines correctly.
Just throwing this out of your truck is a retro fit. May be in my boat.
1984 xcab s-10 3.4L GM crate engine 91 S10 TBI swap w bored intake, Edelbrock headers. 2" Rough Country Lift. Flowmaster, shift kit, e-fan.
I had to cut my nut in half .
post #3 of 9 Old 04-15-2019, 05:03 PM Thread Starter
Re: 1985 2.8 idle and miss issue(s)
Hi, Yes, it is for sure an 85. I had someone check it out and they said both choke pull offs are bad, so I decided to order new ones. I'll put those on and see what happens from there. He stated the code might be a false positive because of the bad choke offs causing it to idle too high and dump too much fuel, reading it as a bad TPS. I'm just going off information I've been told in person, I know little to nothing about the 2.8 nor about carburetion or Pre-OBD II systems. There is a part they call the TPS though, and apparently it sits inside the carb which has to be removed to change it out.
Do you have images of your retrofit? I'm curious to see what it looks like.
Adhwc is offline
post #4 of 9 Old 04-16-2019, 02:17 AM
SFA3.4
User is: Randy Sweet is offline
Make sure the electric choke is opening all the way. Bad pull offs will make it rich when it's cold but they don't really do anything when hot unless the choke thermostat isn't opening. The tps code will set if the computer sees tps voltage out of range. You'll need to check it's output voltage with a digital voltmeter. This could be related to the choke not opening all the way but probably just a bad tps.
Adhwc likes this.
post #5 of 9 Old 04-16-2019, 08:56 PM Thread Starter
So I might as well get a choke thermostat as well? If I need to remove the carb to change out the parts I figure I might as well just buy parts it probably needs and do it all in one big swoop, even if it ends up not needing the part, instead of continuing to troubleshoot.
I suppose I'll wait until I get my pull offs, see if any impact is made, if not, buy the thermostat and put the TPS I already purchased in.
Adhwc is offline
post #6 of 9 Old 04-17-2019, 06:52 PM
SFA3.4
You only have to pull the top off to change the tps but you will need a new gasket that if i remember right is only available in a carb kit. At that point you should probably pull the whole thing off and replace all the gaskets. If the choke thermostat is working I'd leave it alone. Its riveted and its kind of a pain to replace unless someone already has.
post #7 of 9 Old 04-18-2019, 10:56 PM Thread Starter
So would I check to see if it is working properly by checking it on a cold engine, then seeing how it is after it has been warmed up (no change to the choke = faulty)? Sorry for sounding ignorant, I'm a youngin' born when fuel injection was becoming popular.
I'll check on that and if needed buy the thermostat and repair kit as well and can have everything all done at once. I'm just dreading missing a part that needs to be fixed/replaced after taking everything apart and putting it back together,
Adhwc is offline
post #8 of 9 Old 04-19-2019, 10:35 AM
SFA3.4
The choke blade should be fully closed after pumping once when cold. Immediately after it fires up the pull off should open the blade about 25%.
After about 10 minutes the thermostat should fully open the blade.
post #9 of 9 Old 04-21-2019, 07:41 PM Thread Starter
I just tried it out today. Looks like it is doing exactly what you stated it should. Opened up about 25% or so once I started her up. It was smoking black and hesitating a little bit, but actually didn't die by itself today. Once it warmed up it opened fully (pic included). Is this hesitation because of the pull-offs, if the choke is working correctly?
One thing I did notice, however, was it seemed to be idling really high, and I pushed back on the throttle/spring and it kicked down to what seemed to be the appropriate level. Wondering if this has to do with the possible faulty TPS?
ID:	316303   Click image for larger version
Adhwc is offline
